Webcam only Upload
steve03222
Webcam only Upload
Post by steve03222 »
I am wondering how I would go about uploading just the Aircam image to WeatherUnderground using weatherbridge?
I have software that I don not want to switch for uploading my weather data, I would just like to be able to get an Aircam with IP so that I can basically not be limited in length that I currently have with a USB webcam.
So in a nutshell, I just want to upload a webcam image to WU using an Aircam that I would purchase. I have Weatherbridge, but not using it.
Thanks, Steve
Re: Webcam only Upload
select "weather underground CAM upload" on weather network tab. You can't set weather station to "none", so select one and try your luck. Meteobridge will endlessly try to connect to your weather station, but this should not block doing webcam uploads.
steve03222
OK, I have not purchased the cam yet, wanted to make sure it would work 1st.
