meteohub.log
joachimF
meteohub.log
Post by joachimF »
In this log there are always the following lines (no other lines!)
logger (23.07.2014 17:24:21): station 0 (Meteostick), suspicious humidity reading: hum(last) 31(0)% (a0 00 00 37 1d 00 d4 32) -86db
logger (23.07.2014 17:25:05): station 0 (Meteostick), suspicious humidity reading: hum(last) 0(31)% (a1 00 00 00 05 00 5b 7d) -99db
logger (23.07.2014 17:25:53): station 0 (Meteostick), suspicious humidity reading: hum(last) 31(0)% (a0 00 00 34 1d 00 8d 62) -84db
logger (23.07.2014 17:25:57): station 0 (Meteostick), suspicious humidity reading: hum(last) 0(31)% (a1 00 00 00 05 00 5b 7d) -96db
logger (23.07.2014 17:26:04): station 0 (Meteostick), suspicious humidity reading: hum(last) 31(0)% (a0 00 00 34 1d 00 8d 62) -87db
logger (23.07.2014 17:26:10): station 0 (Meteostick), suspicious humidity reading: hum(last) 0(31)% (a2 00 00 00 05 00 95 9d) -93db
logger (23.07.2014 17:26:45): station 0 (Meteostick), suspicious humidity reading: hum(last) 31(0)% (a0 00 00 33 1d 00 08 f2) -80db
logger (23.07.2014 17:26:51): station 0 (Meteostick), suspicious humidity reading: hum(last) 0(31)% (a3 01 25 00 03 00 5b c1) -81db
3 lines per minute :?:
Best Regards
Joachim
http://www.puttkammer.de
Re: meteohub.log
it is simplified logging code (not taking into account that more than one hum sensor might be there) to trap a bug in interpreting hum data from RF packets delivered by Meteostick. Will be stripped with next update, as I found the bug.
Napajedlaci.cz
Re: meteohub.log
Post by Napajedlaci.cz »
I have problem with meteohub.log. What is this? Error?
loggereval (31.07.2014 00:06:48): illegal data record in line 983816 while reading from file /data/weather/201304/raw: 201 t9 317
loggereval (31.07.2014 00:06:48): illegal data record in line 984395 while reading from file /data/weather/201304/raw: a8 13
loggereval (31.07.2014 00:06:48): illegal data record in line 984414 while reading from file /data/weather/201304/raw: 800 data7 100
loggereval (31.07.2014 00:06:48): illegal data record in line 984711 while reading from file /data/weather/201304/raw: 201304301443101 data7 100
loggereval (31.07.2014 00:06:48): illegal data record in line 985307 while reading from file /data/weather/201304/raw: 20130435645 rain0 0 0 4658
loggereval (31.07.2014 00:06:49): illegal data record in line 985588 while reading from file /data/weather/201304/raw: 2ta8 13
loggereval (31.07.2014 00:06:49): illegal data record in line 985607 while reading from file /data/weather/201304/raw: 2n0 0 0 4658
loggereval (31.07.2014 00:06:49): illegal data record in line 985888 while reading from file /data/weather/201304/raw: 20130430152263441500
loggereval (31.07.2014 00:06:49): illegal data record in line 986187 while reading from file /data/weather/201304/raw: 201153400 data1 263528700
loggereval (31.07.2014 00:06:49): illegal data record in line 986206 while reading from file /data/weather/201304/raw: 2013
loggereval (31.07.2014 00:06:49): illegal data record in line 986486 while reading from file /data/weather/201304/raw: 201 263597600
loggereval (31.07.2014 00:06:49): illegal data record in line 986505 while reading from file /data/weather/201304/raw: 14
loggereval (31.07.2014 00:06:49): illegal data record in line 986784 while reading from file /data/weather/201304/raw: 201304130430160000 data1 263684700
loggereval (31.07.2014 00:06:49): illegal data record in line 986802 while reading from file /data/weather/201304/raw: 2013040 0 0 4658
loggereval (31.07.2014 00:06:49): illegal data record in line 987083 while reading from file /data/weather/201304/raw: 20130 6
loggereval (31.07.2014 00:06:49): illegal data record in line 987701 while reading from file /data/weather/201304/raw: 201304364028 data4 4
loggereval (31.07.2014 00:06:49): illegal data record in line 987980 while reading from file /data/weather/201304/raw: 20130430165220130430165200 data3 83
loggereval (31.07.2014 00:06:49): illegal data record in line 987998 while reading from file /data/weather/201304/raw: 201304301652 211
loggereval (31.07.2014 00:06:49): illegal data record in line 988279 while reading from file /data/weather/201304/raw: 20130b0 313 42 0169 9833 1 10168
loggereval (31.07.2014 00:06:50): illegal data record in line 988298 while reading from file /data/weather/201304/raw: 201304301709 data0 107
loggereval (31.07.2014 00:06:50): illegal data record in line 989473 while reading from file /data/weather/201304/raw: 2013043017574
loggereval (31.07.2014 00:06:50): illegal data record in line 989772 while reading from file /data/weather/201304/raw: 201304301810430180929 data8 14
loggereval (31.07.2014 00:06:50): illegal data record in line 989790 while reading from file /data/weather/201304/raw: 20130430181000
loggereval (31.07.2014 00:06:50): illegal data record in line 990071 while reading from file /data/weather/201304/raw: 20data0 86
loggereval (31.07.2014 00:06:50): illegal data record in line 990688 while reading from file /data/weather/201304/raw: 00
loggereval (31.07.2014 00:06:50): illegal data record in line 990967 while reading from file /data/weather/201304/raw: 20
loggereval (31.07.2014 00:06:50): illegal data record in line 990986 while reading from file /data/weather/201304/raw: 249 t9 187
loggereval (31.07.2014 00:06:51): illegal data record in line 991267 while reading from file /data/weather/201304/raw: 201304301915091236 date0 2013 4 30 20 8
loggereval (31.07.2014 00:06:51): illegal data record in line 991863 while reading from file /data/weather/201304/raw: 201304301data0 67
loggereval (31.07.2014 00:06:51): illegal data record in line 992162 while reading from file /data/weather/201304/raw: 2013043095300 data0 177
loggereval (31.07.2014 00:06:51): illegal data record in line 992181 while reading from file /data/weather/201304/raw: 20130430 4000
loggereval (31.07.2014 00:06:51): illegal data record in line 992479 while reading from file /data/weather/201304/raw: 201304330200728 data6 5400
loggereval (31.07.2014 00:06:51): illegal data record in line 992758 while reading from file /data/weather/201304/raw: 8 12
loggereval (31.07.2014 00:06:51): illegal data record in line 992777 while reading from file /data/weather/201304/raw:  t9 180
loggereval (31.07.2014 00:06:51): illegal data record in line 993057 while reading from file /data/weather/201304/raw: 201 data8 12
loggereval (31.07.2014 00:06:51): illegal data record in line 993654 while reading from file /data/weather/201304/raw: 20130430210000130430205800 data1 33500
loggereval (31.07.2014 00:06:51): illegal data record in line 993672 while reading from file /data/weather/201304/raw: 2013043020582930210100 data0 473
loggereval (31.07.2014 00:06:52): illegal data record in line 995180 while reading from file /data/weather/201304/raw: 201304302289
loggereval (31.07.2014 00:06:52): illegal data record in line 995763 while reading from file /data/weather/201304/raw:  data0 382
loggereval (31.07.2014 00:06:52): illegal data record in line 995782 while reading from file /data/weather/201304/raw: n0 0 0 4658
loggereval (31.07.2014 00:06:52): illegal data record in line 996066 while reading from file /data/weather/201304/raw: 20130430224 0
loggereval (31.07.2014 00:06:52): illegal data record in line 996085 while reading from file /data/weather/201304/raw: 201304302
loggereval (31.07.2014 00:06:52): illegal data record in line 996975 while reading from file /data/weather/201304/raw: 20110 9859 2 10194
loggereval (31.07.2014 00:06:52): illegal data record in line 996995 while reading from file /data/weather/201304/raw: 2data3 83
loggereval (31.07.2014 00:06:53): illegal data record in line 997278 while reading from file /data/weather/201304/raw: 20130430 data8 6
loggereval (31.07.2014 00:06:53): illegal data record in line 997297 while reading from file /data/weather/201304/raw: 201330233746 rain0 0 0 4658
loggereval (31.07.2014 00:07:43): illegal data record in line 96112 while reading from file /data/weather/201305/raw: 201305032110.9 1013.2 0.6 0.0 135 0.00 -999 -999 -999
loggereval (31.07.2014 00:07:43): illegal data record in line 96113 while reading from file /data/weather/201305/raw: 28 10 2013  8 33 12.6 90 11.0 1013.2 0.8 2.5 90 0.00 -999 -999 -999
loggereval (31.07.2014 00:07:43): illegal data record in line 96114 while reading from file /data/weather/201305/raw: 28 10 2013  8 34 12.6 90 11.0 1013.2 0.8 2.5 90 0.00 -999 -999 -999
loggereval (31.07.2014 00:07:43): illegal data record in line 96115 while reading from file /data/weather/201305/raw: 28 10 2013  8 35 12.7 90 11.1 1013.2 0.6 0.0 135 0.00 -999 -999 -999
loggereval (31.07.2014 00:07:43): illegal data record in line 96116 while reading from file /data/weather/201305/raw: 28 10 2013  8 36 12.7 90 11.1 1013.2 0.6 0.0 135 0.00 -999 -999 -999
loggereval (31.07.2014 00:07:43): illegal data record in line 96117 while reading from file /data/weather/201305/raw: 28 10 2013  8 37 12.7 90 11.1 1013.2 0.6 1.4 135 0.00 -999 -999 -999
loggereval (31.07.2014 00:07:43): illegal data record in line 96118 while reading from file /data/weather/201305/raw: 28 10 2013  8 38 12.7 90 11.1 1013.2 0.6 1.4 135 0.00 -999 -999 -999
loggereval (31.07.2014 00:07:43): illegal data record in line 96119 while reading from file /data/weather/201305/raw: 28 10 2013  8 39 12.7 90 11.1 1013.2 0.6 1.7 90 0130503212152 t9 118
loggereval (31.07.2014 00:07:43): illegal data record in line 97930 while reading from file /data/weather/201305/raw: 201305 0 0 1 0105
loggereval (31.07.2014 00:07:43): illegal data record in line 98818 while reading from file /data/weather/201305/raw: 20130531800 data2 64
loggereval (31.07.2014 00:07:43): illegal data record in line 98837 while reading from file /data/weather/201305/raw: 20130572 9821 1 10156
loggereval (31.07.2014 00:07:44): illegal data record in line 99121 while reading from file /data/weather/201305/raw: 2 rain0 0 0 5113
loggereval (31.07.2014 00:07:44): illegal data record in line 99426 while reading from file /data/weather/201305/raw: 0503234408 th0 103 92 0091
loggereval (31.07.2014 00:07:44): illegal data record in line 99446 while reading from file /data/weather/201305/raw:  data2 64
loggereval (31.07.2014 00:07:44): illegal data record in line 100352 while reading from file /data/weather/201305/raw: 20130504 8
loggereval (31.07.2014 00:07:44): illegal data record in line 100636 while reading from file /data/weather/201305/raw: 2013058 data5 9900
loggereval (31.07.2014 00:07:44): illegal data record in line 100655 while reading from file /data/weather/201305/raw: 2013054003808 wind0 315 8 3 0103
loggereval (31.07.2014 00:07:44): illegal data record in line 100940 while reading from file /data/weather/201305/raw: 204800 data5 7500
loggereval (31.07.2014 00:07:44): illegal data record in line 100959 while reading from file /data/weather/201305/raw: 28 data2 64
loggereval (31.07.2014 00:07:45): illegal data record in line 101870 while reading from file /data/weather/201305/raw: 2600
loggereval (31.07.2014 00:07:45): illegal data record in line 102154 while reading from file /data/weather/201305/raw: 0504014050 th0 100 92 0088
loggereval (31.07.2014 08:53:23): illegal data record in line 907698 while reading from file /data/weather/201304/raw: 20130428065627 thb0 246 43 0112 9767 loggereval (31.07.2014 08:53:23): illegal data record in line 907702 while reading from file /data/weather/201304/raw: 2 130428065627 rain0 0 0 4658
loggereval (31.07.2014 08:53:23): illegal data record in line 907703 while reading from file /data/weather/201304/raw: 2010428065628 data0 216
loggereval (31.07.2014 08:53:24): illegal data record in line 907713 while reading from file /data/weather/201304/raw: 2 130428065700 da0a3 83
loggereval (31.07.2014 08:53:24): illegal data record in line 907725 while reading from file /data/weather/201304/raw: 20130428065726 rain0 0 0 4658loggereval (31.07.2014 08:53:24): illegal data record in line 907730 while reading from file /data/weather/201304/raw: 2 130428065729 data5 8700
loggereval (31.07.2014 08:53:24): illegal data record in line 907736 while reading from file /data/weather/201304/raw: 20130428065800 data2 65loggereval (31.07.2014 08:53:24): illegal data record in line 907750 while reading from file /data/weather/201304/raw: 2013loggereval (31.07.2014 08:53:24): illegal data record in line 907755 while reading from file /data/weather/201304/raw: 2013042806 900 data1 243158700
loggereval (31.07.2014 08:53:24): illegal data record in line 907762 while reading from file /data/weather/201304/raw: 20130428065900 data8 14loggereval (31.07.2014 08:53:24): illegal data record in line 907767 while reading from file /data/weather/201304/raw: 201304 8065923 rain0 0 0 4658
loggereval (31.07.2014 08:53:24): illegal data record in line 907777 while reading from file /data/weather/201304/raw: 20130428 70000 data3 83
loggereval (31.07.2014 08:53:24): illegal data record in line 907785 while reading from file /data/weather/201304/raw: 20130428 70022 thb0 248 43 0114 9770 1 10105
loggereval (31.07.2014 08:53:24): illegal data record in line 907790 while reading from file /data/weather/201304/raw: 20130 28070029 data0 285
loggereval (31.07.2014 08:53:24): illegal data record in line 907796 while reading from file /data/weather/201304/raw: 20130428070 29 data6 600
loggereval (31.07.2014 08:53:24): illegal data record in line 907800 while reading from file /data/weather/201304/raw: 20 30428070100 data3 83
loggereval (31.07.2014 08:53:24): illegal data record in line 907812 while reading from file /data/weather/201304/raw: 20130428070121 rain0 0 0 4658loggereval (31.07.2014 08:53:24): illegal data record in line 907813 while reading from file /data/weather/201304/raw: 2013048070128 data1 243173500
loggereval (31.07.2014 08:53:24): illegal data record in line 907818 while reading from file /data/weather/201304/raw: 20130 28070128 data6 700
loggereval (31.07.2014 08:54:45): illegal data record in line 976043 while reading from file /data/weather/201304/raw: 20130430081528 T�loggereval (31.07.2014 08:54:46): illegal data record in line 976940 while reading from file /data/weather/201304/raw: 2085501 data0 176
loggereval (31.07.2014 08:54:46): illegal data record in line 977520 while reading from file /data/weather/201304/raw: 201304300430091729 data2 65
loggereval (31.07.2014 08:54:47): illegal data record in line 977819 while reading from file /data/weather/201304/raw: 201304300933 285 45 0154 9871 2 10206
loggereval (31.07.2014 08:54:47): illegal data record in line 977838 while reading from file /data/weather/201304/raw: 20130430093361368700
loggereval (31.07.2014 08:54:47): illegal data record in line 978136 while reading from file /data/weather/201304/raw: 250 thb0 290 45 0159 9869 2 10204
loggereval (31.07.2014 08:54:47): illegal data record in line 978415 while reading from file /data/weather/201304/raw: 2013043009583
loggereval (31.07.2014 08:54:47): illegal data record in line 978434 while reading from file /data/weather/201304/raw: 20130430095430095935 thb0 295 44 0160 9849 2 10184
loggereval (31.07.2014 08:54:48): illegal data record in line 978733 while reading from file /data/weather/201304/raw: 20100
loggereval (31.07.2014 08:54:48): illegal data record in line 979314 while reading from file /data/weather/201304/raw:  4
loggereval (31.07.2014 08:54:49): illegal data record in line 979614 while reading from file /data/weather/201304/raw: 2013043010508 0148
loggereval (31.07.2014 08:54:49): illegal data record in line 979634 while reading from file /data/weather/201304/raw: 201304301050data3 83
loggereval (31.07.2014 08:54:49): illegal data record in line 980212 while reading from file /data/weather/201304/raw: 2ata4 4
loggereval (31.07.2014 08:54:49): illegal data record in line 980231 while reading from file /data/weather/201304/raw: 2130430111704 th0 235 58 0148
loggereval (31.07.2014 08:54:50): illegal data record in line 980511 while reading from file /data/weather/201304/raw: 201330112652 t9 309
loggereval (31.07.2014 08:54:50): illegal data record in line 980811 while reading from file /data/weather/201304/raw: 2014 4
loggereval (31.07.2014 08:54:50): illegal data record in line 980830 while reading from file /data/weather/201304/raw: 2014300 data4 4
loggereval (31.07.2014 08:54:51): illegal data record in line 981111 while reading from file /data/weather/201304/raw: 201304301115228 data6 500
loggereval (31.07.2014 08:54:51): illegal data record in line 981410 while reading from file /data/weather/201304/raw: 201304301 wind0 315 24 14 0244
loggereval (31.07.2014 08:54:51): illegal data record in line 981430 while reading from file /data/weather/201304/raw: 201304301ata4 4
loggereval (31.07.2014 08:54:51): illegal data record in line 981710 while reading from file /data/weather/201304/raw: 201304301828 data8 13
loggereval (31.07.2014 08:54:53): illegal data record in line 982904 while reading from file /data/weather/201304/raw: 20130 data0 53
loggereval (31.07.2014 08:54:53): illegal data record in line 983202 while reading from file /data/weather/201304/raw: 201300132501 data0 289
loggereval (31.07.2014 08:54:53): illegal data record in line 983221 while reading from file /data/weather/201304/raw: 20130ata6 5400
loggereval (31.07.2014 08:54:53): illegal data record in line 983500 while reading from file /data/weather/201304/raw: 201304303621 date0 2013 4 30 14 31
loggereval (31.07.2014 08:54:54): illegal data record in line 983798 while reading from file /data/weather/201304/raw: 20120130430135100 data0 78
loggereval (31.07.2014 08:54:54): illegal data record in line 983816 while reading from file /data/weather/201304/raw: 201 t9 317
loggereval (31.07.2014 08:54:54): illegal data record in line 984395 while reading from file /data/weather/201304/raw: a8 13
loggereval (31.07.2014 08:54:54): illegal data record in line 984414 while reading from file /data/weather/201304/raw: 800 data7 100
loggereval (31.07.2014 08:54:55): illegal data record in line 984711 while reading from file /data/weather/201304/raw: 201304301443101 data7 100
loggereval (31.07.2014 08:54:55): illegal data record in line 985307 while reading from file /data/weather/201304/raw: 20130435645 rain0 0 0 4658
loggereval (31.07.2014 08:54:55): illegal data record in line 985588 while reading from file /data/weather/201304/raw: 2ta8 13
loggereval (31.07.2014 08:54:55): illegal data record in line 985607 while reading from file /data/weather/201304/raw: 2n0 0 0 4658
loggereval (31.07.2014 08:54:56): illegal data record in line 985888 while reading from file /data/weather/201304/raw: 20130430152263441500
loggereval (31.07.2014 08:54:56): illegal data record in line 986187 while reading from file /data/weather/201304/raw: 201153400 data1 263528700
loggereval (31.07.2014 08:54:56): illegal data record in line 986206 while reading from file /data/weather/201304/raw: 2013
loggereval (31.07.2014 08:54:56): illegal data record in line 986486 while reading from file /data/weather/201304/raw: 201 263597600
loggereval (31.07.2014 08:54:56): illegal data record in line 986505 while reading from file /data/weather/201304/raw: 14
loggereval (31.07.2014 08:54:57): illegal data record in line 986784 while reading from file /data/weather/201304/raw: 201304130430160000 data1 263684700
loggereval (31.07.2014 08:54:57): illegal data record in line 986802 while reading from file /data/weather/201304/raw: 2013040 0 0 4658
loggereval (31.07.2014 08:54:57): illegal data record in line 987083 while reading from file /data/weather/201304/raw: 20130 6
loggereval (31.07.2014 08:54:58): illegal data record in line 987701 while reading from file /data/weather/201304/raw: 201304364028 data4 4
loggereval (31.07.2014 08:54:58): illegal data record in line 987980 while reading from file /data/weather/201304/raw: 20130430165220130430165200 data3 83
loggereval (31.07.2014 08:54:58): illegal data record in line 987998 while reading from file /data/weather/201304/raw: 201304301652 211
loggereval (31.07.2014 08:54:58): illegal data record in line 988279 while reading from file /data/weather/201304/raw: 20130b0 313 42 0169 9833 1 10168
loggereval (31.07.2014 08:54:58): illegal data record in line 988298 while reading from file /data/weather/201304/raw: 201304301709 data0 107
loggereval (31.07.2014 08:54:59): illegal data record in line 989473 while reading from file /data/weather/201304/raw: 2013043017574
loggereval (31.07.2014 08:55:00): illegal data record in line 989772 while reading from file /data/weather/201304/raw: 201304301810430180929 data8 14
loggereval (31.07.2014 08:55:00): illegal data record in line 989790 while reading from file /data/weather/201304/raw: 20130430181000
loggereval (31.07.2014 08:55:00): illegal data record in line 990071 while reading from file /data/weather/201304/raw: 20data0 86
loggereval (31.07.2014 08:55:01): illegal data record in line 990688 while reading from file /data/weather/201304/raw: 00
loggereval (31.07.2014 08:55:01): illegal data record in line 990967 while reading from file /data/weather/201304/raw: 20
loggereval (31.07.2014 08:55:01): illegal data record in line 990986 while reading from file /data/weather/201304/raw: 249 t9 187
loggereval (31.07.2014 08:55:01): illegal data record in line 991267 while reading from file /data/weather/201304/raw: 201304301915091236 date0 2013 4 30 20 8
loggereval (31.07.2014 08:55:02): illegal data record in line 991863 while reading from file /data/weather/201304/raw: 201304301data0 67
loggereval (31.07.2014 08:55:02): illegal data record in line 992162 while reading from file /data/weather/201304/raw: 2013043095300 data0 177
loggereval (31.07.2014 08:55:02): illegal data record in line 992181 while reading from file /data/weather/201304/raw: 20130430 4000
loggereval (31.07.2014 08:55:03): illegal data record in line 992479 while reading from file /data/weather/201304/raw: 201304330200728 data6 5400
loggereval (31.07.2014 08:55:03): illegal data record in line 992758 while reading from file /data/weather/201304/raw: 8 12
loggereval (31.07.2014 08:55:03): illegal data record in line 992777 while reading from file /data/weather/201304/raw:  t9 180
loggereval (31.07.2014 08:55:03): illegal data record in line 993057 while reading from file /data/weather/201304/raw: 201 data8 12
loggereval (31.07.2014 08:55:04): illegal data record in line 993654 while reading from file /data/weather/201304/raw: 20130430210000130430205800 data1 33500
loggereval (31.07.2014 08:55:04): illegal data record in line 993672 while reading from file /data/weather/201304/raw: 2013043020582930210100 data0 473
loggereval (31.07.2014 08:55:06): illegal data record in line 995180 while reading from file /data/weather/201304/raw: 201304302289
loggereval (31.07.2014 08:55:07): illegal data record in line 995763 while reading from file /data/weather/201304/raw:  data0 382
loggereval (31.07.2014 08:55:07): illegal data record in line 995782 while reading from file /data/weather/201304/raw: n0 0 0 4658
loggereval (31.07.2014 08:55:07): illegal data record in line 996066 while reading from file /data/weather/201304/raw: 20130430224 0
loggereval (31.07.2014 08:55:07): illegal data record in line 996085 while reading from file /data/weather/201304/raw: 201304302
loggereval (31.07.2014 08:55:08): illegal data record in line 996975 while reading from file /data/weather/201304/raw: 20110 9859 2 10194
loggereval (31.07.2014 08:55:08): illegal data record in line 996995 while reading from file /data/weather/201304/raw: 2data3 83
loggereval (31.07.2014 08:55:09): illegal data record in line 997278 while reading from file /data/weather/201304/raw: 20130430 data8 6
loggereval (31.07.2014 08:55:09): illegal data record in line 997297 while reading from file /data/weather/201304/raw: 201330233746 rain0 0 0 4658
loggereval (31.07.2014 08:57:02): illegal data record in line 96112 while reading from file /data/weather/201305/raw: 201305032110.9 1013.2 0.6 0.0 135 0.00 -999 -999 -999
loggereval (31.07.2014 08:57:02): illegal data record in line 96113 while reading from file /data/weather/201305/raw: 28 10 2013  8 33 12.6 90 11.0 1013.2 0.8 2.5 90 0.00 -999 -999 -999
loggereval (31.07.2014 08:57:02): illegal data record in line 96114 while reading from file /data/weather/201305/raw: 28 10 2013  8 34 12.6 90 11.0 1013.2 0.8 2.5 90 0.00 -999 -999 -999
loggereval (31.07.2014 08:57:02): illegal data record in line 96115 while reading from file /data/weather/201305/raw: 28 10 2013  8 35 12.7 90 11.1 1013.2 0.6 0.0 135 0.00 -999 -999 -999
loggereval (31.07.2014 08:57:02): illegal data record in line 96116 while reading from file /data/weather/201305/raw: 28 10 2013  8 36 12.7 90 11.1 1013.2 0.6 0.0 135 0.00 -999 -999 -999
loggereval (31.07.2014 08:57:02): illegal data record in line 96117 while reading from file /data/weather/201305/raw: 28 10 2013  8 37 12.7 90 11.1 1013.2 0.6 1.4 135 0.00 -999 -999 -999
loggereval (31.07.2014 08:57:02): illegal data record in line 96118 while reading from file /data/weather/201305/raw: 28 10 2013  8 38 12.7 90 11.1 1013.2 0.6 1.4 135 0.00 -999 -999 -999
loggereval (31.07.2014 08:57:02): illegal data record in line 96119 while reading from file /data/weather/201305/raw: 28 10 2013  8 39 12.7 90 11.1 1013.2 0.6 1.7 90 0130503212152 t9 118
loggereval (31.07.2014 08:57:05): illegal data record in line 97930 while reading from file /data/weather/201305/raw: 201305 0 0 1 0105
loggereval (31.07.2014 08:57:06): illegal data record in line 98818 while reading from file /data/weather/201305/raw: 20130531800 data2 64
loggereval (31.07.2014 08:57:06): illegal data record in line 98837 while reading from file /data/weather/201305/raw: 20130572 9821 1 10156
loggereval (31.07.2014 08:57:07): illegal data record in line 99121 while reading from file /data/weather/201305/raw: 2 rain0 0 0 5113
loggereval (31.07.2014 08:57:07): illegal data record in line 99426 while reading from file /data/weather/201305/raw: 0503234408 th0 103 92 0091
loggereval (31.07.2014 08:57:07): illegal data record in line 99446 while reading from file /data/weather/201305/raw:  data2 64
loggereval (31.07.2014 08:57:08): illegal data record in line 100352 while reading from file /data/weather/201305/raw: 20130504 8
loggereval (31.07.2014 08:57:09): illegal data record in line 100636 while reading from file /data/weather/201305/raw: 2013058 data5 9900
loggereval (31.07.2014 08:57:09): illegal data record in line 100655 while reading from file /data/weather/201305/raw: 2013054003808 wind0 315 8 3 0103
loggereval (31.07.2014 08:57:09): illegal data record in line 100940 while reading from file /data/weather/201305/raw: 204800 data5 7500
loggereval (31.07.2014 08:57:09): illegal data record in line 100959 while reading from file /data/weather/201305/raw: 28 data2 64
loggereval (31.07.2014 08:57:10): illegal data record in line 101870 while reading from file /data/weather/201305/raw: 2600
loggereval (31.07.2014 08:57:11): illegal data record in line 102154 while reading from file /data/weather/201305/raw: 0504014050 th0 100 92 0088
loggereval (31.07.2014 10:12:53): illegal data record in line 428656 while reading from file /data/weather/201309/raw: 2013091321230  data6 3900
loggereval (31.07.2014 10:12:53): illegal data record in line 428671 while reading from file /data/weather/201309/raw: 20130913212328 data6loggereval (31.07.2014 10:12:53): illegal data record in line 428679 while reading from file /data/weather/201309/raw: 201309132124 0 data6 4000
loggereval (31.07.2014 10:12:53): illegal data record in line 428693 while reading from file /data/weather/201309/raw: 2013091321242  data5 8700
loggereval (31.07.2014 10:12:53): illegal data record in line 428702 while reading from file /data/weather/201309/raw: 20130913212$01 data6 4100
loggereval (31.07.2014 10:12:53): illegal data record in line 428707 while reading from file /data/weather/201309/raw:  0130913212517 wind0 225 0 0 0112
loggereval (31.07.2014 10:12:53): illegal data record in line 428715 while reading from file /data/weather/201309/raw: 201309132125 9 data5 10200
loggereval (31.07.2014 10:12:53): illegal data record in line 428716 while reading from file /data/weather/201309/raw: 20130913212529 daloggereval (31.07.2014 10:12:53): illegal data record in line 428724 while reading from file /data/weather/201309/raw: 20130913 12600 data6 4300
loggereval (31.07.2014 10:12:53): illegal data record in line 428726 while reading from file /data/weather/201309/raw: 20130 13212600 data8 8
loggereval (31.07.2014 10:12:53): illegal data record in line 428728 while reading from file /data/weather/201309/raw: 201309132 2616 thb0 184 57 0097 9822 1 10157
loggereval (31.07.2014 10:12:53): illegal data record in line 428738 while reading from file /data/weather/201309/raw: 201309132 2628 data5 9800
loggereval (31.07.2014 10:12:53): illegal data record in line 428743 while reading from file /data/weather/201309/raw: 20130913 12700 data3 83
loggereval (31.07.2014 10:12:53): illegal data record in line 428745 while reading from file /data/weather/201309/raw: 20130913 12700 data4 0
loggereval (31.07.2014 10:12:53): illegal data record in line 428746 while reading from file /data/weather/201309/raw: 20130913212700 daloggereval (31.07.2014 10:12:53): illegal data record in line 428749 while reading from file /data/weather/201309/raw: 2013 913212700 data8 8
loggereval (31.07.2014 10:12:53): illegal data record in line 428751 while reading from file /data/weather/201309/raw: 20130913 12714 thb0 184 57 0097 9822 1 10157
loggereval (31.07.2014 10:12:53): illegal data record in line 428763 while reading from file /data/weather/201309/raw: 20130 13212728 data8 9
loggereval (31.07.2014 10:12:53): illegal data record in line 428768 while reading from file /data/weather/201309/raw: 20130913 12801 data4 0
loggereval (31.07.2014 10:14:13): illegal data record in line 498094 while reading from file /data/weather/201309/raw: 20130915232900 data1 395T�loggereval (31.07.2014 10:14:14): illegal data record in line 498378 while reading from file /data/weather/201309/raw: 201309159662700
loggereval (31.07.2014 10:14:15): illegal data record in line 499282 while reading from file /data/weather/201309/raw: 201309125 0 10060
loggereval (31.07.2014 10:14:15): illegal data record in line 499302 while reading from file /data/weather/201309/raw: 2013091a3 83
loggereval (31.07.2014 10:14:15): illegal data record in line 499585 while reading from file /data/weather/201309/raw: 20130916003410a2 74
loggereval (31.07.2014 10:14:15): illegal data record in line 499604 while reading from file /data/weather/201309/raw: 2013091 thb0 219 58 0133 9725 0 10060
loggereval (31.07.2014 10:14:15): illegal data record in line 499887 while reading from file /data/weather/201309/raw: 2013091600013 9 16 1 45
loggereval (31.07.2014 10:14:15): illegal data record in line 499906 while reading from file /data/weather/201309/raw: 2013091600130916004828 data0 45
loggereval (31.07.2014 10:14:16): illegal data record in line 500791 while reading from file /data/weather/201309/raw: 201309160126290 0139
loggereval (31.07.2014 10:14:16): illegal data record in line 500811 while reading from file /data/weather/201309/raw: 20130916012500
loggereval (31.07.2014 10:14:17): illegal data record in line 501095 while reading from file /data/weather/201309/raw: 201825
loggereval (31.07.2014 10:14:17): illegal data record in line 501115 while reading from file /data/weather/201309/raw: 201700
loggereval (31.07.2014 10:14:17): illegal data record in line 501398 while reading from file /data/weather/201309/raw: 2013015029 data2 74
loggereval (31.07.2014 10:14:17): illegal data record in line 501699 while reading from file /data/weather/201309/raw: 201309160206010130916020500 data7 100
loggereval (31.07.2014 10:14:17): illegal data record in line 501717 while reading from file /data/weather/201309/raw: 20130916020601916020629 data6 1000
loggereval (31.07.2014 10:14:18): illegal data record in line 502001 while reading from file /data/weather/201309/raw: 2013098 data3 83
loggereval (31.07.2014 10:14:18): illegal data record in line 502020 while reading from file /data/weather/201309/raw: 201309160625800
loggereval (31.07.2014 10:14:18): illegal data record in line 502605 while reading from file /data/weather/201309/raw: 2013163
loggereval (31.07.2014 10:14:19): illegal data record in line 503208 while reading from file /data/weather/201309/raw: 2013030900 data4 0
loggereval (31.07.2014 10:14:20): illegal data record in line 504109 while reading from file /data/weather/201309/raw: 20130914928 data2 74
loggereval (31.07.2014 10:14:20): illegal data record in line 504128 while reading from file /data/weather/201309/raw: 20130917 0137 9717 0 10052
loggereval (31.07.2014 10:14:20): illegal data record in line 504410 while reading from file /data/weather/201309/raw: 2013091604300
loggereval (31.07.2014 10:14:21): illegal data record in line 504429 while reading from file /data/weather/201309/raw: 2013040402 wind0 248 0 0 0147
loggereval (31.07.2014 10:14:21): illegal data record in line 504712 while reading from file /data/weather/201309/raw: 201309163 9 16 5 14
loggereval (31.07.2014 10:14:21): illegal data record in line 504731 while reading from file /data/weather/201309/raw: 201309169
loggereval (31.07.2014 10:14:21): illegal data record in line 505033 while reading from file /data/weather/201309/raw: 206043028 data3 83
loggereval (31.07.2014 10:14:22): illegal data record in line 505615 while reading from file /data/weather/201309/raw: 20te0 2013 9 16 5 51
loggereval (31.07.2014 10:14:22): illegal data record in line 505634 while reading from file /data/weather/201309/raw: 20130 0 8825
loggereval (31.07.2014 10:14:22): illegal data record in line 505938 while reading from file /data/weather/201309/raw: 20130916050
loggereval (31.07.2014 10:14:23): illegal data record in line 506240 while reading from file /data/weather/201309/raw: 201data6 5600
loggereval (31.07.2014 10:14:24): illegal data record in line 507124 while reading from file /data/weather/201309/raw: 20130916060ta3 83
loggereval (31.07.2014 10:14:24): illegal data record in line 507143 while reading from file /data/weather/201309/raw: 20130916060060145 thb0 228 58 0141 9720 0 10055
loggereval (31.07.2014 10:14:24): illegal data record in line 507426 while reading from file /data/weather/201309/raw: 201309160a6 5500
loggereval (31.07.2014 10:14:24): illegal data record in line 507445 while reading from file /data/weather/201309/raw: 201316061430 t9 175
loggereval (31.07.2014 10:14:24): illegal data record in line 507729 while reading from file /data/weather/201309/raw: 201309162614 thb0 228 58 0141 9719 0 10054
loggereval (31.07.2014 10:14:24): illegal data record in line 507748 while reading from file /data/weather/201309/raw: 201309163 83
loggereval (31.07.2014 10:14:24): illegal data record in line 507767 while reading from file /data/weather/201309/raw: 201309160625152614 thb0 228 58 0141 9719 0 10054
loggereval (31.07.2014 10:14:24): illegal data record in line 507786 while reading from file /data/weather/201309/raw: 201309163 83
loggereval (31.07.2014 10:14:24): illegal data record in line 507805 while reading from file /data/weather/201309/raw: 201309160625152614 thb0 228 58 0141 9719 0 10054
loggereval (31.07.2014 10:14:24): illegal data record in line 507824 while reading from file /data/weather/201309/raw: 201309163 83
loggereval (31.07.2014 10:14:25): illegal data record in line 507843 while reading from file /data/weather/201309/raw: 201309160625152614 thb0 228 58 0141 9719 0 10054
loggereval (31.07.2014 10:14:25): illegal data record in line 507862 while reading from file /data/weather/201309/raw: 201309163 83
loggereval (31.07.2014 10:14:25): illegal data record in line 507881 while reading from file /data/weather/201309/raw: 201309160625152614 thb0 228 58 0141 9719 0 10054
loggereval (31.07.2014 10:14:25): illegal data record in line 507900 while reading from file /data/weather/201309/raw: 201309163 83
loggereval (31.07.2014 10:14:25): illegal data record in line 507919 while reading from file /data/weather/201309/raw: 201309160625152614 thb0 228 58 0141 9719 0 10054
loggereval (31.07.2014 10:14:25): illegal data record in line 507938 while reading from file /data/weather/201309/raw: 201309163 83
loggereval (31.07.2014 10:14:25): illegal data record in line 507957 while reading from file /data/weather/201309/raw: 201309160625152614 thb0 228 58 0141 9719 0 10054
loggereval (31.07.2014 10:14:25): illegal data record in line 507976 while reading from file /data/weather/201309/raw: 201309163 83
loggereval (31.07.2014 10:14:25): illegal data record in line 507995 while reading from file /data/weather/201309/raw: 201309160625152614 thb0 228 58 0141 9719 0 10054
loggereval (31.07.2014 10:14:25): illegal data record in line 508014 while reading from file /data/weather/201309/raw: 201309163 83
loggereval (31.07.2014 10:14:25): illegal data record in line 508033 while reading from file /data/weather/201309/raw: 2013091606251599,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999
loggereval (31.07.2014 10:14:25): illegal data record in line 508034 while reading from file /data/weather/201309/raw: 11 10 2013  7  7 10.8 92 9.6 1014.7 1.2 1.7 180 0.00 -999 -999 -999#11,10,2013, 7, 7,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999
loggereval (31.07.2014 10:14:25): illegal data record in line 508035 while reading from file /data/weather/201309/raw: 11 10 2013  7  8 10.8 92 9.6 1014.7 1.2 1.7 180 0.00 -999 -999 -999#11,10,2013, 7, 8,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999
loggereval (31.07.2014 10:14:25): illegal data record in line 508036 while reading from file /data/weather/201309/raw: 11 10 2013  7  9 10.8 92 9.6 1014.7 1.2 1.7 180 0.00 -999 -999 -999#11,10,2013, 7, 9,- 0 0 0155
loggereval (31.07.2014 10:14:26): illegal data record in line 509225 while reading from file /data/weather/201309/raw: 20data4 0
loggereval (31.07.2014 10:14:26): illegal data record in line 509244 while reading from file /data/weather/201309/raw: 20130 data2 74
loggereval (31.07.2014 10:14:27): illegal data record in line 509528 while reading from file /data/weather/201309/raw: 20130916074
loggereval (31.07.2014 10:14:27): illegal data record in line 509547 while reading from file /data/weather/201309/raw: 201309160740130916074600 data7 100
loggereval (31.07.2014 10:14:27): illegal data record in line 510130 while reading from file /data/weather/201309/raw: 201ta5 13200
loggereval (31.07.2014 10:14:27): illegal data record in line 510149 while reading from file /data/weather/201309/raw: 20120130916081213 wind0 135 11 7 0171
loggereval (31.07.2014 10:14:28): illegal data record in line 510448 while reading from file /data/weather/201309/raw: 201309916082500 data8 9
loggereval (31.07.2014 10:14:28): illegal data record in line 510731 while reading from file /data/weather/201309/raw: 20130916083 10062
loggereval (31.07.2014 10:14:28): illegal data record in line 510751 while reading from file /data/weather/201309/raw: 201309160836600
loggereval (31.07.2014 10:14:28): illegal data record in line 511033 while reading from file /data/weather/201309/raw: 20130916085a6 3300
loggereval (31.07.2014 10:14:28): illegal data record in line 511052 while reading from file /data/weather/201309/raw: 2016085122 wind0 135 7 8 0170
loggereval (31.07.2014 10:14:29): illegal data record in line 511634 while reading from file /data/weather/201309/raw: 201309160
loggereval (31.07.2014 10:14:29): illegal data record in line 511653 while reading from file /data/weather/201309/raw: 2013091609153 83
loggereval (31.07.2014 10:14:30): illegal data record in line 511935 while reading from file /data/weather/201309/raw: 20130916016092900 data0 29
loggereval (31.07.2014 10:14:30): illegal data record in line 511954 while reading from file /data/weather/201309/raw: 20130916020130916093029 data8 10
loggereval (31.07.2014 10:14:30): illegal data record in line 512234 while reading from file /data/weather/201309/raw: 201309194027 thb0 258 57 0166 9725 0 10060
loggereval (31.07.2014 10:14:30): illegal data record in line 512253 while reading from file /data/weather/201309/raw: 2013091 36
loggereval (31.07.2014 10:14:31): illegal data record in line 513135 while reading from file /data/weather/201309/raw: 20130ta4 0
loggereval (31.07.2014 10:14:31): illegal data record in line 513154 while reading from file /data/weather/201309/raw: 2013002238 th0 206 74 0158
loggereval (31.07.2014 10:14:31): illegal data record in line 513455 while reading from file /data/weather/201309/raw: 201309103600 data3 83
loggereval (31.07.2014 10:14:32): illegal data record in line 514037 while reading from file /data/weather/201309/raw:  0180 9721 0 10056
loggereval (31.07.2014 10:14:32): illegal data record in line 514057 while reading from file /data/weather/201309/raw: 20 data1 43757900
loggereval (31.07.2014 10:14:32): illegal data record in line 514340 while reading from file /data/weather/201309/raw: 8 data2 74
loggereval (31.07.2014 10:14:32): illegal data record in line 514359 while reading from file /data/weather/201309/raw: 1501 data2 74
loggereval (31.07.2014 10:14:33): illegal data record in line 514941 while reading from file /data/weather/201309/raw: 20125
loggereval (31.07.2014 10:14:33): illegal data record in line 514961 while reading from file /data/weather/201309/raw: 201a7 100
loggereval (31.07.2014 10:14:34): illegal data record in line 515544 while reading from file /data/weather/201309/raw: 209 data4 0
loggereval (31.07.2014 10:14:34): illegal data record in line 515563 while reading from file /data/weather/201309/raw: 2000 data4 0
loggereval (31.07.2014 10:14:35): illegal data record in line 516746 while reading from file /data/weather/201309/raw: 20130916
loggereval (31.07.2014 10:14:35): illegal data record in line 516765 while reading from file /data/weather/201309/raw: 2013091600
loggereval (31.07.2014 10:14:36): illegal data record in line 517649 while reading from file /data/weather/201309/raw: 201309144675800
loggereval (31.07.2014 10:14:37): illegal data record in line 518254 while reading from file /data/weather/201309/raw: 2013091a7 100
loggereval (31.07.2014 10:14:37): illegal data record in line 518273 while reading from file /data/weather/201309/raw: 2013030916140425 t9 239
loggereval (31.07.2014 10:14:38): illegal data record in line 519157 while reading from file /data/weather/201309/raw: 201309161442404200 data0 95
loggereval (31.07.2014 10:14:38): illegal data record in line 519176 while reading from file /data/weather/201309/raw: 201309161442406144328 data8 9
loggereval (31.07.2014 10:14:39): illegal data record in line 519760 while reading from file /data/weather/201309/raw: 20ata6 4900
loggereval (31.07.2014 10:14:39): illegal data record in line 519779 while reading from file /data/weather/201309/raw: 20 8400
loggereval (31.07.2014 10:14:40): illegal data record in line 520361 while reading from file /data/weather/201309/raw: 2013091ta4 0
loggereval (31.07.2014 10:14:40): illegal data record in line 520380 while reading from file /data/weather/201309/raw: 2013091539 th0 188 78 0149
loggereval (31.07.2014 10:14:40): illegal data record in line 520663 while reading from file /data/weather/201309/raw: 201309161516154528 data6 0
loggereval (31.07.2014 10:14:40): illegal data record in line 520681 while reading from file /data/weather/201309/raw: 20120130916154828 data8 9
loggereval (31.07.2014 10:14:40): illegal data record in line 520964 while reading from file /data/weather/201309/raw: 20130916112 thb0 266 55 0168 9699 0 10034
loggereval (31.07.2014 10:14:40): illegal data record in line 520983 while reading from file /data/weather/201309/raw: 2013091615557900
loggereval (31.07.2014 10:14:41): illegal data record in line 521566 while reading from file /data/weather/201309/raw: 20data8 9
loggereval (31.07.2014 10:14:41): illegal data record in line 521585 while reading from file /data/weather/201309/raw: 20 0 8825
loggereval (31.07.2014 10:14:41): illegal data record in line 521869 while reading from file /data/weather/201309/raw: 2013091ata2 74
loggereval (31.07.2014 10:14:42): illegal data record in line 521888 while reading from file /data/weather/201309/raw: 2013091616382ata3 83
loggereval (31.07.2014 10:14:42): illegal data record in line 522473 while reading from file /data/weather/201309/raw: 2013091999,-999,-999,-999,-999,-999,-999,-999,-999,-999
loggereval (31.07.2014 10:14:42): illegal data record in line 522474 while reading from file /data/weather/201309/raw: 11 10 2013  7 59 11.8 93 10.7 1014.9 0.6 0.0 248 0.00 -999 -999 -999#11,10,2013, 7,59,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999
loggereval (31.07.2014 10:14:42): illegal data record in line 522475 while reading from file /data/weather/201309/raw: 11 10 2013  8  0 11.8 93 10.7 1014.9 0.6 0.0 248 0.00 -999 -999 -999#11,10,2013, 8, 0,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999,-999
loggereval (31.07.2014 10:14:42): illegal data record in line 522476 while reading from file /data/weather/201309/raw: 11 10 2013  8  1 11.8 93 10.7 1014.9 0.6 0.0 248 0.00 -999 -999 -999#11,10,2013, 8, 1,-999,-999,-999,-999,-925
loggereval (31.07.2014 10:14:43): illegal data record in line 523382 while reading from file /data/weather/201309/raw: 2013090 2013 9 16 18 44
loggereval (31.07.2014 10:14:44): illegal data record in line 523664 while reading from file /data/weather/201309/raw: 2013091ta4 0
loggereval (31.07.2014 10:14:44): illegal data record in line 523683 while reading from file /data/weather/201309/raw: 2013091ta4 0
loggereval (31.07.2014 10:14:44): illegal data record in line 523967 while reading from file /data/weather/201309/raw: 2010 30
loggereval (31.07.2014 10:14:44): illegal data record in line 524268 while reading from file /data/weather/201309/raw: 2013091618ata3 83
loggereval (31.07.2014 10:14:44): illegal data record in line 524287 while reading from file /data/weather/201309/raw: 20130916186182518 thb0 230 57 0140 9695 0 10030
loggereval (31.07.2014 10:14:45): illegal data record in line 524569 while reading from file /data/weather/201309/raw: 2013 data6 5200
loggereval (31.07.2014 10:14:45): illegal data record in line 524870 while reading from file /data/weather/201309/raw: 201309161 9 16 19 48
loggereval (31.07.2014 10:14:45): illegal data record in line 524889 while reading from file /data/weather/201309/raw: 201309161a8 9
loggereval (31.07.2014 10:14:45): illegal data record in line 525172 while reading from file /data/weather/201309/raw: 20130916190130916190100 data4 0
loggereval (31.07.2014 10:14:46): illegal data record in line 525774 while reading from file /data/weather/201309/raw: nj/�#���35�o�a��Q�`���d0, ��,�!��I��d0C����&�9����k��7}�����m�z���z�(z��\o�(����W�6193028 data0 341
loggereval (31.07.2014 10:14:46): illegal data record in line 526057 while reading from file /data/weather/201309/raw: 20130951 th0 148 91 0133
loggereval (31.07.2014 10:14:46): illegal data record in line 526077 while reading from file /data/weather/201309/raw: 201309ata3 83
loggereval (31.07.2014 10:14:47): illegal data record in line 526360 while reading from file /data/weather/201309/raw: 20130916195data7 100
loggereval (31.07.2014 10:14:47): illegal data record in line 526379 while reading from file /data/weather/201309/raw: 5628 data5 9900
loggereval (31.07.2014 10:14:47): illegal data record in line 526661 while reading from file /data/weather/201309/raw: 20 data1 47033800
loggereval (31.07.2014 10:14:47): illegal data record in line 526680 while reading from file /data/weather/201309/raw: 20ata0 44
loggereval (31.07.2014 10:14:47): illegal data record in line 526982 while reading from file /data/weather/201309/raw: 201316202228 data3 83
loggereval (31.07.2014 10:14:50): illegal data record in line 528765 while reading from file /data/weather/201309/raw: 201309162139ata7 100
loggereval (31.07.2014 10:14:50): illegal data record in line 528784 while reading from file /data/weather/201309/raw: 028 data5 13200
loggereval (31.07.2014 10:14:50): illegal data record in line 529065 while reading from file /data/weather/201309/raw: 2ta0 74
loggereval (31.07.2014 10:14:50): illegal data record in line 529084 while reading from file /data/weather/201309/raw: 20 07 0 8915
loggereval (31.07.2014 10:14:50): illegal data record in line 529367 while reading from file /data/weather/201309/raw: 20131 9677 0 10012
loggereval (31.07.2014 10:14:50): illegal data record in line 529387 while reading from file /data/weather/201309/raw: ta1 47744600
loggereval (31.07.2014 10:14:51): illegal data record in line 529670 while reading from file /data/weather/201309/raw: 2013091622 wind0 113 0 0 0142
loggereval (31.07.2014 10:14:51): illegal data record in line 529690 while reading from file /data/weather/201309/raw: 20130916222 74
loggereval (31.07.2014 10:14:51): illegal data record in line 529972 while reading from file /data/weather/201309/raw: 2013091 data7 100
loggereval (31.07.2014 10:16:18): illegal data record in line 596849 while reading from file /data/weather/201309/raw: 20130T�loggereval (31.07.2014 10:16:18): illegal data record in line 597132 while reading from file /data/weather/201309/raw: 2ta8 9
loggereval (31.07.2014 10:16:18): illegal data record in line 597151 while reading from file /data/weather/201309/raw: 20130a6 4000
loggereval (31.07.2014 10:16:20): illegal data record in line 598036 while reading from file /data/weather/201309/raw: 20130918233
loggereval (31.07.2014 10:16:20): illegal data record in line 598055 while reading from file /data/weather/201309/raw: 20130918233918234000 thb0 189 58 0105 9670 7 10005
loggereval (31.07.2014 10:16:20): illegal data record in line 598639 while reading from file /data/weather/201309/raw: 2429 data0 59
loggereval (31.07.2014 10:16:20): illegal data record in line 598658 while reading from file /data/weather/201309/raw: 2 data0 97
loggereval (31.07.2014 10:16:21): illegal data record in line 598943 while reading from file /data/weather/201309/raw: 208 data5 10300
loggereval (31.07.2014 10:16:21): illegal data record in line 598962 while reading from file /data/weather/201309/raw: 20 data4 0
loggereval (31.07.2014 10:16:21): illegal data record in line 599244 while reading from file /data/weather/201309/raw: 0 0 9163
loggereval (31.07.2014 10:16:21): illegal data record in line 599263 while reading from file /data/weather/201309/raw: n0 0 0 9163
loggereval (31.07.2014 10:16:21): illegal data record in line 599567 while reading from file /data/weather/201309/raw: 20130919004220919004500 data2 74
loggereval (31.07.2014 10:16:22): illegal data record in line 600452 while reading from file /data/weather/201309/raw: 20130915 9700
loggereval (31.07.2014 10:16:22): illegal data record in line 600471 while reading from file /data/weather/201309/raw: 2013091012400 wind0 248 0 1 0111
loggereval (31.07.2014 10:16:23): illegal data record in line 600755 while reading from file /data/weather/201309/raw: 209013400 data3 83
loggereval (31.07.2014 10:16:23): illegal data record in line 600774 while reading from file /data/weather/201309/raw: 201ata0 20
loggereval (31.07.2014 10:16:23): illegal data record in line 601058 while reading from file /data/weather/201309/raw: 201309190114833 wind0 338 0 1 0111
loggereval (31.07.2014 10:16:23): illegal data record in line 601078 while reading from file /data/weather/201309/raw: 201309190174
loggereval (31.07.2014 10:16:23): illegal data record in line 601379 while reading from file /data/weather/201309/raw: 20 0 0 9163
loggereval (31.07.2014 10:16:24): illegal data record in line 601663 while reading from file /data/weather/201309/raw: 201309190215220130919021500 data4 0
loggereval (31.07.2014 10:16:24): illegal data record in line 601681 while reading from file /data/weather/201309/raw: 20130919021520130919021628 data2 74
loggereval (31.07.2014 11:02:03): illegal data record in line 208476 while reading from file /data/weather/201312/raw: 20131207062529 rain0 0 0 10143loggereval (31.07.2014 11:02:03): illegal data record in line 208491 while reading from file /data/weather/201312/raw: 201312 7062628 data0 42
loggereval (31.07.2014 11:02:03): illegal data record in line 208496 while reading from file /data/weather/201312/raw: 2013120702628 data5 9900
loggereval (31.07.2014 11:02:03): illegal data record in line 208499 while reading from file /data/weather/201312/raw:  0131207062701 data0 43
loggereval (31.07.2014 11:02:03): illegal data record in line 208504 while reading from file /data/weather/201312/raw: 201!1207062701 data5 8900
loggereval (31.07.2014 11:02:03): illegal data record in line 208510 while reading from file /data/weather/201312/raw: 20131207062727 th0 -5 81 -034loggereval (31.07.2014 11:02:03): illegal data record in line 208517 while reading from file /data/weather/201312/raw: 201!1207062729 data4 0
loggereval (31.07.2014 11:02:03): illegal data record in line 208522 while reading from file /data/weather/201312/raw: 201312070 2800 data1 53802100
loggereval (31.07.2014 11:02:03): illegal data record in line 208523 while reading from file /data/weather/201312/raw: 2013120706200 data3 83
loggereval (31.07.2014 11:02:03): illegal data record in line 208526 while reading from file /data/weather/201312/raw: 2013 207062800 data5 7400
loggereval (31.07.2014 11:02:03): illegal data record in line 208540 while reading from file /data/weather/201312/raw: 2013 207062828 data4 0
loggereval (31.07.2014 11:02:03): illegal data record in line 208548 while reading from file /data/weather/201312/raw: 201312070629 0 data4 0
loggereval (31.07.2014 11:02:03): illegal data record in line 208554 while reading from file /data/weather/201312/raw: 20131207062925 thb0 132 38 -008 9834 3 10169loggereval (31.07.2014 11:02:03): illegal data record in line 208558 while reading from file /data/weather/201312/raw: 20131207 62928 data0 8
loggereval (31.07.2014 11:02:03): illegal data record in line 208559 while reading from file /data/weather/201312/raw: 20131207062928 daloggereval (31.07.2014 11:02:03): illegal data record in line 208562 while reading from file /data/weather/201312/raw: 201 1207062928 data0 0
loggereval (31.07.2014 11:02:03): illegal data record in line 208565 while reading from file /data/weather/201312/raw: 201312070$2928 data8 11
loggereval (31.07.2014 11:02:03): illegal data record in line 208573 while reading from file /data/weather/201312/raw: 2 131207063000 data7 100
loggereval (31.07.2014 11:02:03): illegal data record in line 208576 while reading from file /data/weather/201312/raw: 20131207063003 thb0 132 38 -008 9834 3 10169loggereval (31.07.2014 11:02:03): illegal data record in line 208577 while reading from file /data/weather/201312/raw: 20131207063023 wind0 270 48 21 -0loggereval (31.07.2014 11:02:03): illegal data record in line 208582 while reading from file /data/weather/201312/raw: 20 31207063029 data3 83
loggereval (31.07.2014 11:02:03): illegal data record in line 208587 while reading from file /data/weather/201312/raw: 2013120 063029 data8 11
loggereval (31.07.2014 11:02:03): illegal data record in line 208588 while reading from file /data/weather/201312/raw: 20131207063100 loggereval (31.07.2014 11:02:03): illegal data record in line 208592 while reading from file /data/weather/201312/raw: 201312070 3100 data4 0
loggereval (31.07.2014 11:02:03): illegal data record in line 208601 while reading from file /data/weather/201312/raw: 201312070 3122 t9 -11
loggereval (31.07.2014 11:02:03): illegal data record in line 208611 while reading from file /data/weather/201312/raw: 20131207063 00 data0 61
loggereval (31.07.2014 11:02:03): illegal data record in line 208615 while reading from file /data/weather/201312/raw: 20131 07063200 data4 0
loggereval (31.07.2014 11:02:03): illegal data record in line 208634 while reading from file /data/weather/201312/raw: 20131207 63300 data0 22
loggereval (31.07.2014 11:02:03): illegal data record in line 208648 while reading from file /data/weather/201312/raw: 2013120706332  rain0 0 0 10143
loggereval (31.07.2014 11:02:03): illegal data record in line 208652 while reading from file /data/weather/201312/raw:  0131207063329 data2 79
loggereval (31.07.2014 11:02:03): illegal data record in line 208653 while reading from file /data/weather/201312/raw: 20131207loggereval (31.07.2014 11:02:03): illegal data record in line 208659 while reading from file /data/weather/201312/raw:  0131207063400 data3 83
loggereval (31.07.2014 11:02:03): illegal data record in line 208662 while reading from file /data/weather/201312/raw: 20131207063400 data5 7400loggereval (31.07.2014 11:02:03): illegal data record in line 208664 while reading from file /data/weather/201312/raw: 201312070634 0 data8 11
loggereval (31.07.2014 11:02:03): illegal data record in line 208673 while reading from file /data/weather/201312/raw: 201312loggereval (31.07.2014 11:02:04): illegal data record in line 208675 while reading from file /data/weather/201312/raw: 20131207063428 data4 0loggereval (31.07.2014 11:02:04): illegal data record in line 208676 while reading from file /data/weather/201312/raw: 20131 07063428 data6 900
loggereval (31.07.2014 11:02:04): illegal data record in line 208689 while reading from file /data/weather/201312/raw: 2loggereval (31.07.2014 11:02:04): illegal data record in line 208699 while reading from file /data/weather/201312/raw: 201 1207063528 data6 1000
loggereval (31.07.2014 11:02:04): illegal data record in line 208700 while reading from file /data/weather/201312/raw: 2013120703528 data8 11
loggereval (31.07.2014 11:02:04): illegal data record in line 208704 while reading from file /data/weather/201312/raw: 201 1207063600 data2 79
loggereval (31.07.2014 11:02:04): illegal data record in line 208706 while reading from file /data/weather/201312/raw: 20131207063600 data5loggereval (31.07.2014 11:02:04): illegal data record in line 208708 while reading from file /data/weather/201312/raw:  0131207063600 data7 100
loggereval (31.07.2014 11:02:04): illegal data record in line 208709 while reading from file /data/weather/201312/raw: 2013120 063600 data8 11
loggereval (31.07.2014 11:02:04): illegal data record in line 208714 while reading from file /data/weather/201312/raw: 201312070636loggereval (31.07.2014 11:02:04): illegal data record in line 208716 while reading from file /data/weather/201312/raw: 20131207063629 data0 32loggereval (31.07.2014 11:02:04): illegal data record in line 208730 while reading from file /data/weather/201312/raw: 2013120706370loggereval (31.07.2014 11:02:04): illegal data record in line 208735 while reading from file /data/weather/201312/raw: 2013120706371! wind0 315 64 27 -063
loggereval (31.07.2014 11:02:04): illegal data record in line 208736 while reading from file /data/weather/201312/raw: 201312070 3715 t9 -16
Napajedlaci.cz is very good weather station in Czech republic neer town Zlin.
Re: meteohub.log
corrupted file system. What platform? NSLU2?
Napajedlaci.cz
Re: meteohub.log
Sheevaplug.
Unfortunately, the problem with the migration of data from the SheevaPlug RPI probably did not take place cool. Each restart recalculate the data and graphs are reset (RPI so keep running unnecessarily at 100%.
Can this be solved somehow?
Data: 1525MB z 5483MB použito (27%)
