Datalogger stability issue **solved**
assenzuid
Post by assenzuid »
Since the latest MeteoBridge version I have some stability issues, my Davis Envoy datalogger won't connect after a reboot or lost his connection after a few hours when it is correctly working.
To get it work i must reboot the device more than once, or change the station type a few times.
Most frustrating is that the device lost his connection after a few hours of working correctly.
System LOG:
MeteoBridge 2.3 (2598)
test5m (14.08.2014 08:50:02): weathernet daemon stalled, will be restarted now
wnetd (14.08.2014 08:50:02): process started.
test5m (14.08.2014 08:50:02): logger stalled, will be restarted now
logger (14.08.2014 08:50:04): Historical data loaded (22 records).
logger (14.08.2014 08:50:04): data logger (version 4.9za, build 2598) started.
logger (14.08.2014 08:50:07): connect station 0 (Vantage via USB serial).
logger (14.08.2014 08:51:43): open named pipe "/dev/meteobridge" failed: No such device or address
logger (14.08.2014 08:51:47): parent process received update persist db signal (17).
logger (14.08.2014 08:51:47): Historical data loaded (22 records).
logger (14.08.2014 08:51:47): data logger (version 4.9za, build 2598) started.
logger (14.08.2014 08:51:49): connect station 0 (Vantage via USB serial).
logger (14.08.2014 08:51:50): open named pipe "/dev/meteobridge" failed: No such device or address
logger (14.08.2014 08:52:17): Historical data loaded (22 records).
logger (14.08.2014 08:52:17): data logger (version 4.9za, build 2598) started.
logger (14.08.2014 08:52:18): connect station 0 (Vantage via USB serial).
logger (14.08.2014 08:52:47): Historical data loaded (22 records).
logger (14.08.2014 08:52:47): data logger (version 4.9za, build 2598) started.
logger (14.08.2014 08:52:48): connect station 0 (Vantage via USB serial).
logger (14.08.2014 08:53:17): Historical data loaded (22 records).
logger (14.08.2014 08:53:17): data logger (version 4.9za, build 2598) started.
logger (14.08.2014 08:53:18): connect station 0 (Vantage via USB serial).
logger (14.08.2014 08:53:47): Historical data loaded (22 records).
logger (14.08.2014 08:53:47): data logger (version 4.9za, build 2598) started.
logger (14.08.2014 08:53:48): connect station 0 (Vantage via USB serial).
logger (14.08.2014 08:54:17): Historical data loaded (22 records).
logger (14.08.2014 08:54:17): data logger (version 4.9za, build 2598) started.
logger (14.08.2014 08:54:18): connect station 0 (Vantage via USB serial).
logger (14.08.2014 08:54:47): Historical data loaded (22 records).
logger (14.08.2014 08:54:47): data logger (version 4.9za, build 2598) started.
logger (14.08.2014 08:54:48): connect station 0 (Vantage via USB serial).
Live data tab
Data Logger Failure
Data logger does not provide data. Please check that station settings are correct.
Kind regards,
assenzuid
Re: Datalogger stability issue.
Post by assenzuid »
Strange, I just removed one Push services (email) and system is direct up & running.
I have a few Push Services running (around 15), removed the 16th and it looks that it is running fine again.
Kind regards,
josecmorales
Post by josecmorales »
Has the same issues and fix it in the same way!!!!
@climaguayana
15 push services? you are pushing hard... this is a small tiny box, have some mercy... ;-)
assenzuid
Post by assenzuid »
Okay, I will have some mercy :wink:
What are the further plans for Meteobridge?
New hardware support (with more power and possibilities)
I love this piece of software and the possibilities.
