actual_rain0_rate_mm **solved**
Guten Abend,
vielleicht habe ich ein Verständigungsproblem.
Die Variable "actual_rain0_rate_mm" sollte doch die aktuelle Regenrate ausgeben, oder?
Bei mir wird die letzte Regenrate über Stunden angezeigt.
Gruß Wilfried
Re: actual_rain0_rate_mm
Welche Wetterstation?
Sorry, eine VantagePro2Plus wireless mit Meteostick.
Gruß Wilfried
Gruß Wilfried
Gruß Wilfried
Hallo Boris,
letzter Regen Gestern vor über 15 Stunden.
In der Variable actual_rain0_rate_mm steht noch 5.6 mm/h
Ist das so gewollt?
Ist das so gewollt?
Gruß Wilfried
Das ist ein Bug in dere Regenratenberechnung. Ist mit dem letzten 5.0 Update gefixt.
Re: actual_rain0_rate_mm **solved**
Hi all, I hope I found the right topic to place my question.
I'm running a Davis VP2 with the "weatherboxx" (TL-MR3020) and meteostick/meteoplug since July this year. I bought the weatherboxx/meteostick from meteo.cc as a pre-installed system and it works fine so far. I really love this very smooth and effective solution!
As one of the very few minor flaws, I'm also suffering from the invalid "actual_rain0_rate" values (showing values >0mm/h for hours after rainfall), as described here.
I tried to read all Forum / wiki / Getting Started pages around meteohub /meteoplug to figure out how I could upgrade to a new version that resolves this issue, but I could not find or understand the answer.
Currently I'm running the meteoplug Client (TL-MR3020) with "FW-Version 1.1" and "SW-Version: 2.2 (Build 4343)". The luci Interface tells me "OpenWrt Barrier Breaker r34065 / LuCI Trunk (trunk+svn9415)".
The MeteoPlug System Information says "4.9 (Build 7093)" but I guess that's the meteoplug server side that I cannot influence.
Any information about how to upgrade what and where in general would be much appreciated (so I learn this also for future upgrades). Any help especially for getting rid of the invalid rain rate values would be fantastic.
Thank you very much in advance!
I realize that you are running a Meteoplug client. The newest code has not
been released for the Meteoplug clients, just for Meteobridge.
I will do on soon.
I will do on soon.
I just released the new code, could you please powercycle your Meteoplug client
and check if client is now on SW 2.3 and logger reported on Meteoplug server on 5.0?
Great News, thank you very much!
I added some "things" (issues?) that I noticed after reboot to the corresponding meteoplug.com thread.
To avoid further double-postings that I introduced, I suggest to continue the specific discussion there:
http://forum.meteoplug.com/viewtopic.php?f=7&p=882#p882
Thanks again!
Thanks again!
I have a MeteoHub on RPI running v5 of the software reading from a MeteoStick-connected Davis VP2 and experiencing the same type of problem where the reported rain rate continues to be "stuck" on a non-zero value. This morning we had a light rain for a short period of time and as of this evening, the raw data for rain0 is still displaying a .02 in/hr rate -- long, long after it has ceased raining.
Here is the complete rain event from today. Note that it continues to show "05" (.5 mm/hr) rate even now...
Is there anything else I can provide to help solve this problem?
mark
20141006123613 rain0 0 0 620
20141006123623 rain0 0 0 620
20141006123633 rain0 0 0 620
20141006123643 rain0 0198 0 622
20141006123704 rain0 0198 0 622
20141006123714 rain0 0198 0 622
20141006123724 rain0 0198 0 622
20141006123735 rain0 0198 0 622
20141006123745 rain0 0198 0 622
20141006123755 rain0 0198 0 622
20141006123805 rain0 0198 0 622
20141006123816 rain0 0198 0 622
20141006123826 rain0 0198 0 622
20141006123836 rain0 0198 0 622
20141006123846 rain0 0198 0 622
20141006123857 rain0 0198 0 622
20141006123907 rain0 0198 0 622
20141006123917 rain0 0198 0 622
20141006123927 rain0 0198 0 622
20141006123938 rain0 0157 0 625
20141006123948 rain0 0157 0 625
20141006123958 rain0 0157 0 625
20141006124008 rain0 0157 0 625
20141006124019 rain0 0157 0 625
20141006124029 rain0 0157 0 625
20141006124039 rain0 0157 0 625
20141006124049 rain0 0157 0 625
20141006124100 rain0 0157 0 625
20141006124110 rain0 0157 0 625
20141006124120 rain0 0157 0 625
20141006124130 rain0 0157 0 625
20141006124141 rain0 0157 0 625
20141006124151 rain0 0157 0 625
20141006124211 rain0 0157 0 625
20141006124222 rain0 0112 0 627
20141006124232 rain0 0112 0 627
20141006124242 rain0 0112 0 627
20141006124252 rain0 0112 0 627
20141006124303 rain0 0112 0 627
20141006124313 rain0 0112 0 627
20141006124323 rain0 0112 0 627
20141006124333 rain0 0386 0 630
20141006124344 rain0 0386 0 630
20141006124354 rain0 0386 0 630
20141006124414 rain0 0386 0 630
20141006124425 rain0 0386 0 630
20141006124435 rain0 0386 0 630
20141006124445 rain0 0254 0 632
20141006124455 rain0 0254 0 632
20141006124506 rain0 0254 0 632
20141006124516 rain0 0254 0 632
20141006124526 rain0 0457 0 635
20141006124536 rain0 0457 0 635
20141006124547 rain0 0457 0 635
20141006124557 rain0 0457 0 635
20141006124607 rain0 0457 0 635
20141006124617 rain0 0457 0 635
20141006124628 rain0 0457 0 635
20141006124638 rain0 0381 0 638
20141006124648 rain0 0381 0 638
20141006124658 rain0 0381 0 638
20141006124709 rain0 0381 0 638
20141006124719 rain0 0381 0 638
20141006124729 rain0 0305 0 640
20141006124739 rain0 0305 0 640
20141006124750 rain0 0305 0 640
20141006124800 rain0 0457 0 643
20141006124810 rain0 0457 0 643
20141006124820 rain0 0305 0 645
20141006124831 rain0 0305 0 645
20141006124841 rain0 0305 0 645
20141006124851 rain0 0457 0 648
20141006124912 rain0 0457 0 648
20141006124922 rain0 0457 0 648
20141006124932 rain0 0457 0 648
20141006124942 rain0 0457 0 648
20141006124953 rain0 0457 0 648
20141006125003 rain0 0254 0 650
20141006125013 rain0 0254 0 650
20141006125023 rain0 0254 0 650
20141006125034 rain0 0254 0 650
20141006125044 rain0 0254 0 650
20141006125054 rain0 0254 0 650
20141006125104 rain0 0254 0 650
20141006125115 rain0 0254 0 650
20141006125125 rain0 0254 0 650
20141006125135 rain0 0297 0 653
20141006125145 rain0 0297 0 653
20141006125156 rain0 0297 0 653
20141006125206 rain0 0297 0 653
20141006125216 rain0 0297 0 653
20141006125226 rain0 0297 0 653
20141006125237 rain0 0297 0 653
20141006125247 rain0 0297 0 653
20141006125257 rain0 0297 0 653
20141006125307 rain0 0297 0 653
20141006125318 rain0 0297 0 653
20141006125328 rain0 0297 0 653
20141006125338 rain0 0297 0 653
20141006125348 rain0 0137 0 655
20141006125359 rain0 0137 0 655
20141006125409 rain0 0137 0 655
20141006125429 rain0 0137 0 655
20141006125440 rain0 0137 0 655
20141006125450 rain0 0137 0 655
20141006125500 rain0 0137 0 655
20141006125510 rain0 0137 0 655
20141006125521 rain0 0137 0 655
20141006125531 rain0 0137 0 655
20141006125541 rain0 0244 0 658
20141006125551 rain0 0244 0 658
20141006125602 rain0 0244 0 658
20141006125612 rain0 0244 0 658
20141006125632 rain0 0244 0 658
20141006125643 rain0 0244 0 658
...Trimmed Events...
20141006135529 rain0 0244 0 658
20141006135539 rain0 0244 0 658
20141006135549 rain0 0244 0 658
20141006135559 rain0 0244 0 658
20141006135610 rain0 0244 0 658
20141006135620 rain0 0244 0 658
20141006135630 rain0 0244 0 658
20141006135651 rain0 0244 0 658
20141006135701 rain0 0244 0 658
20141006135711 rain0 0244 0 658
20141006135721 rain0 0244 0 658
20141006135732 rain0 0244 0 658
20141006135742 rain0 0244 0 658
20141006135752 rain0 0244 0 658
20141006135802 rain0 0244 0 658
20141006135813 rain0 0244 0 658
20141006135823 rain0 0244 0 658
20141006135833 rain0 05 0 660
20141006135843 rain0 05 0 660
20141006135854 rain0 05 0 660
20141006135904 rain0 05 0 660
20141006135924 rain0 05 0 660
20141006135935 rain0 05 0 660
20141006135945 rain0 05 0 660
20141006135955 rain0 05 0 660
20141006140005 rain0 05 0 660
20141006140016 rain0 05 0 660
20141006140026 rain0 05 0 660
mark
There have been changes on 5.0 software version. Please use "update (auto)" again and check if you still have this artifact.
Unfortunately yes, I am still seeing this issue of a "stuck" rain rate value (in this morning's case > 24 hours after the last rain fall).
Meteohub v5.0 Build 50 on RPI:
20141011091158 rain0 071 0 213
20141011091208 rain0 071 0 213
20141011091229 rain0 086 0 216
20141011091239 rain0 086 0 216
20141011091249 rain0 086 0 216
20141011091259 rain0 086 0 216
20141011091310 rain0 086 0 216
20141011091320 rain0 086 0 216
20141011091330 rain0 086 0 216
20141011091340 rain0 086 0 216
20141011091351 rain0 086 0 216
20141011091401 rain0 086 0 216
20141011091411 rain0 086 0 216
20141011091421 rain0 086 0 216
20141011091432 rain0 086 0 216
20141011091442 rain0 086 0 216
20141011091452 rain0 086 0 216
20141011091502 rain0 086 0 216
20141011091513 rain0 086 0 216
20141011091523 rain0 086 0 216
20141011091533 rain0 086 0 216
20141011091543 rain0 086 0 216
20141011091554 rain0 086 0 216
20141011091604 rain0 086 0 216
20141011091614 rain0 081 0 218
20141011091624 rain0 081 0 218
20141011091635 rain0 081 0 218
20141012121250 rain0 081 0 218
20141012121310 rain0 081 0 218
20141012121321 rain0 081 0 218
20141012121331 rain0 081 0 218
20141012121341 rain0 081 0 218
20141012121351 rain0 081 0 218
20141012121402 rain0 081 0 218
20141012121412 rain0 081 0 218
20141012121422 rain0 081 0 218
20141012121432 rain0 081 0 218
20141012121443 rain0 081 0 218
20141012121503 rain0 081 0 218
ok, will work on this.
I'm seeing this too. Light rain this morning, and MeteoHub thinks it's been raining all day.
I am running 5.0 on a DC01. I "updated" to 5.0 again today, but that did not help. It's still reporting rain.
which station are you using?
