Rasberry PI B und Huger WMR 928 Anleitung
kannschonsein
Re: Rasberry PI B und Huger WMR 928 Anleitung
Post by kannschonsein »
Hi there,
where can I change the background image of YoWindow 7 day forecast graphics?
in the file, wsDashYowindow.php I can not do the .
I also do not find where I can change the Yahoo Forcast ... there is still
Forcast for Leuven - Belgium
Ideea?
best regards herbert
kannschonsein wrote:Hi there,
In the script weather2/wsDashYowindow.php
The 4 different backgrounds are at line 32-35
#$yoLandscape	= 'seaside';            // select the landscape by removing the commment mark # at one landscape  only
$yoLandscape	= 'oriental';           // put the comment mark # at the unwanted landscapes
#$yoLandscape	= 'village';
#$yoLandscape	= 'airport';
You comment all lines you do no want with a # on the first position
The background you want to have should have NO # on the first position
At the moment the $yoLandscape = 'oriental'; is your choice
I also do not find where I can change the Yahoo Forcast ... there is still Forcast for Leuven - Belgium
Ideea?
http://wiki.leuven-template.eu/doku.php ... irst#yahoo
Which tells you to go to
==> https://weather.yahoo.com/germany/baden ... nn-658506/
if that is the correct Heilbronn
==> copy 658506 to your wsSettings.php
Succes, Wim
kannschonsein
hello wim,
The Warning frame "No particular awareness of the weather is required. There are no Weather-warnings"
can I use the frame separately?
kannschonsein wrote:hello wim,
It is not really a frame but a separate script which can be used on a site, so also at yours.
There are hundreds of users of this script on all kind of PHP/HTML websites.
Examples, download AND extensive documentation on http://www.weerstation-leuven.be/demowa ... arning.php
Succes, Wim
kannschonsein
Hello wim,
I think the page is now ready.
www.heilbronner-wetter.de
Once again many thanks for your help
greeting herbert
