I note that a new feature allowing one to select which sensors report data to connected services. The example in the wiki shows that sensors in green type are primary and sensors that are yellow can be selected to be primary.
All but one of my sensors are colored orange and the exception is colored white. Click on the sensor name elicits no response. If someone could explain what is going on (and perhaps add this to the wiki), I would be most appreciative.
Davis Vantage Pro2 sensors connected wirelessly to a Vantage Pro2 console connected to Meteobridge software installed on a TP-Link TPMR3040.
Regarding New Feature "Primary Sensors"
Re: Regarding New Feature "Primary Sensors"
You have a preliminary version loaded. We changed that to the new feature set.
Please just reboot your Meteobridge and colors will be fine
Of course. I forgot the primary rule; when in doubt, reboot!
yes, sorry... we are pushing out new release on a tight schedule... true devops
Is there no way to make this work to totally remove the extraneous sensors like the Outdoor #7 from my Acurite?
The is no feature to suppress a certain sensors from being listed at all.
