Email send Error...
crazyace
Email send Error...
Post by crazyace »
My email status for my "push alarms" started showing an error in the last couple of days. I get the "Error: msmtp: network read error: the operation timed out" message however when I click "test" in the email section of the "push services" all works fine. What could be causing this error when the email seems to work fine when using the test button?
Meteobridge Email Issue 02242015.jpg (74.56 KiB) Viewed 3858 times
holgerwag
Re: Email send Error...
Post by holgerwag »
i and some other users got the same problem since i updated to version 5.0d (from 4.9w)
currently there is no solution
which version do you have installed?
crazyace
Post by crazyace »
I am running Meteobridge 2.5 (Feb 8 2015, build 5958), FW 1.3 on a D-Link DIR-505L router.
I don't believe that this is a Meteobridge issue, but some networking or email provider problems.
holgerwag
Post by holgerwag »
Sorry, my problem is depending meteohub not meteobridge
albertquiles
Post by albertquiles »
I've been having the same problem since updating to Meteobridge 2.5.
