PI B+ NET MAP WINDOWS
Chill
Post by Chill »
I'm trying to setup a PI B+.
It runs from browser but I an't access it through Windows Explorer in order to net map public folder, as I did with NSLU2.
I get prompted with user and password but I don't know what to enter as meteohub meteohub fails.
Anyone can put some light on it?
TIA,
Chill
Chill
Re: PI B+ NET MAP WINDOWS
Post by Chill »
Hi there..
Is it life in the forum?
I thought it was a very elemental question :shock:
Anyone has mapped /public folder from a Windos XP pro?
Any ideas?
Chill
Yes there is life, but it looks no-one is facing this issue.
Just mounting it as a network device and making sure the workgroup
is matching is all it needs... user meteohub, password meteohub.
Are you familiar with windows networking? workgroups? etc?
Chill
Post by Chill »
Hi Boris.
After reading your post I realized I've forgotten to change the Group name. I've it already working!
I'll try to make it with the new PI. Let's evolve!
Chill
Chill
Post by Chill »
Hi there,
I use to access \public\uploads folder with NSLU2 but it says now this folder doesn't exist or it prompts for a different user and password.
It has changed? Or I need to provide different info ?
TIA,
Chill
Pc network user and password is always meteohub.
Chill
Post by Chill »
Hi Boris,
Still, has anything changed on having access to \public\uploads folder?
I can't access with RPI buty I can with NSLU2...
TIA,
Chill
Can you please provide a screen dump what you entered and how the error message looks like?
I tried with my RPI2 and it works flawless.
Chill
Post by Chill »
Hi Boris,
Here it's the picture showing the message I told in my previous message:
"Acceso denegado" means "Access denied"
It prompts you to try to log in as Administrator, but no success in doing it!
TIA,
wfpost
Post by wfpost »
could be that your m: drive is already mapped with Explorer. And Windows can map one resource only once!
I would try to disconnect the current mappings. Best Methode to check is using Command prompt and command NET USE
Chill
Post by Chill »
Hi wfpost,
Not really, in fact I'm not trying to map it... While browsing M: (\public) folder you see the subfolders and the only one I can't access is \uploads.
Thanks anyway,
Chill
peteroi
Post by peteroi »
Hi Chill,
uploads and lost&found is not accessible, only by the system itself.
So this behaviour is totally normal.
If you need to find the uploaded data, you have to check "local copy in /public/myweb/uploads" in graphics upload page...
BR Peter
Chill
Post by Chill »
Hi Peter,
Thanks for your answer.
Although it works, as a workaround, it must be a change from NSLU2 behavior where I can browse Uploads folder flawlessly.
Anyway, it rocks!
Have a nice day!
Chill
