Is there a simple way to get the Meteohub version from a command line (ssh)?
I grep'ed /etc/* and /home/meteohub/* but could not find anything.
How do I get the Meteohub version from a command line?
Re: How do I get the Meteohub version from a command line?
/srv/www/cgi-bin/meteohub.cgi | grep "MeteoHub:" | awk '{print $2}'
- YJB
Or if you want to go more fancy:
mh_version=`wget -q -O - "http://localhost/meteograph.cgi?text=actual_system_version_text"`
mh_build=`wget -q -O - "http://localhost/meteograph.cgi?text=actual_system_build_num"`
echo $mh_version" "$mh_build
Thanks. These both seem to work.
