Hello
Precipitation in meteobrige may changed manualy, but the manual input is incorrect. if you alter it then appears mm in inches and inches in mm.
This count for day,month,year and all record.
Bug in meteobridge **solved**
Re: Bug in meteobridge
There is no bug found, you must enter one value, mm or inch in the field, and the meteorological bridge complements the other value.
