a bad boot code that will block them from booting correctly next time. The bug has been solved, but impacted
Meteobridges will need a manual intervention to come up again. This can be done in 3 ways.
1) Put this file onto a FAT formatted USB stick, stick it into your Meteobridge and power-cycle
the Meteobridge: http://tau.meteobridge.com/files/rescue (file must be named "rescue" on the USB stick)
Meteobridge should come up fine. When you can reach the normal web interface,
you are done and you can remove the USB stick. It is no longer needed, system has fixed itself.
2) Login via ssh (putty or any other ssh clients work fine). User is "root", password is "meteobridge"
(or the one you changed it to). Now give these two commands (both commands will take some time,
second will throw lots of messages/warnings but just ignore):
/root/start download.meteobridge.com bridge.meteohub.com
/root/start.sh
3) Flashing firmware again will also fix is, but by this you loose your settings. It is the last way out,
I don't think you have to go that path and recommend 1) and 2) instead.
I am sorry for the hick-up but hope you will not have too much hassle applying the easy fix as explained above.
If you need more support on applying this bug fix, please contact "info(at)meteobridge.com".
