I want to migrade my Meteohub from NLSU2 to RPI 2.
So i downloaded the image http://www.meteohub.de/files/mhrpi-v5.0f.rar and install it to the Micro-SD.
The RSPI answered the Ping-Command successful.
But a login is not working:
Browser: User: meteohub and Password: meteohub is not working
SSH: User:root Password: meteohub is also not working
Is there an new default Password in the Image ?
Greets
Carlo
No Login on a fresh Install
Re: No Login on a fresh Install
No, should do. Did you read the IP from the Meteohub LED blinks?
My guess is that you are trying to login on a false device.
Is is the right computer. The default IP is 192.168.1.77 and it is not my default network.
I change the Client IP to 192.168.1.1 and no other device is in this Network-Segment.
As I remember the answer came from a thttp Webserver.
Kind Regards
Carlo
Kind Regards
Carlo
I post a Screenshot wich shows, that i am connected to the Meteohub-System on the RPI.
No Idea ?
I have already bought a new Micro-SD-Card - Same Problem
Greetz
Carlo
No Idea ?
Greetz
Carlo
- Zwischenablage01.jpg (22.83 KiB) Viewed 5905 times
On a freshly installed system http user is "meteohub" and password is "meteohub".
There is a posting int the FAQ that explains how to reset http password.
viewtopic.php?f=23&t=5335
Hello Boris,
thx for your Help !
As you assumed it was my old Meteohub-System wich I would update.
My Problem was, that if you change the IP-Adress in the Bowser, the System bind a second IP to the network-Card.
The Old one (192.168.1.77) is still alive.
Greetz
Carlo
thx for your Help !
Greetz
Carlo
