I'm running Meteohub on a VirtualBox (5.0.14) residing on a Ubuntu host. I have a WMR100N connected directly to the host and a RFXCOM433 via an USB Extender. What I find is that Meteohub frequently looses connection to the RFXCOM (and sometimes WMR100N, but that's a known issue) and cannot recover by shutting the virtual machine off/on.
Only way to recover, is to reboot the entire host (and sometime disconnect/connect RFXCOM physically).
On another virtual host, I have a Windows 7 + a Domotiga software running towards another RFXCOM433E on the USB Extender. This never fails.
I have setup the relevant USB filters, have installed the Windows Guest additions, but have not touched Meteohub's OS at all.
Questions: Would it perhaps help to update Debian? Would it help installing guest additions on Debian? Or must I accept that this is not supported/should work and find another solution?
Will updating Debian help USB issues?
- YJB
Re: Will updating Debian help USB issues?
I'm running MH in a Virtualbox environment as well and can't relate to the issues you are describing
VirtualBox 4.3.32
Host OS: Open Suse 12.3 (3.7.10-1.45-desktop)
USB RfXReceiver
Davis Envoy (TCP/IP)
As far as I'm concerned it's running pretty stable and I've never seen any USB connection issues.
If it was me I would probably suspect the USB extender....
VirtualBox 4.3.32
USB RfXReceiver
Hi JTB,
I would as well, if it wasn't because another VM running Windows 2012 and mapped towards another RFXCOM on the USB Extender never has these issues.
BTW: Would it be possible to get the machine settings from your virtual meteohub? e.g. chipset settings etc.?
- YJB
Sure:
VBoxManage showvminfo "Meteohub"
Groups: /
Guest OS: Debian (32-bit)
UUID: xxxxxx-1813-43a1-b1ca-xxxxxxxxxxxx
Config file: /home/vbox/VirtualBox VMs/Meteohub/Meteohub.vbox
Snapshot folder: /home/vbox/VirtualBox VMs/Meteohub/Snapshots
Log folder: /home/vbox/VirtualBox VMs/Meteohub/Logs
Hardware UUID: xxxx-xxxx
Memory size: 256MB
Page Fusion: off
VRAM size: 12MB
CPU exec cap: 100%
HPET: off
Chipset: piix3
Firmware: BIOS
Number of CPUs: 1
PAE: off
Long Mode: on
Synthetic CPU: off
CPUID overrides: None
Boot menu mode: message and menu
Boot Device (1): HardDisk
Boot Device (2): Not Assigned
Boot Device (3): Not Assigned
Boot Device (4): Not Assigned
ACPI: on
IOAPIC: off
Time offset: 0ms
RTC: UTC
Hardw. virt.ext: off
Nested Paging: off
Large Pages: off
VT-x VPID: on
VT-x unr. exec.: on
State: running (since 2016-01-06T20:03:47.279000000)
Monitor count: 1
3D Acceleration: off
2D Video Acceleration: off
Teleporter Enabled: off
Teleporter Port: 0
Teleporter Address:
Teleporter Password:
Tracing Enabled: off
Allow Tracing to Access VM: off
Tracing Configuration:
Autostart Enabled: off
Autostart Delay: 0
Default Frontend:
Storage Controller Name (0): IDE Controller
Storage Controller Type (0): PIIX4
Storage Controller Instance Number (0): 0
Storage Controller Max Port Count (0): 2
Storage Controller Port Count (0): 2
Storage Controller Bootable (0): on
IDE Controller (0, 0): /home/Virtual/Meteohub/Meteohub-v4.7-4GB.vdi (UUID: xxxx-xxxx)
NIC 1: MAC: 000DB9XXXXXX, Attachment: Bridged Interface 'eth1', Cable connected: on, Trace: off (file: none), Type: 82540EM, Reported speed: 0 Mbps, Boot priority: 0, Promisc Policy: deny, Bandwidth group: none
NIC 2: disabled
NIC 3: disabled
NIC 4: disabled
NIC 5: disabled
NIC 6: disabled
NIC 7: disabled
NIC 8: disabled
Pointing Device: PS/2 Mouse
Keyboard Device: PS/2 Keyboard
UART 1: disabled
UART 2: disabled
LPT 1: disabled
LPT 2: disabled
Audio: disabled
Clipboard Mode: Bidirectional
Drag'n'drop Mode: disabled
Video mode: 720x400x0 at 0,0
VRDE: enabled (Address 0.0.0.0, Ports 4005, MultiConn: off, ReuseSingleConn: off, Authentication type: null)
VRDE port: 4005
Video redirection: disabled
VRDE property: TCP/Ports = "4005"
VRDE property: TCP/Address = <not set>
VRDE property: VideoChannel/Enabled = <not set>
VRDE property: VideoChannel/Quality = <not set>
VRDE property: VideoChannel/DownscaleProtection = <not set>
VRDE property: Client/DisableDisplay = <not set>
VRDE property: Client/DisableInput = <not set>
VRDE property: Client/DisableAudio = <not set>
VRDE property: Client/DisableUSB = <not set>
VRDE property: Client/DisableClipboard = <not set>
VRDE property: Client/DisableUpstreamAudio = <not set>
VRDE property: Client/DisableRDPDR = <not set>
VRDE property: H3DRedirect/Enabled = <not set>
VRDE property: Security/Method = <not set>
VRDE property: Security/ServerCertificate = <not set>
VRDE property: Security/ServerPrivateKey = <not set>
VRDE property: Security/CACertificate = <not set>
VRDE property: Audio/RateCorrectionMode = <not set>
VRDE property: Audio/LogPath = <not set>
USB: enabled
EHCI: enabled
Currently Attached USB Devices:
UUID: xxxxxxxx-ca51-48f9-8311-xxxxxxxxxxxx
VendorId: 0x0403 (0403)
ProductId: 0x6001 (6001)
Revision: 6.0 (0600)
Manufacturer: FTDI
Product: FT232R USB UART
SerialNumber: A60081IB
Address: sysfs:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.8/2-1.8.1//device:/dev/vboxusb/002/005
Bandwidth groups: <none>
Shared folders: <none>
VRDE Connection: not active
Clients so far: 0
Video capturing: not active
Capture screens: 0
Capture file: /home/vbox/VirtualBox VMs/Meteohub/Meteohub.webm
Capture dimensions: 1024x768
Capture rate: 512 kbps
Capture FPS: 25
Guest:
Configured memory balloon size: 0 MB
OS type: Debian
Additions run level: 0
Guest Facilities:
No active facilities.
