MeteoBridge Stops Logging **solved**
blacklistedcard
Post by blacklistedcard »
I just got my Meteobridge online and have noticed every three to four hours the system stops sending data to weatherunderground. I'm running the latest version of Meteobridge and Meteostick.
Hardware:
D-LINK DIR-505 REV. A1 (no USB hub)
Davis Pro 2 weather station
Meteostick with the latest firmware
wnetd (04.03.2016 23:08:18): process started.
test5m (04.03.2016 23:08:20): logger stalled, will be restarted now.
logger (04.03.2016 23:08:21): Historical data loaded (29 records).
logger (04.03.2016 23:08:21): data logger (version 5.0p, build 9385) started.
logger (04.03.2016 23:08:21): connect station 0 (Meteostick Vantage via USB serial).
logger (04.03.2016 23:08:23): transmitter 1 registered as ISS
logger (04.03.2016 23:08:23): Meteostick Version 2.3b1
logger (04.03.2016 23:08:23): debug off
logger (04.03.2016 23:08:23): verbose off
logger (04.03.2016 23:08:23): output raw (8 bytes)
logger (04.03.2016 23:08:23): output raw (10 bytes)
logger (04.03.2016 23:08:23): filter on
logger (04.03.2016 23:08:23): rx threshold set to -80db
logger (04.03.2016 23:08:23): listening to transmitter 1
logger (04.03.2016 23:08:23): bandwidth wide
logger (04.03.2016 23:08:23): chip authentication ok: 14
logger (04.03.2016 23:08:23): frequency band 915MHz (US)
logger (05.03.2016 02:39:29): restart meteostick (311 secs no valid rf signal)
logger (05.03.2016 02:44:30): restart meteostick (301 secs no valid rf signal)
logger (05.03.2016 07:51:01): child process received timeout signal (14).
logger (05.03.2016 07:51:22): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 07:51:22): data logger stopped.
logger (05.03.2016 07:51:22): Historical data loaded (29 records).
logger (05.03.2016 07:51:22): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 07:52:18): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 07:57:48): child process received timeout signal (14).
logger (05.03.2016 07:58:39): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 07:58:39): data logger stopped.
logger (05.03.2016 07:58:40): Historical data loaded (29 records).
logger (05.03.2016 07:58:40): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 07:59:36): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 08:05:06): child process received timeout signal (14).
logger (05.03.2016 08:05:57): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 08:05:57): data logger stopped.
logger (05.03.2016 08:05:57): Historical data loaded (29 records).
logger (05.03.2016 08:05:57): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 08:06:53): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 08:12:23): child process received timeout signal (14).
logger (05.03.2016 08:13:14): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 08:13:14): data logger stopped.
logger (05.03.2016 08:13:14): Historical data loaded (29 records).
logger (05.03.2016 08:13:14): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 08:14:10): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 08:19:40): child process received timeout signal (14).
logger (05.03.2016 08:20:32): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 08:20:32): data logger stopped.
logger (05.03.2016 08:20:32): Historical data loaded (29 records).
logger (05.03.2016 08:20:32): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 08:21:28): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 08:26:58): child process received timeout signal (14).
logger (05.03.2016 08:27:49): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 08:27:49): data logger stopped.
logger (05.03.2016 08:27:49): Historical data loaded (29 records).
logger (05.03.2016 08:27:49): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 08:28:45): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 08:34:15): child process received timeout signal (14).
logger (05.03.2016 08:35:06): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 08:35:06): data logger stopped.
logger (05.03.2016 08:35:06): Historical data loaded (29 records).
logger (05.03.2016 08:35:06): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 08:36:02): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 08:41:32): child process received timeout signal (14).
logger (05.03.2016 08:42:24): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 08:42:24): data logger stopped.
logger (05.03.2016 08:42:24): Historical data loaded (29 records).
logger (05.03.2016 08:42:24): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 08:43:20): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 08:48:50): child process received timeout signal (14).
logger (05.03.2016 08:49:41): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 08:49:41): data logger stopped.
logger (05.03.2016 08:49:41): Historical data loaded (29 records).
logger (05.03.2016 08:49:41): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 08:50:37): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 08:56:07): child process received timeout signal (14).
logger (05.03.2016 08:56:58): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 08:56:58): data logger stopped.
logger (05.03.2016 08:56:59): Historical data loaded (29 records).
logger (05.03.2016 08:56:59): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 08:57:54): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 09:03:24): child process received timeout signal (14).
logger (05.03.2016 09:04:16): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 09:04:16): data logger stopped.
logger (05.03.2016 09:04:16): Historical data loaded (29 records).
logger (05.03.2016 09:04:16): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 09:05:12): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 09:10:42): child process received timeout signal (14).
logger (05.03.2016 09:11:33): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 09:11:33): data logger stopped.
logger (05.03.2016 09:11:33): Historical data loaded (29 records).
logger (05.03.2016 09:11:33): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 09:12:29): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 09:17:59): child process received timeout signal (14).
logger (05.03.2016 09:18:50): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 09:18:51): data logger stopped.
logger (05.03.2016 09:18:51): Historical data loaded (29 records).
logger (05.03.2016 09:18:51): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 09:19:47): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 09:25:17): child process received timeout signal (14).
logger (05.03.2016 09:26:08): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 09:26:08): data logger stopped.
logger (05.03.2016 09:26:08): Historical data loaded (29 records).
logger (05.03.2016 09:26:08): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 09:27:04): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 09:32:34): child process received timeout signal (14).
logger (05.03.2016 09:33:25): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 09:33:25): data logger stopped.
logger (05.03.2016 09:33:25): Historical data loaded (29 records).
logger (05.03.2016 09:33:25): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 09:34:21): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 09:39:51): child process received timeout signal (14).
logger (05.03.2016 09:40:43): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 09:40:43): data logger stopped.
logger (05.03.2016 09:40:43): Historical data loaded (29 records).
logger (05.03.2016 09:40:43): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 09:41:39): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 09:47:09): child process received timeout signal (14).
logger (05.03.2016 09:48:00): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 09:48:00): data logger stopped.
logger (05.03.2016 09:48:00): Historical data loaded (29 records).
logger (05.03.2016 09:48:00): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 09:48:56): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 09:54:26): child process received timeout signal (14).
logger (05.03.2016 09:55:17): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 09:55:17): data logger stopped.
logger (05.03.2016 09:55:17): Historical data loaded (29 records).
logger (05.03.2016 09:55:17): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 09:56:13): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 10:01:43): child process received timeout signal (14).
logger (05.03.2016 10:02:35): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 10:02:35): data logger stopped.
logger (05.03.2016 10:02:35): Historical data loaded (29 records).
logger (05.03.2016 10:02:35): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 10:03:31): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 10:09:01): child process received timeout signal (14).
logger (05.03.2016 10:09:52): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 10:09:52): data logger stopped.
logger (05.03.2016 10:09:52): Historical data loaded (29 records).
logger (05.03.2016 10:09:52): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 10:10:48): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 10:16:18): child process received timeout signal (14).
logger (05.03.2016 10:17:09): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 10:17:09): data logger stopped.
logger (05.03.2016 10:17:10): Historical data loaded (29 records).
logger (05.03.2016 10:17:10): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 10:18:06): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 10:23:36): child process received timeout signal (14).
logger (05.03.2016 10:24:27): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 10:24:27): data logger stopped.
logger (05.03.2016 10:24:27): Historical data loaded (29 records).
logger (05.03.2016 10:24:27): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 10:25:23): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 10:30:53): child process received timeout signal (14).
logger (05.03.2016 10:31:44): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 10:31:44): data logger stopped.
logger (05.03.2016 10:31:44): Historical data loaded (29 records).
logger (05.03.2016 10:31:44): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 10:32:40): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 10:38:10): child process received timeout signal (14).
logger (05.03.2016 10:39:01): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 10:39:02): data logger stopped.
logger (05.03.2016 10:39:02): Historical data loaded (29 records).
logger (05.03.2016 10:39:02): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 10:39:58): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 10:45:28): child process received timeout signal (14).
logger (05.03.2016 10:46:19): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 10:46:19): data logger stopped.
logger (05.03.2016 10:46:19): Historical data loaded (29 records).
logger (05.03.2016 10:46:19): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 10:47:15): connect station 0 (Meteostick Vantage via USB serial).
logger (05.03.2016 10:52:45): child process received timeout signal (14).
logger (05.03.2016 10:53:36): disconnect station 0 (Meteostick Vantage): exit
logger (05.03.2016 10:53:36): data logger stopped.
logger (05.03.2016 10:53:36): Historical data loaded (29 records).
logger (05.03.2016 10:53:36): data logger (version 5.0p, build 9385) started.
logger (05.03.2016 10:54:32): connect station 0 (Meteostick Vantage via USB serial).
Re: MeteoBridge Stops Logging
The behavour shown above is a bit unexpected. When the data logger disconnects because of timeout
it is expected to restart Meteostick as well. But I cant see the expected Meteostick start messages.
blacklistedcard
I just did another reboot and picked up the new version. I'll see if the I get the same problem.
Platform: D-LINK DIR-505 REV. A1 (no USB hub)
RAM: 61556 kB total, 28592 kB free (53% used)
SW Version: Meteobridge 2.8 (Mar 7 2016, build 9466), FW 1.3
Uptime: 0 hours, 3 minutes Buffer Usage:
blacklistedcard
I noticed the wind data error message. That's the first time I have seen that message. Will keep monitoring....
wnetd (07.03.2016 20:26:18): process started.
test5m (07.03.2016 20:26:21): logger stalled, will be restarted now.
logger (07.03.2016 20:26:21): Historical data loaded (29 records).
logger (07.03.2016 20:26:21): data logger (version 5.0p, build 9466) started.
logger (07.03.2016 20:26:22): connect station 0 (Meteostick Vantage via USB serial).
logger (07.03.2016 20:26:24): transmitter 1 registered as ISS
logger (07.03.2016 20:26:24): Meteostick Version 2.3b1
logger (07.03.2016 20:26:24): debug off
logger (07.03.2016 20:26:24): verbose off
logger (07.03.2016 20:26:24): output raw (8 bytes)
logger (07.03.2016 20:26:24): output raw (10 bytes)
logger (07.03.2016 20:26:24): filter on
logger (07.03.2016 20:26:24): rx threshold set to -80db
logger (07.03.2016 20:26:24): listening to transmitter 1
logger (07.03.2016 20:26:25): bandwidth wide
logger (07.03.2016 20:26:25): chip authentication ok: 14
logger (07.03.2016 20:26:25): frequency band 915MHz (US)
logger (07.03.2016 20:30:44): wind0 data incomplete (missing outdoor temp for windchill)
logger (07.03.2016 20:30:52): wind0 data incomplete (missing outdoor temp for windchill)
logger (07.03.2016 20:30:57): wind0 data incomplete (missing outdoor temp for windchill)
logger (07.03.2016 20:30:59): wind0 data incomplete (missing outdoor temp for windchill)
logger (07.03.2016 20:31:02): wind0 data incomplete (missing outdoor temp for windchill)
logger (07.03.2016 20:31:04): wind0 data incomplete (missing outdoor temp for windchill)
blacklistedcard
Here is the screenshot of the Meteostick and the sensor data.
Once the outdoor temp sensor chimes in, windchill warning will go away.
D2149
Location: Bass Lake - California USA (Southern Sierra Nevada near Yosemite National Park)
Post by D2149 »
What about the constant logger stalls and restarts though? I just received and setup my Meteobridge PRO today and I am getting a lot of those same kind of messages...
test5m (10.03.2016 17:30:45): weathernet daemon stalled, will be restarted now.
test5m (10.03.2016 17:35:38): weathernet daemon stalled, will be restarted now.
test5m (10.03.2016 17:41:14): weathernet daemon stalled, will be restarted now.
test5m (10.03.2016 17:45:27): weathernet daemon stalled, will be restarted now.
blacklistedcard
I still getting the problem after about three hours, the meteostick dies. Starts off fine... Runs for about three hours, then "logger (05.03.2016 08:26:58): child process received timeout signal (14)" messages until I reboot.
Any suggestions?
please reboot and report if it still is a problem.
blacklistedcard
Rebooted the device. So far it only last for two to three hours and then the logging dies.
Running the following:
RAM: 61556 kB total, 28460 kB free (53% used)
SW Version: Meteobridge 2.8 (Mar 19 2016, build 9591), FW 1.3
Uptime: 0 hours, 14 minutes Buffer Usage: 0 items (0%)
blacklistedcard
Any Suggestions?
Can you please give me access as explained in the FAQ? Please send URL and password to "info(at)meteobridge.com"
blacklistedcard
Details sent by e-mail...
blacklistedcard
Still stops logging after a couple of hours
Seem to be some low level USB problems.
