I am constantly getting this error in the Meteohub log file:
wmr928eval (15.08.2008 19:48:01): no sensor found to match export name th1
wmr928eval (15.08.2008 19:58:00): no sensor found to match export name th1
WMR928 tells me it is associted with an Oregon WMR928 - but I have a Davis Vantage Pro...the errors are about every 10 mintues for the last 4 days. I am uploading clientrawextra and an html file every 10 minutes. Recalc of weather data and a reboot doesn't fix it.....but it doesn't appear to effect anything unless it effects my lack of rain updating from my other post.....
The html file I am uploading it this one....
http://westwoodsweather.com/weather/mobile.html
Any thoughts!
Logging error of another bug? SOLVED
Re:Logging error of another bug?
See this thread.
It seems that Boris has yet to track down the source of that weird message, but if you go to the WSWIN Data Export page on the administration panel and assign all your sensors to the appropriate WSWIN Variable (e.g. Temp Outdoor --> th0, and so forth), then press 'SAVE' it suppresses the error message.
You don't need to check the 'Generate WSWIN Data Ongoing' box either... the above is sufficient to eliminate the log file message.
THANKS!!! :)
