MB Pro failure to read WeatherLink IP data **solved**
Re: MB Pro failure to read WeatherLink IP data **solved**
Had also crossed my mind re "the behaviour of the WLIP" has been changed in some way due to the same issue occurring at about the same time on totally independent systems.
Anyway the following is the log and time line after setting one setup to IP (No WL Upload) (will post the other system results separately)
BTW the MB (MR3020 / Meteobridge 2.8 (May 6 2016, build 9855), FW 1.4 ) was powered all day yesterday (14/5) but no connected to the WLIP (which was also powered/running) or the router which was powered off
14/5/16
~ 17:17 All repowered/reconnected
~ 19:45 - Set IP (No WL Upload)
15/5/16
~ 7:30 Downloaded WeatherLink, last data uploaded was 14/5/16 @ 23:40
WeatherLink.com went red at 2:08
Message log as follows as per 15/5/16 @ 09:00
logger (14.05.2016 17:17:54): station 0 (Vantage), error connect socket 192.168.0.59: port 22222: No route to host
logger (14.05.2016 17:18:21): connect station 0 (Vantage via TCP/IP).
logger (14.05.2016 17:18:21): wakeup sent.
logger (14.05.2016 17:18:21): internal logger activated.
logger (14.05.2016 17:18:21): syncing.
logger (14.05.2016 17:18:32): gettime request sent.
logger (14.05.2016 17:18:32): time offset of Vantage: -1 minutes
logger (14.05.2016 17:18:32): eeprom request sent.
logger (14.05.2016 17:18:33): rain collector size 0.2 mm per tick.
logger (14.05.2016 17:18:33): transmitter 3 active as station type (#0) "ISS".
logger (14.05.2016 17:18:33): firmware version request sent.
logger (14.05.2016 17:18:34): firmware version 1.90
logger (14.05.2016 17:18:34): no reading of Vantage's internal logger.
logger (14.05.2016 19:45:51): parent process received termination signal (15).
logger (14.05.2016 19:45:51): child process received termination signal (15).
logger (14.05.2016 19:45:51): disconnect station 0 (Vantage): exit
logger (14.05.2016 19:45:51): data logger stopped.
logger (14.05.2016 19:45:51): Historical data loaded (19 records).
logger (14.05.2016 19:45:51): data logger (version 5.0p, build 9855) started.
logger (14.05.2016 19:45:52): connect station 0 (Vantage via TCP/IP).
logger (14.05.2016 19:45:52): wakeup sent.
logger (14.05.2016 19:45:52): internal logger activated.
logger (14.05.2016 19:45:52): syncing.
logger (14.05.2016 19:46:03): gettime request sent.
logger (14.05.2016 19:46:03): time offset of Vantage: -1 minutes
logger (14.05.2016 19:46:03): eeprom request sent.
logger (14.05.2016 19:46:04): rain collector size 0.2 mm per tick.
logger (14.05.2016 19:46:04): transmitter 3 active as station type (#0) "ISS".
logger (14.05.2016 19:46:04): firmware version request sent.
logger (14.05.2016 19:46:05): firmware version 1.90
logger (14.05.2016 19:46:05): no reading of Vantage's internal logger.
logger (14.05.2016 21:55:41): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (14.05.2016 21:55:41): disconnect station 0 (Vantage): read failed
logger (14.05.2016 21:56:11): connect station 0 (Vantage via TCP/IP).
logger (14.05.2016 21:56:11): wakeup sent.
logger (14.05.2016 21:56:11): internal logger activated.
logger (14.05.2016 21:56:11): syncing.
logger (14.05.2016 21:56:21): gettime request sent.
logger (14.05.2016 21:56:21): time offset of Vantage: -1 minutes
logger (14.05.2016 21:56:21): eeprom request sent.
logger (14.05.2016 21:56:22): rain collector size 0.2 mm per tick.
logger (14.05.2016 21:56:22): transmitter 3 active as station type (#0) "ISS".
logger (14.05.2016 21:56:22): firmware version request sent.
logger (14.05.2016 21:56:23): firmware version 1.90
logger (14.05.2016 21:56:23): no reading of Vantage's internal logger.
logger (14.05.2016 22:19:18): child process received timeout signal (14).
logger (14.05.2016 22:19:18): disconnect station 0 (Vantage): exit
logger (14.05.2016 22:19:18): data logger stopped.
logger (14.05.2016 22:19:18): Historical data loaded (19 records).
logger (14.05.2016 22:19:18): data logger (version 5.0p, build 9855) started.
logger (14.05.2016 22:19:19): connect station 0 (Vantage via TCP/IP).
logger (14.05.2016 22:19:19): wakeup sent.
logger (14.05.2016 22:19:19): internal logger activated.
logger (14.05.2016 22:19:19): syncing.
logger (14.05.2016 22:19:29): gettime request sent.
logger (14.05.2016 22:19:29): time offset of Vantage: -1 minutes
logger (14.05.2016 22:19:29): eeprom request sent.
logger (14.05.2016 22:19:30): rain collector size 0.2 mm per tick.
logger (14.05.2016 22:19:30): transmitter 3 active as station type (#0) "ISS".
logger (14.05.2016 22:19:30): firmware version request sent.
logger (14.05.2016 22:19:31): firmware version 1.90
logger (14.05.2016 22:19:31): no reading of Vantage's internal logger.
logger (14.05.2016 23:24:33): child process received timeout signal (14).
logger (14.05.2016 23:24:33): disconnect station 0 (Vantage): exit
logger (14.05.2016 23:24:33): data logger stopped.
logger (14.05.2016 23:24:34): Historical data loaded (19 records).
logger (14.05.2016 23:24:34): data logger (version 5.0p, build 9855) started.
logger (14.05.2016 23:24:34): connect station 0 (Vantage via TCP/IP).
logger (14.05.2016 23:24:34): wakeup sent.
logger (14.05.2016 23:24:34): internal logger activated.
logger (14.05.2016 23:24:35): syncing.
logger (14.05.2016 23:24:45): gettime request sent.
logger (14.05.2016 23:24:45): time offset of Vantage: -1 minutes
logger (14.05.2016 23:24:45): eeprom request sent.
logger (14.05.2016 23:24:46): rain collector size 0.2 mm per tick.
logger (14.05.2016 23:24:46): transmitter 3 active as station type (#0) "ISS".
logger (14.05.2016 23:24:46): firmware version request sent.
logger (14.05.2016 23:24:47): firmware version 1.90
logger (14.05.2016 23:24:47): no reading of Vantage's internal logger.
logger (15.05.2016 02:08:03): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 02:08:03): disconnect station 0 (Vantage): read failed
logger (15.05.2016 02:08:33): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 02:08:33): wakeup sent.
logger (15.05.2016 02:08:33): internal logger activated.
logger (15.05.2016 02:08:33): syncing.
logger (15.05.2016 02:08:43): gettime request sent.
logger (15.05.2016 02:08:53): gettime request sent.
logger (15.05.2016 02:09:03): gettime request sent.
logger (15.05.2016 02:09:03): time offset of Vantage: -1 minutes
logger (15.05.2016 02:09:03): eeprom request sent.
logger (15.05.2016 02:09:04): rain collector size 0.2 mm per tick.
logger (15.05.2016 02:09:04): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 02:09:04): firmware version request sent.
logger (15.05.2016 02:09:05): firmware version 1.90
logger (15.05.2016 02:09:05): no reading of Vantage's internal logger.
logger (15.05.2016 02:21:56): child process received timeout signal (14).
logger (15.05.2016 02:21:56): disconnect station 0 (Vantage): exit
logger (15.05.2016 02:21:56): data logger stopped.
logger (15.05.2016 02:21:56): Historical data loaded (19 records).
logger (15.05.2016 02:21:56): data logger (version 5.0p, build 9855) started.
logger (15.05.2016 02:21:57): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 02:21:57): wakeup sent.
logger (15.05.2016 02:21:57): internal logger activated.
logger (15.05.2016 02:21:57): syncing.
logger (15.05.2016 02:22:07): gettime request sent.
logger (15.05.2016 02:22:17): gettime request sent.
logger (15.05.2016 02:22:27): gettime request sent.
logger (15.05.2016 02:22:37): wakeup sent.
logger (15.05.2016 02:22:37): internal logger activated.
logger (15.05.2016 02:22:37): syncing.
logger (15.05.2016 02:22:37): gettime request sent.
logger (15.05.2016 02:22:47): gettime request sent.
logger (15.05.2016 02:22:57): gettime request sent.
logger (15.05.2016 02:22:57): time offset of Vantage: -1 minutes
logger (15.05.2016 02:22:57): eeprom request sent.
logger (15.05.2016 02:22:58): rain collector size 0.2 mm per tick.
logger (15.05.2016 02:22:58): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 02:22:58): firmware version request sent.
logger (15.05.2016 02:22:59): firmware version 1.90
logger (15.05.2016 02:22:59): no reading of Vantage's internal logger.
Some follow on from my above post (9:02am)
At approx. 09:05 set the upload back to IP (WL Upload 1 min)
At 09:06 WeatherLink.com was live again and displaying correct data from throughout the night
At ~ 10:20am downloaded data up until 00:30 (15/5) and from past experience will expect the remaining data upload to catchup over the next few hours?
Message log as follows on the previous as at 10:30 (15/5)
logger (15.05.2016 09:06:04): Historical data loaded (19 records).
logger (15.05.2016 09:06:04): data logger (version 5.0p, build 9855) started.
logger (15.05.2016 09:06:04): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 09:06:05): wakeup sent.
logger (15.05.2016 09:06:05): internal logger activated.
logger (15.05.2016 09:06:05): syncing.
logger (15.05.2016 09:06:14): gettime request sent.
logger (15.05.2016 09:06:14): time offset of Vantage: -1 minutes
logger (15.05.2016 09:06:14): eeprom request sent.
logger (15.05.2016 09:06:15): rain collector size 0.2 mm per tick.
logger (15.05.2016 09:06:15): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 09:06:15): firmware version request sent.
logger (15.05.2016 09:06:15): firmware version 1.90
logger (15.05.2016 09:06:15): no reading of Vantage's internal logger.
logger (15.05.2016 09:15:33): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 09:15:33): disconnect station 0 (Vantage): read failed
logger (15.05.2016 09:16:03): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 09:16:03): wakeup sent.
logger (15.05.2016 09:16:03): internal logger activated.
logger (15.05.2016 09:16:03): syncing.
logger (15.05.2016 09:16:13): gettime request sent.
logger (15.05.2016 09:16:13): time offset of Vantage: -1 minutes
logger (15.05.2016 09:16:13): eeprom request sent.
logger (15.05.2016 09:16:14): rain collector size 0.2 mm per tick.
logger (15.05.2016 09:16:14): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 09:16:14): firmware version request sent.
logger (15.05.2016 09:16:15): firmware version 1.90
logger (15.05.2016 09:16:15): no reading of Vantage's internal logger.
logger (15.05.2016 09:41:36): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 09:41:36): disconnect station 0 (Vantage): read failed
logger (15.05.2016 09:42:06): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 09:42:06): wakeup sent.
logger (15.05.2016 09:42:06): internal logger activated.
logger (15.05.2016 09:42:06): syncing.
logger (15.05.2016 09:42:16): gettime request sent.
logger (15.05.2016 09:42:16): time offset of Vantage: -1 minutes
logger (15.05.2016 09:42:16): eeprom request sent.
logger (15.05.2016 09:42:17): rain collector size 0.2 mm per tick.
logger (15.05.2016 09:42:17): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 09:42:17): firmware version request sent.
logger (15.05.2016 09:42:17): firmware version 1.90
logger (15.05.2016 09:42:17): no reading of Vantage's internal logger.
logger (15.05.2016 09:45:11): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 09:45:11): disconnect station 0 (Vantage): read failed
logger (15.05.2016 09:45:41): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 09:45:41): wakeup sent.
logger (15.05.2016 09:45:41): internal logger activated.
logger (15.05.2016 09:45:41): syncing.
logger (15.05.2016 09:45:51): gettime request sent.
logger (15.05.2016 09:45:51): time offset of Vantage: -1 minutes
logger (15.05.2016 09:45:51): eeprom request sent.
logger (15.05.2016 09:45:52): rain collector size 0.2 mm per tick.
logger (15.05.2016 09:45:52): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 09:45:52): firmware version request sent.
logger (15.05.2016 09:45:52): firmware version 1.90
logger (15.05.2016 09:45:52): no reading of Vantage's internal logger.
logger (15.05.2016 10:02:39): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 10:02:39): disconnect station 0 (Vantage): read failed
logger (15.05.2016 10:03:09): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 10:03:09): wakeup sent.
logger (15.05.2016 10:03:09): internal logger activated.
logger (15.05.2016 10:03:09): syncing.
logger (15.05.2016 10:03:20): gettime request sent.
logger (15.05.2016 10:03:20): time offset of Vantage: -1 minutes
logger (15.05.2016 10:03:20): eeprom request sent.
logger (15.05.2016 10:03:21): rain collector size 0.2 mm per tick.
logger (15.05.2016 10:03:21): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 10:03:21): firmware version request sent.
logger (15.05.2016 10:03:21): firmware version 1.90
logger (15.05.2016 10:03:21): no reading of Vantage's internal logger.
logger (15.05.2016 10:06:15): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 10:06:15): disconnect station 0 (Vantage): read failed
logger (15.05.2016 10:06:45): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 10:06:45): wakeup sent.
logger (15.05.2016 10:06:45): internal logger activated.
logger (15.05.2016 10:06:45): syncing.
logger (15.05.2016 10:06:56): gettime request sent.
logger (15.05.2016 10:06:56): time offset of Vantage: -1 minutes
logger (15.05.2016 10:06:56): eeprom request sent.
logger (15.05.2016 10:06:57): rain collector size 0.2 mm per tick.
logger (15.05.2016 10:06:57): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 10:06:57): firmware version request sent.
logger (15.05.2016 10:06:58): firmware version 1.90
logger (15.05.2016 10:06:58): no reading of Vantage's internal logger.
logger (15.05.2016 10:09:25): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 10:09:25): disconnect station 0 (Vantage): read failed
logger (15.05.2016 10:09:55): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 10:09:55): wakeup sent.
logger (15.05.2016 10:09:55): internal logger activated.
logger (15.05.2016 10:09:55): syncing.
logger (15.05.2016 10:10:06): gettime request sent.
logger (15.05.2016 10:10:06): time offset of Vantage: -1 minutes
logger (15.05.2016 10:10:06): eeprom request sent.
logger (15.05.2016 10:10:07): rain collector size 0.2 mm per tick.
logger (15.05.2016 10:10:07): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 10:10:07): firmware version request sent.
logger (15.05.2016 10:10:08): firmware version 1.90
logger (15.05.2016 10:10:08): no reading of Vantage's internal logger
This is a different station to the above 2 posts, this is a Meteobridge 2.5 (Jul 31 2015, build 6790), FW 1.4 (MR3020 running on a totally different network)
Was set to upload WLIP @ 1 min. At approx. 19:41 (14/5/16) changed the 1 min upload to 5 min upload and exited web interface
The MB was then not logged into again until 11:07 this morning as per following message log
logger (14.05.2016 18:27:13): no reading of Vantage's internal logger.
logger (14.05.2016 18:38:48): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (14.05.2016 18:38:48): disconnect station 0 (Vantage): read failed
logger (14.05.2016 18:39:18): connect station 0 (Vantage via TCP/IP).
logger (14.05.2016 18:39:18): wakeup sent.
logger (14.05.2016 18:39:18): internal logger activated.
logger (14.05.2016 18:39:18): syncing.
logger (14.05.2016 18:39:29): gettime request sent.
logger (14.05.2016 18:39:29): no Vantage time offset.
logger (14.05.2016 18:39:29): eeprom request sent.
logger (14.05.2016 18:39:30): rain collector size 0.2 mm per tick.
logger (14.05.2016 18:39:30): transmitter 2 active as station type (#0) "ISS".
logger (14.05.2016 18:39:30): firmware version request sent.
logger (14.05.2016 18:39:31): firmware version 1.90
logger (14.05.2016 18:39:31): no reading of Vantage's internal logger.
logger (14.05.2016 19:41:32): parent process received termination signal (15).
logger (14.05.2016 19:41:32): child process received termination signal (15).
logger (14.05.2016 19:41:32): disconnect station 0 (Vantage): wrap-up
logger (14.05.2016 19:41:32): data logger stopped.
logger (14.05.2016 19:41:33): Historical data loaded (22 records).
logger (14.05.2016 19:41:33): data logger (version 5.0i, build 6790) started.
logger (14.05.2016 19:41:34): connect station 0 (Vantage via TCP/IP).
logger (14.05.2016 19:41:34): wakeup sent.
logger (14.05.2016 19:41:34): internal logger activated.
logger (14.05.2016 19:41:35): syncing.
logger (14.05.2016 19:41:48): gettime request sent.
logger (14.05.2016 19:41:58): gettime request sent.
logger (14.05.2016 19:41:58): no Vantage time offset.
logger (14.05.2016 19:41:58): eeprom request sent.
logger (14.05.2016 19:41:59): rain collector size 0.2 mm per tick.
logger (14.05.2016 19:41:59): transmitter 2 active as station type (#0) "ISS".
logger (14.05.2016 19:41:59): firmware version request sent.
logger (14.05.2016 19:42:00): firmware version 1.90
logger (14.05.2016 19:42:00): no reading of Vantage's internal logger.
logger (14.05.2016 19:42:13): Historical data loaded (22 records).
logger (14.05.2016 19:42:13): data logger (version 5.0i, build 6790) started.
logger (14.05.2016 19:42:14): connect station 0 (Vantage via TCP/IP).
logger (14.05.2016 19:42:14): wakeup sent.
logger (14.05.2016 19:42:14): internal logger activated.
logger (14.05.2016 19:42:14): syncing.
logger (14.05.2016 19:42:24): gettime request sent.
logger (14.05.2016 19:42:34): gettime request sent.
logger (14.05.2016 19:42:34): no Vantage time offset.
logger (14.05.2016 19:42:34): eeprom request sent.
logger (14.05.2016 19:42:35): rain collector size 0.2 mm per tick.
logger (14.05.2016 19:42:35): transmitter 2 active as station type (#0) "ISS".
logger (14.05.2016 19:42:35): firmware version request sent.
logger (14.05.2016 19:42:36): firmware version 1.90
logger (14.05.2016 19:42:36): no reading of Vantage's internal logger.
logger (15.05.2016 11:07:48): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 11:07:48): disconnect station 0 (Vantage): read failed
logger (15.05.2016 11:08:18): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 11:08:18): wakeup sent.
logger (15.05.2016 11:08:18): internal logger activated.
logger (15.05.2016 11:08:18): syncing.
logger (15.05.2016 11:08:29): gettime request sent.
logger (15.05.2016 11:08:30): no Vantage time offset.
logger (15.05.2016 11:08:30): eeprom request sent.
logger (15.05.2016 11:08:30): rain collector size 0.2 mm per tick.
logger (15.05.2016 11:08:30): transmitter 2 active as station type (#0) "ISS".
logger (15.05.2016 11:08:30): firmware version request sent.
logger (15.05.2016 11:08:31): firmware version 1.90
logger (15.05.2016 11:08:31): no reading of Vantage's internal logger.
chrysnic
Post by chrysnic »
Here is my 24h update: since configuring the MB Pro to NOT upload to WeatherLink ("no WL upload" setting on "Station" tab), the error messages have disappeared! There is not a single "Connection reset by peer" message in the log over the last 24 hours.
Thus, it seems that the problem exists only when the MB Pro is configured to allow the WLIP to upload to WeatherLink.com every 1 minute.
Yes 1 minute appears the problem, 5 minute upload to WLIP basically eliminates much of the resets, not entirely all, these are MB's (MR3020) and the one that did a few resets is the one being accessed remotely.
last night rebooted one of the MB's (standalone system accessed remotely) from release May 6 to May 14 which was set for 5 minute WL upload.
Reset still exists but less occurrences. Going to try 10 minute upload period on this one.
Other MB on the main network set for 5 min has been completely clean for the past 36 hours
wnetd (15.05.2016 21:36:26): process started.
logger (15.05.2016 21:36:27): Historical data loaded (19 records).
logger (15.05.2016 21:36:27): data logger (version 5.0p, build 9888) started.
logger (15.05.2016 21:36:28): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 21:36:28): wakeup sent.
logger (15.05.2016 21:36:28): internal logger activated.
logger (15.05.2016 21:36:28): syncing.
logger (15.05.2016 21:36:39): gettime request sent.
logger (15.05.2016 21:36:49): gettime request sent.
logger (15.05.2016 21:36:49): time offset of Vantage: -1 minutes
logger (15.05.2016 21:36:49): eeprom request sent.
logger (15.05.2016 21:36:50): rain collector size 0.2 mm per tick.
logger (15.05.2016 21:36:50): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 21:36:50): firmware version request sent.
logger (15.05.2016 21:36:50): firmware version 1.90
logger (15.05.2016 21:36:50): no reading of Vantage's internal logger.
logger (15.05.2016 22:03:17): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 22:03:17): disconnect station 0 (Vantage): read failed
logger (15.05.2016 22:03:47): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 22:03:47): wakeup sent.
logger (15.05.2016 22:03:47): internal logger activated.
logger (15.05.2016 22:03:47): syncing.
logger (15.05.2016 22:03:57): gettime request sent.
logger (15.05.2016 22:03:57): time offset of Vantage: -1 minutes
logger (15.05.2016 22:03:57): eeprom request sent.
logger (15.05.2016 22:03:58): rain collector size 0.2 mm per tick.
logger (15.05.2016 22:03:58): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 22:03:58): firmware version request sent.
logger (15.05.2016 22:03:59): firmware version 1.90
logger (15.05.2016 22:03:59): no reading of Vantage's internal logger.
logger (15.05.2016 23:17:15): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (15.05.2016 23:17:15): disconnect station 0 (Vantage): read failed
logger (15.05.2016 23:17:45): connect station 0 (Vantage via TCP/IP).
logger (15.05.2016 23:17:45): wakeup sent.
logger (15.05.2016 23:17:45): internal logger activated.
logger (15.05.2016 23:17:45): syncing.
logger (15.05.2016 23:17:55): gettime request sent.
logger (15.05.2016 23:17:55): time offset of Vantage: -1 minutes
logger (15.05.2016 23:17:55): eeprom request sent.
logger (15.05.2016 23:17:56): rain collector size 0.2 mm per tick.
logger (15.05.2016 23:17:56): transmitter 3 active as station type (#0) "ISS".
logger (15.05.2016 23:17:56): firmware version request sent.
logger (15.05.2016 23:17:56): firmware version 1.90
logger (15.05.2016 23:17:56): no reading of Vantage's internal logger.
logger (16.05.2016 02:10:25): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (16.05.2016 02:10:25): disconnect station 0 (Vantage): read failed
logger (16.05.2016 02:10:55): connect station 0 (Vantage via TCP/IP).
logger (16.05.2016 02:10:55): wakeup sent.
logger (16.05.2016 02:10:55): internal logger activated.
logger (16.05.2016 02:10:55): syncing.
logger (16.05.2016 02:11:06): gettime request sent.
logger (16.05.2016 02:11:06): time offset of Vantage: -1 minutes
logger (16.05.2016 02:11:06): eeprom request sent.
logger (16.05.2016 02:11:07): rain collector size 0.2 mm per tick.
logger (16.05.2016 02:11:07): transmitter 3 active as station type (#0) "ISS".
logger (16.05.2016 02:11:07): firmware version request sent.
logger (16.05.2016 02:11:08): firmware version 1.90
logger (16.05.2016 02:11:08): no reading of Vantage's internal logger.
logger (16.05.2016 03:14:35): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (16.05.2016 03:14:35): disconnect station 0 (Vantage): read failed
logger (16.05.2016 03:15:05): connect station 0 (Vantage via TCP/IP).
logger (16.05.2016 03:15:05): wakeup sent.
logger (16.05.2016 03:15:05): internal logger activated.
logger (16.05.2016 03:15:05): syncing.
logger (16.05.2016 03:15:15): gettime request sent.
logger (16.05.2016 03:15:15): time offset of Vantage: -1 minutes
logger (16.05.2016 03:15:15): eeprom request sent.
logger (16.05.2016 03:15:16): rain collector size 0.2 mm per tick.
logger (16.05.2016 03:15:16): transmitter 3 active as station type (#0) "ISS".
logger (16.05.2016 03:15:16): firmware version request sent.
logger (16.05.2016 03:15:17): firmware version 1.90
logger (16.05.2016 03:15:17): no reading of Vantage's internal logger.
logger (16.05.2016 05:20:33): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (16.05.2016 05:20:33): disconnect station 0 (Vantage): read failed
logger (16.05.2016 05:21:03): connect station 0 (Vantage via TCP/IP).
logger (16.05.2016 05:21:03): wakeup sent.
logger (16.05.2016 05:21:03): internal logger activated.
logger (16.05.2016 05:21:03): syncing.
logger (16.05.2016 05:21:13): gettime request sent.
logger (16.05.2016 05:21:13): time offset of Vantage: -1 minutes
logger (16.05.2016 05:21:13): eeprom request sent.
logger (16.05.2016 05:21:14): rain collector size 0.2 mm per tick.
logger (16.05.2016 05:21:14): transmitter 3 active as station type (#0) "ISS".
logger (16.05.2016 05:21:14): firmware version request sent.
logger (16.05.2016 05:21:15): firmware version 1.90
logger (16.05.2016 05:21:15): no reading of Vantage's internal logger.
logger (16.05.2016 06:13:45): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (16.05.2016 06:13:45): disconnect station 0 (Vantage): read failed
logger (16.05.2016 06:14:15): connect station 0 (Vantage via TCP/IP).
logger (16.05.2016 06:14:15): wakeup sent.
logger (16.05.2016 06:14:15): internal logger activated.
logger (16.05.2016 06:14:15): syncing.
logger (16.05.2016 06:14:25): gettime request sent.
logger (16.05.2016 06:14:25): time offset of Vantage: -1 minutes
logger (16.05.2016 06:14:25): eeprom request sent.
logger (16.05.2016 06:14:26): rain collector size 0.2 mm per tick.
logger (16.05.2016 06:14:26): transmitter 3 active as station type (#0) "ISS".
logger (16.05.2016 06:14:26): firmware version request sent.
logger (16.05.2016 06:14:27): firmware version 1.90
logger (16.05.2016 06:14:27): no reading of Vantage's internal logger.
chrysnic
Post by chrysnic »
Indeed, after 48 hours of operation using the "no WL upload" setting on "Station" tab, the log is completely clean (not a single "Connection reset by peer" message).
It is clear now that the problem occurs when the WLIP is allowed to upload to WeatherLink.com.
chrysnic
Post by chrysnic »
I have just noticed that this thread has been marked as **solved**, but I don't know why. Has the problem been solved?
Looks to me like Meteobridge is not waiting long enough for WLIP to upload its data to
weatherlink. Making this slot longer might fix the problem but will cause even more
data Meteobridge is not going to see while beeing disconnected form the weather station live data.
However, I will increase the delay from 10 to 15 secs with next release.
chrysnic
Post by chrysnic »
OK, thanks. I am not sure if this is related, but now I get a new type of error message, "station 0 (Vantage), can't write string "LPS": Bad file descriptor". Here is a snippet from the log:
logger (13.06.2016 11:19:39): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (13.06.2016 11:20:39): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (13.06.2016 11:20:43): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (13.06.2016 11:21:37): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (13.06.2016 11:21:41): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (13.06.2016 11:21:49): station 0 (Vantage), reading weather station failed: Connection reset by peer
logger (13.06.2016 11:21:49): disconnect station 0 (Vantage): read failed
logger (13.06.2016 11:22:19): connect station 0 (Vantage via TCP/IP).
logger (13.06.2016 11:22:19): wakeup sent.
logger (13.06.2016 11:22:19): internal logger activated.
logger (13.06.2016 11:22:19): syncing.
logger (13.06.2016 11:22:29): gettime request sent.
logger (13.06.2016 11:22:29): time offset of Vantage: 1 minutes
logger (13.06.2016 11:22:29): eeprom request sent.
logger (13.06.2016 11:22:30): rain collector size 0.2 mm per tick.
logger (13.06.2016 11:22:30): transmitter 1 active as station type (#0) "ISS".
logger (13.06.2016 11:22:30): firmware version request sent.
logger (13.06.2016 11:22:31): firmware version 3.12
logger (13.06.2016 11:22:31): no reading of Vantage's internal logger.
logger (13.06.2016 11:23:25): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (13.06.2016 11:23:29): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (13.06.2016 11:24:23): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (13.06.2016 11:24:27): station 0 (Vantage), can't write string "LPS": Bad file descriptor
Is this the same problem as before?
See the following thread re LPS
viewtopic.php?f=56&t=11030&p=20203#p20203
chrysnic
Post by chrysnic »
This seems to be related to the WLIP, when the MB Pro is configured to allow the uploading of data (by the WLIP) to WeatherLink.com.
I configured the MB Pro to NOT allow uploads to WeatherLink.com yesterday, and the LPS error message has NOT appeared even once.
chrysnic
Post by chrysnic »
A kind and friendly reminder to the admin about increasing the pause time given to the WLIP to upload data to WeatherLink.com :)
This is also related to this thread:
I am so much focused on reducing USB storage wear, that I did implement this. Will be part of next release.
chrysnic
Post by chrysnic »
I have been testing the new release (Jul 13 2016, build 10179), which "increases logging timeout period of 15 secs to 20 secs in order to allow more stable WLIP uploads to Davis weather link server."
I am happy to report that this new release has eliminated the "Connection reset by peer" error messages.
However, the "LPS Bad file descriptor" messages are still there and they appear all the time. Below is a snippet of the system log when the WLIP is allowed to upload data to WeatherLink.com every 1 minute:
logger (14.07.2016 14:57:58): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 14:58:02): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 14:58:56): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 14:59:00): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 14:59:04): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 14:59:58): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:00:02): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:00:06): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:01:00): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:01:04): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:01:08): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:02:02): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:02:06): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:02:10): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:03:04): station 0 (Vantage), can't write string "LPS": Bad file descriptor
logger (14.07.2016 15:03:08): station 0 (Vantage), can't write string "LPS": Bad file descriptor
The "LPS bad file descriptor" issue has also been reported in this thread:
