No live data or upload to WU/CWOP
vgolle
Post by vgolle »
Hi, I'm having no success getting Meteobridge (version 2.9) to receive data from Vantage Pro2 and Davis logger. I'm using TPLink TL-MR3020 with USB 2.0 hub/serial to USB. My trial period lapsed but I went ahead and paid for license. Here is the log:
logger (04.06.2016 11:30:29): connect station 0 (Vantage via USB serial).
logger (04.06.2016 11:30:29): wakeup sent.
logger (04.06.2016 11:30:29): internal logger activated.
logger (04.06.2016 11:30:29): syncing.
logger (04.06.2016 11:30:39): gettime request sent.
logger (04.06.2016 11:30:49): gettime request sent.
logger (04.06.2016 11:30:59): gettime request sent.
logger (04.06.2016 11:31:09): disconnect station 0 (Vantage): timeout
logger (04.06.2016 11:31:39): connect station 0 (Vantage via USB serial).
logger (04.06.2016 11:31:39): wakeup sent.
logger (04.06.2016 11:31:39): internal logger activated.
logger (04.06.2016 11:31:39): syncing.
I've since pulled the serial from the serial to USB adapter. Three straight times I removed the batteries from the console, unplugged the console, rebooted the TPLink thru the Meteobridge software, connected the serial to USB adapter (2.0) running between the console and the TPLink and then plugged in the console. Each time, same result. The above is the log of what keeps happening. Can anyone please help me with this? Thank you
vgolle
Re: No live data or upload to WU/CWOP
Post by vgolle »
Oh and one other thing. On the TPLink router, the light for Internet is constantly green but the WLAN blinks every so often.
vgolle
Post by vgolle »
Are there any other details I need to provide for someone to help me along with this? Thank you
wsnoordbergum
Post by wsnoordbergum »
Have you got your console setup completely?
Setting time and time zone?
Make sure you've done the console setup as described in the manual!
If you can reach the meteobridge when typing the IP address in a browser then the meteobridge is setup ok.
I assume you have setup the right station in the station tab.
Check the system tab also here you can see if you've got a internet connection.
Good luck wsNoordbergum.
wsnoordbergum
Also:
If a serial logger is used, it needs to be set to 19.200 baud and a RS232-USB converter based on Prolific pl2303 or FTDI chipset is necessary.
looks a lot like a hang-up of the Davis Console serial port. Could you please disconnect the console from batteries, power and USB and then set it up again (with logger installed first).
