Big-Scroll-ISO Wind speed
I have my MBPRO set to display the Template: Big-Scroll-ISO because i have trouble reading the small letters, but it only has one little problem that i have noticed and that is the Wind Speed is not showing on the display the Wind Direction is showing ok and it uploads ok to WeatherUnderground with the correct data and shows up if set to a different template setting but not on the Big-Scroll-ISO all i get is --
Re: Big-Scroll-ISO Wind speed
I f you like you can open remote access and give me login access.
Here is explained how to do so: viewtopic.php?f=57&t=9885
Hi it only seemed to be when i updated to the 2.9 version that I notice the missing details so I went back to the 2.7 version that i was using before and it was back to reading again, I just wondered if anyone else had encounterd the same issue its no big deal as it was only the display on the unit that was missing , the wind speed data was still being uploaded to site ok thankyou for getting back
I see same behavior here on MBP after update on 28th of june
I just tested the "BIG-Scroll-ISO" default template on version 3.0 and it shows all the data. No "--" for wind or gust speed. Does your live data show recent wind speeds? If not, then showing "--" on the display would be ok and the problem is more on the data reception side.... just guessing.
With 2.9 (9993):admin wrote:I just tested the "BIG-Scroll-ISO" default template on version 3.0 and it shows all the data. No "--" for wind or gust speed. Does your live data show recent wind speeds? If not, then showing "--" on the display would be ok and the problem is more on the data reception side.... just guessing.
Live Data
Sensor Signal Metric Data Imperial Data
Indoor 30s 97.4% 21.6°C 58% 1016.5hPa (1015.4hPa) 70.9°F 58% 30.02inHg (29.98inHg)
Rain 7s -51db rate 0.0mm/h rate 0.00in/h
Outdoor 9s -50db 13.9°C 78% (dew 10.1°C, heat 13.9°C) 57.0°F 78% (dew 50.2°F, heat 57.0°F)
Wind #1 2s -51db 0.0m/s (avg 0.0m/s) 0° N 0.0mph (avg 0.0mph) 0° N
Wind 5s -35db 0.5m/s (avg 1.5m/s) 238° WSW 1.1mph (avg 3.4mph) 238° WSW
Data #10 16 sec 45% system load 45% system load
Data #11 16 sec 0.1h uptime 0.1h uptime
Data #12 16 sec 4% data store usage 4% data store usage
Data #13 16 sec 84% RAM usage 84% RAM usage
Data #15 16 sec 58 processes 58 processes
Data #16 16 sec 0sec since last data 0sec since last data
Data #14 16 sec 2.44W power 2.44W power
Data #17 16 sec 5.46V voltage 5.46V voltage
Data #18 16 sec 0.45A current 0.45A current
Data #19 16 sec 650.31kb tx data 650.31kb tx data
Data #20 16 sec 5213.10kb rx data 5213.10kb rx data
System #9 16 sec 47.3°C 13% 1015.6hPa (1014.5hPa) 117.1°F 13% 29.99inHg (29.96inHg)
Display shows WIND "--"
wind/outdoor/indoor/rain/system ISO 5 min wrap - works ok
Strange, can you please give me a remote login? Please send URL and password to "info(at)smartbedded.com".
BTW, I am on release 3.0.
Problem solved together with version 3.0
