version 3.0 at the meteobridge PRO not good **solved**
MeteoOudkarspel
Post by MeteoOudkarspel »
oled (03.07.2016 17:33:52): process started.
database (03.07.2016 19:35:30): process started.
wnetd (03.07.2016 19:35:30): process started.
logger (03.07.2016 19:35:30): database connected.
logger (03.07.2016 19:36:00): database connected.
For the rest, he does not do anything. he does not read me out datalogger.
So turn here with version 2.9 that does it right.
Sincerely,
plex
Re: version 3.0 at the meteobridge PRO not good
Post by plex »
Exactly same thing here - no good :(
oled (03.07.2016 18:36:59): process started.
test5m (03.07.2016 20:40:19): weathernet daemon stalled, will be restarted now.
wnetd (03.07.2016 20:40:19): process started.
test5m (03.07.2016 20:40:19): logger stalled, will be restarted now.
test5m (03.07.2016 20:40:19): database daemon stalled, will be restarted now.
database (03.07.2016 20:40:19): process started.
logger (03.07.2016 20:40:19): database connected.
logger (03.07.2016 20:40:35): database connected.
logger (03.07.2016 20:41:05): database connected.
logger (03.07.2016 20:41:35): database connected.
After one hour still the same, and no live data
Works fine here. Can you please send me remote login credentials to "info(at)meteobridge.com".
This will be the fastest way to find out where your setup and mine do differ.
Hurray, I can reproduce the bug. No credentials needed. 8)
Please reboot. I just uploaded an update that should fix this issue.
Problem was a folder not existing on 2.9 machines and my test rig already had this. :roll:
plex
Re: version 3.0 at the meteobridge PRO not good **solved**
Post by plex »
Problem solves - thanks :)
MeteoOudkarspel
Sincerely,
