Can anyone help with this error?
The MeteoBridge will collect some data for a few minutes, then stop and start every couple of hours. The Davis console is a little further from the ISS than the MeteoBridge, but it isn't have any problems receiving data.
logger (14.07.2016 16:37:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:38:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:38:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:39:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:39:47): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:40:17): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:40:22): parent process received termination signal (15).
logger (14.07.2016 16:40:22): child process received termination signal (15).
logger (14.07.2016 16:40:22): disconnect station 9 (System Data): exit
database (14.07.2016 16:40:22): process terminated normally.
logger (14.07.2016 16:40:23): data logger stopped.
test5m (14.07.2016 16:40:23): USB storage remounted: /dev/sda
database (14.07.2016 16:40:23): process started.
logger (14.07.2016 16:40:24): databases connected. Update interval 3600 seconds.
logger (14.07.2016 16:40:24): Historical data loaded (0 records).
logger (14.07.2016 16:40:24): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 16:40:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:40:25): connect station 9 (System Data via Plug-in).
logger (14.07.2016 16:40:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 16:41:04): sync of internal databases done (69 tables)
logger (14.07.2016 16:41:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:41:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:42:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:42:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:43:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:43:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:44:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:44:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:45:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:45:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:46:18): parent process received termination signal (15).
logger (14.07.2016 16:46:18): child process received termination signal (15).
logger (14.07.2016 16:46:18): disconnect station 9 (System Data): exit
database (14.07.2016 16:46:18): process terminated normally.
logger (14.07.2016 16:46:19): data logger stopped.
test5m (14.07.2016 16:46:19): USB storage remounted: /dev/sda
database (14.07.2016 16:46:19): process started.
logger (14.07.2016 16:46:20): databases connected. Update interval 3600 seconds.
logger (14.07.2016 16:46:20): Historical data loaded (0 records).
logger (14.07.2016 16:46:20): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 16:46:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:46:21): connect station 9 (System Data via Plug-in).
logger (14.07.2016 16:46:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 16:47:00): sync of internal databases done (69 tables)
logger (14.07.2016 16:47:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:47:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:48:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:48:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:49:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:49:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:50:08): parent process received termination signal (15).
logger (14.07.2016 16:50:08): child process received termination signal (15).
logger (14.07.2016 16:50:08): disconnect station 9 (System Data): exit
database (14.07.2016 16:50:08): process terminated normally.
logger (14.07.2016 16:50:09): data logger stopped.
test5m (14.07.2016 16:50:09): USB storage remounted: /dev/sda
database (14.07.2016 16:50:09): process started.
logger (14.07.2016 16:50:10): databases connected. Update interval 3600 seconds.
logger (14.07.2016 16:50:10): Historical data loaded (0 records).
logger (14.07.2016 16:50:10): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 16:50:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:50:11): connect station 9 (System Data via Plug-in).
logger (14.07.2016 16:50:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 16:50:50): sync of internal databases done (69 tables)
logger (14.07.2016 16:51:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:51:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:52:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:52:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:53:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:53:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:54:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:54:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:55:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:55:12): parent process received termination signal (15).
logger (14.07.2016 16:55:12): child process received termination signal (15).
logger (14.07.2016 16:55:12): disconnect station 9 (System Data): exit
database (14.07.2016 16:55:12): process terminated normally.
logger (14.07.2016 16:55:13): data logger stopped.
test5m (14.07.2016 16:55:13): USB storage remounted: /dev/sda
database (14.07.2016 16:55:13): process started.
logger (14.07.2016 16:55:14): databases connected. Update interval 3600 seconds.
logger (14.07.2016 16:55:14): Historical data loaded (0 records).
logger (14.07.2016 16:55:14): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 16:55:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:55:15): connect station 9 (System Data via Plug-in).
logger (14.07.2016 16:55:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 16:55:54): sync of internal databases done (69 tables)
logger (14.07.2016 16:56:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:56:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:57:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:57:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:58:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:58:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:59:15): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 16:59:45): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:00:10): parent process received termination signal (15).
logger (14.07.2016 17:00:10): child process received termination signal (15).
logger (14.07.2016 17:00:10): disconnect station 9 (System Data): exit
database (14.07.2016 17:00:10): process terminated normally.
logger (14.07.2016 17:00:11): data logger stopped.
test5m (14.07.2016 17:00:11): USB storage remounted: /dev/sda
database (14.07.2016 17:00:11): process started.
logger (14.07.2016 17:00:12): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:00:12): Historical data loaded (0 records).
logger (14.07.2016 17:00:12): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:00:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:00:13): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:00:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:00:52): sync of internal databases done (69 tables)
logger (14.07.2016 17:01:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:01:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:02:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:02:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:03:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:03:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:04:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:04:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:05:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:05:15): parent process received termination signal (15).
logger (14.07.2016 17:05:15): child process received termination signal (15).
logger (14.07.2016 17:05:15): disconnect station 9 (System Data): exit
database (14.07.2016 17:05:15): process terminated normally.
logger (14.07.2016 17:05:16): data logger stopped.
test5m (14.07.2016 17:05:16): USB storage remounted: /dev/sda
database (14.07.2016 17:05:16): process started.
logger (14.07.2016 17:05:17): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:05:17): Historical data loaded (0 records).
logger (14.07.2016 17:05:17): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:05:19): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:05:19): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:05:49): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:05:57): sync of internal databases done (69 tables)
logger (14.07.2016 17:06:19): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:06:49): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:07:19): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:07:49): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:08:19): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:08:49): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:09:19): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:09:49): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:10:19): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:10:48): parent process received termination signal (15).
logger (14.07.2016 17:10:48): child process received termination signal (15).
logger (14.07.2016 17:10:48): disconnect station 9 (System Data): exit
database (14.07.2016 17:10:48): process terminated normally.
logger (14.07.2016 17:10:49): data logger stopped.
test5m (14.07.2016 17:10:49): USB storage remounted: /dev/sda
database (14.07.2016 17:10:49): process started.
logger (14.07.2016 17:10:50): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:10:50): Historical data loaded (0 records).
logger (14.07.2016 17:10:50): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:10:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:10:51): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:11:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:11:31): sync of internal databases done (69 tables)
logger (14.07.2016 17:11:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:12:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:12:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:13:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:13:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:14:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:14:51): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:15:21): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:15:30): parent process received termination signal (15).
logger (14.07.2016 17:15:30): child process received termination signal (15).
logger (14.07.2016 17:15:30): disconnect station 9 (System Data): exit
database (14.07.2016 17:15:30): process terminated normally.
logger (14.07.2016 17:15:31): data logger stopped.
test5m (14.07.2016 17:15:31): USB storage remounted: /dev/sda
database (14.07.2016 17:15:31): process started.
logger (14.07.2016 17:15:32): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:15:32): Historical data loaded (0 records).
logger (14.07.2016 17:15:32): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:15:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:15:33): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:16:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:16:13): sync of internal databases done (69 tables)
logger (14.07.2016 17:16:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:17:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:17:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:18:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:18:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:19:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:19:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:20:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:20:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:21:03): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:21:33): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:21:37): parent process received termination signal (15).
logger (14.07.2016 17:21:37): child process received termination signal (15).
logger (14.07.2016 17:21:37): disconnect station 9 (System Data): exit
database (14.07.2016 17:21:37): process terminated normally.
logger (14.07.2016 17:21:38): data logger stopped.
test5m (14.07.2016 17:21:38): USB storage remounted: /dev/sda
database (14.07.2016 17:21:38): process started.
logger (14.07.2016 17:21:39): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:21:39): Historical data loaded (0 records).
logger (14.07.2016 17:21:39): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:21:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:21:40): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:22:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:22:20): sync of internal databases done (69 tables)
logger (14.07.2016 17:22:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:23:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:23:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:24:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:24:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:25:10): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:25:40): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:25:55): parent process received termination signal (15).
logger (14.07.2016 17:25:55): child process received termination signal (15).
logger (14.07.2016 17:25:55): disconnect station 9 (System Data): exit
logger (14.07.2016 17:25:56): data logger stopped.
database (14.07.2016 17:25:56): process terminated normally.
test5m (14.07.2016 17:25:57): USB storage remounted: /dev/sda
database (14.07.2016 17:25:57): process started.
logger (14.07.2016 17:25:58): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:25:58): Historical data loaded (0 records).
logger (14.07.2016 17:25:58): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:25:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:25:59): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:26:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:26:39): sync of internal databases done (69 tables)
logger (14.07.2016 17:26:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:27:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:27:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:28:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:28:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:29:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:29:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:30:10): parent process received termination signal (15).
logger (14.07.2016 17:30:10): child process received termination signal (15).
logger (14.07.2016 17:30:10): disconnect station 9 (System Data): exit
database (14.07.2016 17:30:10): process terminated normally.
logger (14.07.2016 17:30:11): data logger stopped.
test5m (14.07.2016 17:30:11): USB storage remounted: /dev/sda
database (14.07.2016 17:30:11): process started.
logger (14.07.2016 17:30:12): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:30:12): Historical data loaded (0 records).
logger (14.07.2016 17:30:12): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:30:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:30:14): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:30:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:30:52): sync of internal databases done (69 tables)
logger (14.07.2016 17:31:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:31:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:32:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:32:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:33:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:33:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:34:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:34:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:35:14): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:35:44): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:35:59): parent process received termination signal (15).
logger (14.07.2016 17:35:59): child process received termination signal (15).
logger (14.07.2016 17:35:59): disconnect station 9 (System Data): exit
database (14.07.2016 17:35:59): process terminated normally.
logger (14.07.2016 17:36:00): data logger stopped.
test5m (14.07.2016 17:36:00): USB storage remounted: /dev/sda
database (14.07.2016 17:36:00): process started.
logger (14.07.2016 17:36:01): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:36:01): Historical data loaded (0 records).
logger (14.07.2016 17:36:01): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:36:02): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:36:02): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:36:32): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:36:42): sync of internal databases done (69 tables)
logger (14.07.2016 17:37:02): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:37:32): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:38:02): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:38:32): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:39:02): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:39:32): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:40:02): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:40:32): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:41:02): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:41:32): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:41:33): parent process received termination signal (15).
logger (14.07.2016 17:41:33): child process received termination signal (15).
logger (14.07.2016 17:41:33): disconnect station 9 (System Data): exit
database (14.07.2016 17:41:33): process terminated normally.
logger (14.07.2016 17:41:34): data logger stopped.
test5m (14.07.2016 17:41:34): USB storage remounted: /dev/sda
database (14.07.2016 17:41:34): process started.
logger (14.07.2016 17:41:35): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:41:35): Historical data loaded (0 records).
logger (14.07.2016 17:41:35): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:41:37): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:41:37): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:42:07): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:42:16): sync of internal databases done (69 tables)
logger (14.07.2016 17:42:37): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:43:07): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:43:37): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:44:07): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:44:37): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:45:07): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:45:37): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:46:07): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:46:37): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:46:38): parent process received termination signal (15).
logger (14.07.2016 17:46:38): child process received termination signal (15).
logger (14.07.2016 17:46:38): disconnect station 9 (System Data): exit
database (14.07.2016 17:46:39): process terminated normally.
logger (14.07.2016 17:46:39): data logger stopped.
test5m (14.07.2016 17:46:40): USB storage remounted: /dev/sda
database (14.07.2016 17:46:40): process started.
logger (14.07.2016 17:46:40): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:46:40): Historical data loaded (0 records).
logger (14.07.2016 17:46:40): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:46:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:46:42): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:47:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:47:21): sync of internal databases done (69 tables)
logger (14.07.2016 17:47:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:48:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:48:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:49:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:49:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:50:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:50:21): parent process received termination signal (15).
logger (14.07.2016 17:50:21): child process received termination signal (15).
logger (14.07.2016 17:50:21): disconnect station 9 (System Data): exit
database (14.07.2016 17:50:22): process terminated normally.
logger (14.07.2016 17:50:22): data logger stopped.
test5m (14.07.2016 17:50:23): USB storage remounted: /dev/sda
database (14.07.2016 17:50:23): process started.
logger (14.07.2016 17:50:23): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:50:23): Historical data loaded (0 records).
logger (14.07.2016 17:50:23): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:50:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:50:25): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:50:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:51:04): sync of internal databases done (69 tables)
logger (14.07.2016 17:51:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:51:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:52:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:52:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:53:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:53:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:54:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:54:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:55:09): parent process received termination signal (15).
logger (14.07.2016 17:55:09): child process received termination signal (15).
logger (14.07.2016 17:55:09): disconnect station 9 (System Data): exit
database (14.07.2016 17:55:10): process terminated normally.
logger (14.07.2016 17:55:10): data logger stopped.
test5m (14.07.2016 17:55:11): USB storage remounted: /dev/sda
database (14.07.2016 17:55:11): process started.
logger (14.07.2016 17:55:11): databases connected. Update interval 3600 seconds.
logger (14.07.2016 17:55:11): Historical data loaded (0 records).
logger (14.07.2016 17:55:11): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 17:55:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:55:13): connect station 9 (System Data via Plug-in).
logger (14.07.2016 17:55:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 17:55:52): sync of internal databases done (69 tables)
logger (14.07.2016 17:56:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:56:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:57:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:57:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:58:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:58:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:59:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 17:59:43): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:00:13): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:00:18): parent process received termination signal (15).
logger (14.07.2016 18:00:18): child process received termination signal (15).
logger (14.07.2016 18:00:18): disconnect station 9 (System Data): exit
logger (14.07.2016 18:00:19): data logger stopped.
database (14.07.2016 18:00:19): process terminated normally.
test5m (14.07.2016 18:00:20): USB storage remounted: /dev/sda
database (14.07.2016 18:00:20): process started.
logger (14.07.2016 18:00:21): databases connected. Update interval 3600 seconds.
logger (14.07.2016 18:00:21): Historical data loaded (0 records).
logger (14.07.2016 18:00:21): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 18:00:22): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:00:22): connect station 9 (System Data via Plug-in).
logger (14.07.2016 18:00:52): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 18:01:02): sync of internal databases done (69 tables)
logger (14.07.2016 18:01:22): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:01:52): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:02:22): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:02:52): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:03:22): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:03:52): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:04:22): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:04:52): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:05:22): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:05:52): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:05:55): parent process received termination signal (15).
logger (14.07.2016 18:05:55): child process received termination signal (15).
logger (14.07.2016 18:05:56): disconnect station 9 (System Data): exit
database (14.07.2016 18:05:56): process terminated normally.
logger (14.07.2016 18:05:56): data logger stopped.
test5m (14.07.2016 18:05:57): USB storage remounted: /dev/sda
database (14.07.2016 18:05:57): process started.
logger (14.07.2016 18:05:57): databases connected. Update interval 3600 seconds.
logger (14.07.2016 18:05:57): Historical data loaded (0 records).
logger (14.07.2016 18:05:57): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 18:05:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:05:59): connect station 9 (System Data via Plug-in).
logger (14.07.2016 18:06:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 18:06:39): sync of internal databases done (69 tables)
logger (14.07.2016 18:06:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:07:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:07:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:08:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:08:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:09:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:09:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:10:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:10:59): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:11:29): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:11:37): parent process received termination signal (15).
logger (14.07.2016 18:11:37): child process received termination signal (15).
logger (14.07.2016 18:11:37): disconnect station 9 (System Data): exit
logger (14.07.2016 18:11:38): data logger stopped.
database (14.07.2016 18:11:39): process terminated normally.
test5m (14.07.2016 18:11:40): USB storage remounted: /dev/sda
database (14.07.2016 18:11:40): process started.
logger (14.07.2016 18:11:40): databases connected. Update interval 3600 seconds.
logger (14.07.2016 18:11:40): Historical data loaded (0 records).
logger (14.07.2016 18:11:40): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 18:11:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:11:42): connect station 9 (System Data via Plug-in).
logger (14.07.2016 18:12:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 18:12:21): sync of internal databases done (69 tables)
logger (14.07.2016 18:12:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:13:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:13:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:14:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:14:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:15:12): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:15:42): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:15:51): parent process received termination signal (15).
logger (14.07.2016 18:15:51): child process received termination signal (15).
logger (14.07.2016 18:15:51): disconnect station 9 (System Data): exit
logger (14.07.2016 18:15:52): data logger stopped.
database (14.07.2016 18:15:52): process terminated normally.
test5m (14.07.2016 18:15:53): USB storage remounted: /dev/sda
database (14.07.2016 18:15:54): process started.
logger (14.07.2016 18:15:54): databases connected. Update interval 3600 seconds.
logger (14.07.2016 18:15:54): Historical data loaded (0 records).
logger (14.07.2016 18:15:54): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 18:15:56): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:15:56): connect station 9 (System Data via Plug-in).
logger (14.07.2016 18:16:26): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 18:16:36): sync of internal databases done (69 tables)
logger (14.07.2016 18:16:56): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:17:26): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:17:56): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:18:26): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:18:56): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:19:26): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:19:56): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:20:26): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:20:49): parent process received termination signal (15).
logger (14.07.2016 18:20:49): child process received termination signal (15).
logger (14.07.2016 18:20:50): disconnect station 9 (System Data): exit
database (14.07.2016 18:20:50): process terminated normally.
logger (14.07.2016 18:20:50): data logger stopped.
test5m (14.07.2016 18:20:51): USB storage remounted: /dev/sda
database (14.07.2016 18:20:51): process started.
logger (14.07.2016 18:20:51): databases connected. Update interval 3600 seconds.
logger (14.07.2016 18:20:51): Historical data loaded (0 records).
logger (14.07.2016 18:20:51): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 18:20:53): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:20:53): connect station 9 (System Data via Plug-in).
logger (14.07.2016 18:21:23): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 18:21:33): sync of internal databases done (69 tables)
logger (14.07.2016 18:21:53): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:22:23): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:22:53): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:23:23): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:23:53): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:24:23): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:24:53): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:25:23): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:25:53): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:26:07): parent process received termination signal (15).
logger (14.07.2016 18:26:07): child process received termination signal (15).
logger (14.07.2016 18:26:08): disconnect station 9 (System Data): exit
database (14.07.2016 18:26:08): process terminated normally.
logger (14.07.2016 18:26:08): data logger stopped.
test5m (14.07.2016 18:26:09): USB storage remounted: /dev/sda
database (14.07.2016 18:26:09): process started.
logger (14.07.2016 18:26:09): databases connected. Update interval 3600 seconds.
logger (14.07.2016 18:26:09): Historical data loaded (0 records).
logger (14.07.2016 18:26:09): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 18:26:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:26:11): connect station 9 (System Data via Plug-in).
logger (14.07.2016 18:26:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 18:26:50): sync of internal databases done (69 tables)
logger (14.07.2016 18:27:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:27:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:28:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:28:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:29:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:29:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:30:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:30:41): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:31:11): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:31:21): parent process received termination signal (15).
logger (14.07.2016 18:31:21): child process received termination signal (15).
logger (14.07.2016 18:31:22): disconnect station 9 (System Data): exit
database (14.07.2016 18:31:22): process terminated normally.
logger (14.07.2016 18:31:23): data logger stopped.
test5m (14.07.2016 18:31:23): USB storage remounted: /dev/sda
database (14.07.2016 18:31:23): process started.
logger (14.07.2016 18:31:23): databases connected. Update interval 3600 seconds.
logger (14.07.2016 18:31:23): Historical data loaded (0 records).
logger (14.07.2016 18:31:23): data logger (version 5.0q, build 10179) started.
logger (14.07.2016 18:31:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:31:25): connect station 9 (System Data via Plug-in).
logger (14.07.2016 18:31:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
database (14.07.2016 18:32:05): sync of internal databases done (69 tables)
logger (14.07.2016 18:32:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:32:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:33:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:33:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:34:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:34:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:35:25): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
logger (14.07.2016 18:35:55): station 0 (Meteostick Vantage), can't open device /dev/ttyMH: No such file or directory
Device failing since 3.0
Re: Device failing since 3.0
This looks like a MB PRO and you seem to have USB storage problems.
Can you please post output of "http://ip-of-your-mbpro/cgi-bin/system.cgi?dmesg"?
