Frozen MBP but ok after reboot
peterb
Post by peterb »
Frozen MBP but ok after reboot screen stuck on info, no connection to DVP2, no uploads to internet. This is what system says:
system (08.09.2016 22:55:55): start of logging process initiated.
logger (08.09.2016 22:55:55): databases connected. Update interval 3600 seconds.
logger (08.09.2016 22:55:55): Historical data loaded (0 records).
logger (08.09.2016 22:55:55): data logger (version 5.0r, build 10289) started.
logger (08.09.2016 22:55:56): connect station 0 (Meteostick Vantage via USB serial).
logger (08.09.2016 22:55:56): connect station 9 (System Data via Plug-in).
logger (08.09.2016 22:55:56): transmitter 2 registered as Temperature
logger (08.09.2016 22:55:56): transmitter 3 registered as ISS
logger (08.09.2016 22:55:56): Meteostick Version 2.4
logger (08.09.2016 22:55:56): debug off
logger (08.09.2016 22:55:56): verbose off
logger (08.09.2016 22:55:56): output raw (8 bytes)
logger (08.09.2016 22:55:56): output raw (10 bytes)
logger (08.09.2016 22:55:56): filter on
logger (08.09.2016 22:55:56): rx threshold set to -80db
logger (08.09.2016 22:55:56): listening to transmitter 2 3
logger (08.09.2016 22:55:56): bandwidth normal
logger (08.09.2016 22:55:57): chip authentication ok: 14
logger (08.09.2016 22:55:57): frequency band 868MHz (EU)
logger (12.09.2016 05:04:38): child process received timeout signal (14).
logger (12.09.2016 05:04:39): disconnect station 0 (Meteostick Vantage): exit
Re: Frozen MBP but ok after reboot
Does screen freeze or RF reception or complete operation including admin browser pages?
