admin wrote:You can search for these two entries in the raw file "..../200808/raw" with your favorite text editor:
Thnak you.
I'd already found the lines using a combination of line number and search pattern. What I can't see is anything wrong with them.
(833364/5) you should find by searching for "rain1 0 0 4096"
[pre]20080829164702 t7 152
20080829164704 wind1 248 25 25 0149
20080829164712 rain1 0 0 4096
20080829164714 wind0 227 24 24 0149
20080829164715 t8 156[/pre]
(855307/8) you should find by searching for "104718 t8 179"
[pre]20080830104710 wind1 202 24 20 0163
20080830104716 th5 161 98 0158
20080830104718 t8 179
20080830104721 wind0 221 16 20 0163
20080830104721 th3 174 78 0135[/pre]
That's exactly as the lines are in the file - there are no extra characters in there disturbing the usual patterns.
Before I do the clean up I'll take an extra copy. Then I'll diff the two files afterwards.
PS. On restart of WD this morning the "latest data record" request is again working fine as hoped (i.e. since it is now looking at the new 2008-09 raw). :)
PPS. Sorry for being in a bit of a panic yesterday evening. I get nervous about things that might disturb the relatively stable state I have achieved with WD (and change of month is an especially busy time internally for WD).
PPPS. Since (I imagine) most of us don't look in meteohub log very often, might it be an idea to consider a "Send e-mail Notification" option for when an "illegal data record" occurs?
