I'm a new user of Meteobridge and I'm trying to connect a Oregon Scientific WMR200 with Meteobridge, flashed in a TP-Link TL-MR3020. I have a USB Hub between console and Meteobridge, but nothing happend. If I connect the weather station without the USB hub, an error message apear at Weather Station page, saying to connect a USB Hub. However, when I connect the hub, no error message and no weather data.
That's the log:
wnetd (08.05.2017 21:56:17): process started.
system (09.05.2017 00:56:17): start of logging process initiated.
logger (08.05.2017 21:56:17): no historical data loaded.
logger (08.05.2017 21:56:17): data logger (version 5.0v, build 11191) started.
logger (08.05.2017 21:56:18): connect station 0 (WMR-200 via USB HID).
logger (08.05.2017 21:56:21): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (08.05.2017 21:56:21): services paused.
logger (08.05.2017 21:58:18): give up waiting for sensors after 120 secs.
logger (08.05.2017 21:58:18): services activated.
logger (08.05.2017 22:01:49): child process received timeout signal (14).
logger (08.05.2017 22:01:49): disconnect station 0 (WMR-200): exit
logger (08.05.2017 22:01:49): data logger stopped.
logger (08.05.2017 22:01:49): no historical data loaded.
logger (08.05.2017 22:01:49): data logger (version 5.0v, build 11191) started.
logger (08.05.2017 22:01:50): connect station 0 (WMR-200 via USB HID).
logger (08.05.2017 22:01:53): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (08.05.2017 22:01:53): services paused.
logger (08.05.2017 22:03:50): give up waiting for sensors after 120 secs.
logger (08.05.2017 22:03:50): services activated.
logger (08.05.2017 22:07:20): child process received timeout signal (14).
logger (08.05.2017 22:07:20): disconnect station 0 (WMR-200): exit
logger (08.05.2017 22:07:21): data logger stopped.
logger (08.05.2017 22:07:21): no historical data loaded.
logger (08.05.2017 22:07:21): data logger (version 5.0v, build 11191) started.
logger (08.05.2017 22:07:21): connect station 0 (WMR-200 via USB HID).
logger (08.05.2017 22:07:25): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (08.05.2017 22:07:25): services paused.
logger (08.05.2017 22:09:22): give up waiting for sensors after 120 secs.
logger (08.05.2017 22:09:22): services activated.
logger (08.05.2017 22:12:51): child process received timeout signal (14).
logger (08.05.2017 22:12:52): disconnect station 0 (WMR-200): exit
logger (08.05.2017 22:12:52): data logger stopped.
logger (08.05.2017 22:12:52): no historical data loaded.
logger (08.05.2017 22:12:52): data logger (version 5.0v, build 11191) started.
logger (08.05.2017 22:12:53): connect station 0 (WMR-200 via USB HID).
logger (08.05.2017 22:12:56): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (08.05.2017 22:12:56): services paused.
When I connect my Davis Vantage Pro 2, Meteobridge works fine. Can be a problem with the USB Hub, or cables? Usb hub 2.0 is new and I use a Monster Cable USB to connect the console station to the USB Hub.
WMR200 and Meteobridge conection problems
Re: WMR200 and Meteobridge conection problems
Data hold seems to be limited to 120 secs. Please try 300 secs to avoid logger reboots.
USB hub can be an issue or bad RF reception of sensor data.
Sorry, where can I change data hold time?
Bad RF reception can't be, I'm testing with the sensors very close to console.
I just got one historical data uploaded, but then nothing more. Can be a USB cable issue befor USB hub?
MeteobridgeWessel wrote:Sorry, where can I change data hold time?
=> Tab: Weather Station
=> Nearly at the bottom: Local settings
=> Second line: Tolerated age of data, select the value from the dropdown
Do not set the sensors to close as that may cause interferenceBad RF reception can't be, I'm testing with the sensors very close to console.
Better test with another cable then alsoI just got one historical data uploaded, but then nothing more. Can be a USB cable issue befor USB hub?
