insane temperatures... **solved**
junkycosmos
Re: insane temperatures... **solved**
Post by junkycosmos »
Heya Dolfs
When you say you have sometimes seen contents of the live data pages during these issues. How do they display: with -- or with the extremely high temps ??
Agreed on trying to catch one live and get Boris in there to see might be tricky. I'm all for him seeing but timing is hard.
Seems the pattern is that the F temps being recoverted back to F as if they were C. (x2.3).
I still stand by my compliments to both Ed at Ambient Weather (observer ip 1400) and Boris here of Meteo. Both are responsive and have been able the driving forces in this tech.
I will try to setup an alert for anything over 100 degrees to see if I can catch this live.
Cheers
J
Meteobridge reads the page with the settings (where it finds Celsius or Fahrenheit) and the one with the current sensor data.
When no setting data is present, the last seen unit definition is used. This is what struggles me as I would expect a missing settings
page should not drive computation crazy. There must be something else happening to the settings page when the observerIP's
web interface goes mad...
junkycosmos
Agreed ! but who knows until we can catch this live, which reminds me to create a little alert program
Weather Temp Issue - [ID 00xx][Parent 000A]
If
Module 'Climate' Temperature >= 80 °F
Then
Send Notification to 'J_All'
comment::
has ISY send alert when weather temp is over 80 degrees F
Oberserver 1400 --> meteobridge (on MR3020)--> WeatherForYou/pwsweather --> ISY
of course this is only good until temps here reach winter zones since the pattern seems to be X2.3 real life
lrosenman
Post by lrosenman »
They (Ambient) have newer Firmware (4.3.1) that uses 2 TCP connections when you are doing BOTH WeatherUnderground and AmbientWeather.net.
It also removes the telnet server.
it seems to have MUCH better behavior with this new firmware.
https://www.ambientweather.com/wswsfiup.html
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
junkycosmos
Just had a reoccurrence of this issue but only for a few minutes today. Started and stoped all in its own. Note that my observer IP is on the newer firmware (4.3.1) as of Sep 30th.
12:03 PM 49.5°F 40.1°F 70% Calm - 29.72 in 0.00 in 0.00 in 0.03 in
12:02 PM 120.7°F 108.1°F 70% 0.7 mph ENE 2.5 mph 29.72 in 0.00 in 0.00 in 0.03 in
12:01 PM 120.7°F 108.1°F 70% 2.5 mph N 4.9 mph 29.72 in 0.00 in 0.00 in 0.03 in
11:59 AM 120.7°F 107.8°F 69% 0.2 mph NW 2.5 mph 29.72 in 0.00 in 0.00 in 0.03 in
11:58 AM 120.4°F 108.0°F 70% 0.7 mph NW 2.5 mph 29.72 in 0.00 in 0.00 in 0.03 in
11:54 AM 48.9°F 39.9°F 71% Calm - 29.71 in 0.00 in 0.00 in 0.03 in
11:53 AM 48.9°F 40.3°F 72% Calm -
lrosenman
Post by lrosenman »
I've seen it occasionally on the 4.3.1 Firmware. The Ambient Weather Firmware Guys are looking at their TCP stack.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
Is there a coincidence with data logger restarts? Messages section on "System" tab tells you about Meteobridge logger restarts.
WA4OPQ
Location: Tennessee, USA About 40 miles west of Nashville y'all.
Post by WA4OPQ »
I also have the problem with my Observer IP, it occurs about once a week. I've gotten used to doing power resets.
I have some beta code running, which preserves unit settings even when Meteobridge data logging process is restarted. When Irosenman reboots the Meteobridge it should run this beta code. Please report, if this fixes the issue.
lrosenman
Post by lrosenman »
I've rebooted and have the October 15 code. I'll keep watching it.
Thank You.
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
junkycosmos
Few more occurrences of it for me again. And currently happening
Wind Gusts Pressure Precip Precip Rate Daily Precip Total
02:31 PM 149.2°F 110.1°F 35% 1.6 mph S 2.5 mph 29.64 in 0.00 in 0.00 in 0.00 in
02:29 PM 149.2°F 108.1°F 33% Calm - 29.64 in 0.00 in 0.00 in 0.00 in
02:27 PM 149.2°F 108.1°F 33% 1.6 mph NE 4.9 mph 29.64 in 0.00 in 0.00 in 0.00 in
02:26 PM 64.9°F 35.1°F 33% Calm - 29.64 in 0.00 in 0.00 in 0.00 in
02:23 PM 64.9°F 35.1°F 33% Calm - 29.65 in 0.00 in 0.00 in 0.00 in
02:21 PM 64.9°F 35.1°F 33% 0.9 mph N 2.5 mph 29.65 in 0.00 in 0.00 in 0.00 in
02:19 PM 64.8°F 35.1°F 33% 1.8 mph S 2.5 mph 29.65 in 0.00 in 0.00 in 0.00 in
02:18 PM 64.8°F 35.1°F 33% 1.6 mph SSE 2.5 mph 29.65 in 0.00 in 0.00 in 0.00 in
02:17 PM 64.8°F 35.1°F 33% 1.3 mph SE 2.5 mph 29.65 in 0.00 in 0.00 in 0.00 in
02:16 PM 64.8°F 35.8°F 34% 5.4 mph SE - 29.65 in 0.00 in 0.00 in 0.00 in
02:14 PM 64.8°F 35.1°F 33% Calm - 29.65 in 0.00 in 0.00 in 0.00 in
02:13 PM 64.8°F 35.1°F 33% Calm - 29.66 in 0.00 in 0.00 in 0.00 in
02:12 PM 64.6°F 35.6°F 34% 0.2 mph NNE 2.5 mph 29.65 in 0.00 in 0.00 in 0.00 in
02:11 PM 64.6°F 34.9°F 33% Calm - 29.66 in 0.00 in 0.00 in 0.00 in
02:10 PM 64.4°F 34.7°F 33% 3.8 mph SE 4.9 mph 29.65 in 0.00 in 0.00 in 0.00 in
02:09 PM 64.4°F 34.7°F 33% Calm - 29.66 in 0.00 in 0.00 in 0.00 in
02:08 PM 64.2°F 34.5°F 33% Calm - 29.65 in 0.00 in 0.00 in 0.00 in
02:06 PM 64.2°F 35.2°F 34% 0.7 mph SE 2.5 mph 29.66 in 0.00 in 0.00 in 0.00 in
02:05 PM 64.2°F 34.5°F 33% Calm - 29.66 in 0.00 in 0.00 in 0.00 in
02:04 PM 64.0°F 33.6°F 32% 4.0 mph E - 29.66 in 0.00 in 0.00 in 0.00 in
02:03 PM 64.0°F 33.6°F 32% Calm - 29.66 in 0.00 in 0.00 in 0.00 in
02:01 PM 63.9°F 33.4°F 32% 0.9 mph SW 2.5 mph 29.66 in 0.00 in 0.00 in 0.00 in
02:00 PM 63.9°F 33.4°F 32% 0.2 mph NE - 29.67 in 0.00 in 0.00 in 0.00 in
01:58 PM 63.7°F 34.7°F 34% 3.4 mph SE - 29.66 in 0.00 in 0.00 in 0.00 in
01:56 PM 63.7°F 34.0°F 33% Calm - 29.66 in 0.00 in 0.00 in 0.00 in
01:52 PM 63.5°F 32.4°F 31% Calm - 29.67 in 0.00 in 0.00 in 0.00 in
01:51 PM 63.5°F 32.4°F 31% 2.9 mph SE 4.9 mph 29.67 in 0.00 in 0.00 in 0.00 in
01:50 PM 63.3°F 32.2°F 31% 1.3 mph NW 2.5 mph 29.67 in 0.00 in 0.00 in 0.00 in
01:49 PM 63.3°F 32.9°F 32% Calm - 29.67 in 0.00 in 0.00 in 0.00 in
01:48 PM 63.3°F 33.8°F 33% 5.4 mph NE 7.6 mph 29.67 in 0.00 in 0.00 in 0.00 in
01:46 PM 63.1°F 33.6°F 33% 1.6 mph SSE 2.5 mph 29.67 in 0.00 in 0.00 in 0.00 in
01:45 PM 63.0°F 33.4°F 33% Calm - 29.67 in 0.00 in 0.00 in 0.00 in
01:41 PM 63.0°F 31.1°F 30% 0.7 mph WSW - 29.68 in 0.00 in 0.00 in 0.00 in
01:39 PM 63.0°F 31.1°F 30% Calm - 29.68 in 0.00 in 0.00 in 0.00 in
01:38 PM 63.0°F 31.1°F 30% 0.2 mph ENE 2.5 mph 29.68 in 0.00 in 0.00 in 0.00 in
01:37 PM 62.8°F 32.5°F 32% 5.6 mph SE 7.6 mph 29.68 in 0.00 in 0.00 in 0.00 in
01:36 PM 62.8°F 30.9°F 30% Calm - 29.68 in 0.00 in 0.00 in 0.00 in
01:32 PM 62.6°F 30.7°F 30% 1.6 mph NE 2.5 mph 29.68 in 0.00 in 0.00 in 0.00 in
01:30 PM 62.6°F 30.7°F 30% 2.9 mph SE 4.9 mph 29.68 in 0.00 in 0.00 in 0.00 in
01:29 PM 62.6°F 30.7°F 30% 3.8 mph SE 4.9 mph 29.68 in 0.00 in 0.00 in 0.00 in
01:27 PM 62.4°F 31.5°F 31% 1.6 mph SSW - 29.69 in 0.00 in 0.00 in 0.00 in
01:24 PM 62.2°F 31.3°F 31% 1.3 mph ENE 2.5 mph 29.69 in 0.00 in 0.00 in 0.00 in
01:23 PM 62.2°F 31.3°F 31% 0.2 mph S - 29.69 in 0.00 in 0.00 in 0.00 in
01:21 PM 62.2°F 31.3°F 31% 0.7 mph SE 2.5 mph 29.69 in 0.00 in 0.00 in 0.00 in
01:20 PM 62.1°F 31.1°F 31% 0.7 mph S - 29.69 in 0.00 in 0.00 in 0.00 in
01:19 PM 62.1°F 31.1°F 31% 4.0 mph SSW 4.9 mph 29.70 in 0.00 in 0.00 in 0.00 in
01:17 PM 143.8°F 102.6°F 32% Calm - 29.70 in 0.00 in 0.00 in 0.00 in
01:16 PM 61.9°F 31.6°F 32% 3.4 mph S - 29.69 in 0.00 in 0.00 in 0.00 in
01:13 PM 61.9°F 31.6°F 32% Calm - 29.70 in 0.00 in 0.00 in 0.00 in
01:11 PM 61.7°F 31.5°F 32% Calm - 29.70 in 0.00 in 0.00 in 0.00 in
01:10 PM 61.7°F 30.7°F 31% 2.2 mph SE 2.5 mph 29.70 in 0.00 in 0.00 in 0.00 in
01:09 PM 61.7°F 31.5°F 32% Calm - 29.70 in 0.00 in 0.00 in 0.00 in
01:08 PM 61.7°F 31.5°F 32% Calm - 29.70 in 0.00 in 0.00 in 0.00 in
01:05 PM 61.5°F 32.2°F 33% 0.2 mph NE 2.5 mph 29.70 in 0.00 in 0.00 in 0.00 in
01:03 PM 61.3°F 32.0°F 33% 0.9 mph NNW 2.5 mph 29.70 in 0.00 in 0.00 in 0.00 in
01:01 PM 61.3°F 33.4°F 35% 0.7 mph WSW 2.5 mph 29.70 in 0.00 in 0.00 in 0.00 in
01:00 PM 61.3°F 33.4°F 35% Calm - 29.70 in 0.00 in 0.00 in 0.00 in
12:59 PM 61.2°F 34.0°F 36% 2.5 mph SE - 29.71 in 0.00 in 0.00 in 0.00 in
12:56 PM 61.2°F 32.5°F 34% 0.2 mph SW 2.5 mph 29.71 in 0.00 in 0.00 in 0.00 in
12:55 PM 61.2°F 31.8°F 33% Calm - 29.71 in 0.00 in 0.00 in 0.00 in
12:54 PM 61.0°F 31.6°F 33% Calm - 29.71 in 0.00 in 0.00 in 0.00 in
12:52 PM 61.0°F 31.6°F 33% 0.2 mph N 2.5 mph 29.71 in 0.00 in 0.00 in 0.00 in
12:51 PM 61.0°F 31.6°F 33% 3.1 mph N 4.9 mph 29.71 in 0.00 in 0.00 in 0.00 in
12:50 PM 61.0°F 31.6°F 33% Calm - 29.71 in 0.00 in 0.00 in 0.00 in
12:49 PM 60.8°F 30.7°F 32% Calm - 29.71 in 0.00 in 0.00 in 0.00 in
12:48 PM 60.8°F 30.7°F 32% 0.9 mph S 2.5 mph 29.72 in 0.00 in 0.00 in 0.00 in
12:47 PM 60.8°F 31.5°F 33% 1.8 mph ESE 2.5 mph 29.71 in 0.00 in 0.00 in 0.00 in
12:46 PM 60.6°F 31.3°F 33% Calm - 29.72 in 0.00 in 0.00 in 0.00 in
12:45 PM 60.6°F 31.3°F 33% Calm - 29.72 in 0.00 in 0.00 in 0.00 in
12:43 PM 60.6°F 31.3°F 33% 1.8 mph SSE - 29.72 in 0.00 in 0.00 in 0.00 in
12:38 PM 60.3°F 31.8°F 34% 0.9 mph S 2.5 mph 29.72 in 0.00 in 0.00 in 0.00 in
12:37 PM 60.3°F 31.1°F 33% 2.9 mph SE - 29.72 in 0.00 in 0.00 in 0.00 in
12:35 PM 60.3°F 31.1°F 33% Calm - 29.72 in 0.00 in 0.00 in 0.00 in
12:34 PM 60.1°F 31.6°F 34% Calm - 29.72 in 0.00 in 0.00 in 0.00 in
12:32 PM 60.1°F 30.9°F 33% 0.9 mph ENE 2.5 mph 29.72 in 0.00 in 0.00 in 0.00 in
12:31 PM 59.9°F 31.5°F 34% Calm - 29.72 in 0.00 in 0.00 in 0.00 in
12:30 PM 59.9°F 32.2°F 35% 2.9 mph SSE 4.9 mph 29.72 in 0.00 in 0.00 in 0.00 in
12:29 PM 59.9°F 31.5°F 34% Calm - 29.72 in 0.00 in 0.00 in 0.00 in
12:28 PM 59.7°F 30.6°F 33% Calm - 29.72 in 0.00 in 0.00 in 0.00 in
12:27 PM 59.7°F 31.3°F 34% 4.0 mph S 4.9 mph 29.74 in 0.00 in 0.00 in 0.00 in
12:26 PM 59.5°F 30.4°F 33% Calm - 29.74 in 0.00 in 0.00 in 0.00 in
12:25 PM 59.4°F 31.6°F 35% 4.9 mph SE - 29.72 in 0.00 in 0.00 in 0.00 in
12:23 PM 59.2°F 32.2°F 36% Calm - 29.74 in 0.00 in 0.00 in 0.00 in
12:21 PM 59.0°F 33.4°F 38% Calm - 29.74 in 0.00 in 0.00 in 0.00 in
12:19 PM 58.8°F 33.3°F 38% Calm - 29.74 in 0.00 in 0.00 in 0.00 in
12:18 PM 58.6°F 32.4°F 37% Calm - 29.74 in 0.00 in 0.00 in 0.00 in
12:16 PM 58.5°F 32.9°F 38% 3.4 mph S 4.9 mph 29.74 in 0.00 in 0.00 in 0.00 in
12:15 PM 58.3°F 33.4°F 39% 2.5 mph ESE 4.9 mph 29.74 in 0.00 in 0.00 in 0.00 in
12:14 PM 58.1°F 34.0°F 40% 0.9 mph SE 2.5 mph 29.74 in 0.00 in 0.00 in 0.00 in
12:13 PM 57.9°F 34.3°F 41% Calm - 29.74 in 0.00 in 0.00 in 0.00 in
12:11 PM 57.7°F 33.6°F 40% Calm - 29.74 in 0.00 in 0.00 in 0.00 in
12:10 PM 57.6°F 33.4°F 40% Calm - 29.74 in 0.00 in 0.00 in 0.00 in
12:09 PM 57.4°F 33.3°F 40% 0.7 mph SSE 2.5 mph 29.74 in 0.00 in 0.00 in 0.00 in
12:07 PM 57.2°F 33.1°F 40% 6.9 mph SE 10.1 mph 29.74 in 0.00 in 0.00 in 0.00 in
12:06 PM 57.2°F 33.6°F 41% 0.7 mph S 2.5 mph 29.74 in 0.00 in 0.00 in 0.00 in
12:05 PM 57.0°F 33.6°F 41% Calm - 29.75 in 0.00 in 0.00 in 0.00 in
12:02 PM 56.5°F 33.6°F 42% Calm - 29.75 in 0.00 in 0.00 in 0.00 in
12:01 PM 56.3°F 33.4°F 42% 0.2 mph NE 2.5 mph 29.75 in 0.00 in 0.00 in 0.00 in
11:58 AM 55.9°F 33.8°F 43% Calm - 29.75 in 0.00 in 0.00 in 0.00 in
11:54 AM 55.2°F 33.6°F 44% 1.3 mph SSE 2.5 mph 29.75 in 0.00 in 0.00 in 0.00 in
11:51 AM 55.0°F 34.2°F 45% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:50 AM 54.9°F 34.5°F 46% 4.7 mph S - 29.75 in 0.00 in 0.00 in 0.00 in
11:49 AM 54.9°F 35.6°F 48% Calm - 29.75 in 0.00 in 0.00 in 0.00 in
11:48 AM 54.5°F 34.7°F 47% Calm - 29.75 in 0.00 in 0.00 in 0.00 in
11:46 AM 54.5°F 34.2°F 46% 0.7 mph SSW 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:45 AM 54.3°F 34.0°F 46% 3.8 mph SSE 4.9 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:44 AM 54.1°F 34.3°F 47% 1.3 mph E 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:43 AM 54.0°F 35.2°F 49% 1.6 mph NNW 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:40 AM 53.8°F 35.6°F 50% 0.2 mph S 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:38 AM 53.6°F 34.9°F 49% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:37 AM 53.4°F 35.8°F 51% 4.0 mph SE 4.9 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:36 AM 53.2°F 35.1°F 50% 2.2 mph S 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:35 AM 53.2°F 35.1°F 50% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:33 AM 53.1°F 35.4°F 51% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:32 AM 52.9°F 35.2°F 51% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:30 AM 52.9°F 35.2°F 51% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:29 AM 52.7°F 35.1°F 51% 2.5 mph NW 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:28 AM 52.7°F 35.1°F 51% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:26 AM 52.5°F 35.4°F 52% 0.2 mph E 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:25 AM 52.5°F 35.4°F 52% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:22 AM 52.3°F 35.2°F 52% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:19 AM 52.2°F 35.6°F 53% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:18 AM 52.0°F 35.8°F 54% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:17 AM 52.0°F 35.8°F 54% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:15 AM 51.8°F 35.6°F 54% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:13 AM 51.6°F 36.0°F 55% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:09 AM 51.4°F 35.4°F 54% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:08 AM 51.3°F 35.2°F 54% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:07 AM 51.3°F 34.7°F 53% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:05 AM 51.1°F 34.5°F 53% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
11:04 AM 51.1°F 35.1°F 54% 1.3 mph NNE 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
11:03 AM 50.9°F 34.9°F 54% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:02 AM 50.9°F 34.9°F 54% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
11:01 AM 50.7°F 35.1°F 55% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
10:59 AM 50.5°F 35.1°F 55% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:58 AM 50.5°F 35.4°F 56% 0.7 mph E 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
10:57 AM 50.4°F 34.9°F 55% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
10:54 AM 50.0°F 35.4°F 57% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:50 AM 49.8°F 36.1°F 59% 1.3 mph SE 2.5 mph 29.77 in 0.00 in 0.00 in 0.00 in
10:49 AM 49.6°F 36.3°F 60% 0.2 mph ESE 2.5 mph 29.76 in 0.00 in 0.00 in 0.00 in
10:48 AM 49.6°F 36.7°F 61% 2.5 mph S 4.9 mph 29.76 in 0.00 in 0.00 in 0.00 in
10:47 AM 49.5°F 36.5°F 61% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
10:46 AM 49.5°F 36.5°F 61% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
10:45 AM 49.3°F 36.3°F 61% 2.2 mph SE 4.9 mph 29.76 in 0.00 in 0.00 in 0.00 in
10:44 AM 49.1°F 36.3°F 61% Calm - 29.76 in 0.00 in 0.00 in 0.00 in
10:42 AM 48.9°F 36.1°F 61% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:41 AM 48.7°F 36.0°F 61% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:39 AM 48.6°F 35.8°F 61% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:38 AM 48.4°F 35.6°F 61% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:36 AM 48.2°F 36.1°F 63% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:34 AM 48.0°F 35.6°F 62% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:33 AM 47.8°F 35.8°F 63% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:31 AM 47.7°F 36.1°F 64% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:26 AM 47.1°F 35.6°F 64% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:22 AM 46.8°F 35.6°F 65% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:21 AM 46.8°F 35.6°F 65% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:19 AM 46.6°F 35.4°F 65% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:18 AM 46.4°F 35.6°F 66% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:16 AM 46.4°F 36.0°F 67% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:15 AM 46.2°F 36.7°F 69% 1.3 mph E 2.5 mph 29.78 in 0.00 in 0.00 in 0.00 in
10:14 AM 46.2°F 36.7°F 69% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:11 AM 114.8°F 103.5°F 72% 3.1 mph SSE 4.9 mph 29.77 in 0.00 in 0.00 in 0.00 in
10:10 AM 114.6°F 103.3°F 72% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:09 AM 45.7°F 37.2°F 72% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:07 AM 45.7°F 37.6°F 73% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:06 AM 45.5°F 37.4°F 73% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:05 AM 45.5°F 37.4°F 73% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:03 AM 45.1°F 37.0°F 73% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
10:02 AM 45.1°F 37.0°F 73% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
10:01 AM 45.0°F 36.9°F 73% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:59 AM 44.8°F 36.3°F 72% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:58 AM 44.8°F 36.3°F 72% Calm - 29.78 in 0.00 in 0.00 in 0.00 in
09:56 AM 111.9°F 100.8°F 72% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:55 AM 44.2°F 35.8°F 72% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:53 AM 44.1°F 35.6°F 72% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:52 AM 43.9°F 35.4°F 72% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:49 AM 43.7°F 35.6°F 73% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:48 AM 43.5°F 35.4°F 73% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:47 AM 43.3°F 35.6°F 74% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:45 AM 43.3°F 36.0°F 75% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:44 AM 43.2°F 36.1°F 76% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:43 AM 43.0°F 36.0°F 76% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:41 AM 109.0°F 100.6°F 78% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:38 AM 108.3°F 100.8°F 80% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:37 AM 108.1°F 100.9°F 81% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:35 AM 42.1°F 37.0°F 82% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:32 AM 41.7°F 36.9°F 83% Calm - 29.77 in 0.00 in 0.00 in 0.00 in
09:31 AM 41.7°F 37.2°F 84% Calm -
Is there a coincidence with data logger restarts (can be seen in "messages" section of "System" tab )?
Can you please send me the MAC of your Meteobridge? info(at)meteobridge.com
I have some beta code you might like to have a test drive with.
lrosenman
Post by lrosenman »
It got slower again, and your beta code did NOT handle it:
observerip=# select * from response_time order by date_response desc limit 20;
         date_response         | response_time
 2017-10-19 21:55:22.302791-05 |         22.28
 2017-10-19 21:50:35.695418-05 |         35.66
 2017-10-19 21:45:24.197975-05 |         24.17
 2017-10-19 21:40:27.597409-05 |         27.57
 2017-10-19 21:35:29.522276-05 |         29.48
 2017-10-19 21:30:17.833846-05 |         17.66
 2017-10-19 21:25:23.49469-05  |         23.47
 2017-10-19 21:20:19.119392-05 |         19.09
 2017-10-19 21:15:23.949588-05 |         23.86
 2017-10-19 21:10:17.424158-05 |          17.4
 2017-10-19 21:05:30.285919-05 |         30.26
 2017-10-19 21:00:22.167189-05 |         22.12
 2017-10-19 20:55:24.822076-05 |         24.72
 2017-10-19 20:50:38.974765-05 |         38.82
 2017-10-19 20:45:16.217544-05 |         16.19
 2017-10-19 20:40:17.560105-05 |         17.53
 2017-10-19 20:35:31.495132-05 |         31.46
 2017-10-19 20:30:33.393568-05 |         33.36
 2017-10-19 20:25:05.920797-05 |          5.83
 2017-10-19 20:20:14.014432-05 |         13.98
(20 rows)
weather=# select count(*) from raw_query where data ilike '%tempf=1__._%' and date_sub >'2017-10-19';
 count
    10
(1 row)
weather=#
select * from raw_query where data ilike '%tempf=1__._%' and date_sub >'2017-10-19 ';
        date_sub        |        data
 2017-10-19 21:42:36-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:42:29&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
 2017-10-19 21:42:41-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:42:35&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
 2017-10-19 21:42:43-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:42:41&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
 2017-10-19 21:42:49-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:42:47&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
 2017-10-19 21:42:55-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:42:53&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
 2017-10-19 21:43:01-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:42:59&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
 2017-10-19 21:43:07-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:43:05&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
 2017-10-19 21:43:13-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:43:11&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
 2017-10-19 21:43:19-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:43:17&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
 2017-10-19 21:43:24-05 | tempf=160.9&windchillf=135.7&winddir=241&windspeedmph=0.00&windgustmph=2.46&humidity=70.0&dewptf=146.3&rainin=0.00&dailyrainin=0.00&monthlyrainin=0.89&yearlyrainin=23.78&solarradiation=0.00&UV=0.0&indoortempf=164.1&indoorhumidity=48.0&baromin=29.34&absbaromin=30.05&lowbatt=0&dateutc=2017-10-20%2002:43:23&softwaretype=MB%203.4(11558)%20Observer-IP%20DIR-505&action=updateraw&realtime=1&rtfreq=5&heatindex=666.7
(10 rows)
weather=#
During the *SAME* period, weewx running on another server, reading the SAME observerIP, had a couple of timeouts, but no bad data:
Oct 19 19:25:52 borg weewx[22147]: observerip: direct retrieval failed attempt 1 of 5: timed out
Oct 19 19:30:19 borg weewx[22147]: manager: Added record 2017-10-19 19:30:00 CDT (1508459400) to database 'weewx.sdb'
Oct 19 19:30:19 borg weewx[22147]: manager: Added record 2017-10-19 19:30:00 CDT (1508459400) to daily summary in 'weewx.sdb'
Oct 19 19:35:36 borg weewx[22147]: manager: Added record 2017-10-19 19:35:00 CDT (1508459700) to database 'weewx.sdb'
Oct 19 19:35:36 borg weewx[22147]: manager: Added record 2017-10-19 19:35:00 CDT (1508459700) to daily summary in 'weewx.sdb'
Oct 19 19:40:19 borg weewx[22147]: manager: Added record 2017-10-19 19:40:00 CDT (1508460000) to database 'weewx.sdb'
Oct 19 19:40:19 borg weewx[22147]: manager: Added record 2017-10-19 19:40:00 CDT (1508460000) to daily summary in 'weewx.sdb'
Oct 19 19:45:42 borg weewx[22147]: manager: Added record 2017-10-19 19:45:00 CDT (1508460300) to database 'weewx.sdb'
Oct 19 19:45:42 borg weewx[22147]: manager: Added record 2017-10-19 19:45:00 CDT (1508460300) to daily summary in 'weewx.sdb'
Oct 19 19:50:17 borg weewx[22147]: manager: Added record 2017-10-19 19:50:00 CDT (1508460600) to database 'weewx.sdb'
Oct 19 19:50:17 borg weewx[22147]: manager: Added record 2017-10-19 19:50:00 CDT (1508460600) to daily summary in 'weewx.sdb'
Oct 19 19:55:44 borg weewx[22147]: manager: Added record 2017-10-19 19:55:00 CDT (1508460900) to database 'weewx.sdb'
Oct 19 19:55:44 borg weewx[22147]: manager: Added record 2017-10-19 19:55:00 CDT (1508460900) to daily summary in 'weewx.sdb'
Oct 19 20:00:20 borg weewx[22147]: manager: Added record 2017-10-19 20:00:00 CDT (1508461200) to database 'weewx.sdb'
Oct 19 20:00:20 borg weewx[22147]: manager: Added record 2017-10-19 20:00:00 CDT (1508461200) to daily summary in 'weewx.sdb'
Oct 19 20:05:23 borg weewx[22147]: manager: Added record 2017-10-19 20:05:00 CDT (1508461500) to database 'weewx.sdb'
Oct 19 20:05:23 borg weewx[22147]: manager: Added record 2017-10-19 20:05:00 CDT (1508461500) to daily summary in 'weewx.sdb'
Oct 19 20:10:38 borg weewx[22147]: manager: Added record 2017-10-19 20:10:00 CDT (1508461800) to database 'weewx.sdb'
Oct 19 20:10:38 borg weewx[22147]: manager: Added record 2017-10-19 20:10:00 CDT (1508461800) to daily summary in 'weewx.sdb'
Oct 19 20:15:36 borg weewx[22147]: manager: Added record 2017-10-19 20:15:00 CDT (1508462100) to database 'weewx.sdb'
Oct 19 20:15:36 borg weewx[22147]: manager: Added record 2017-10-19 20:15:00 CDT (1508462100) to daily summary in 'weewx.sdb'
Oct 19 20:20:15 borg weewx[22147]: manager: Added record 2017-10-19 20:20:00 CDT (1508462400) to database 'weewx.sdb'
Oct 19 20:20:15 borg weewx[22147]: manager: Added record 2017-10-19 20:20:00 CDT (1508462400) to daily summary in 'weewx.sdb'
Oct 19 20:25:25 borg weewx[22147]: manager: Added record 2017-10-19 20:25:00 CDT (1508462700) to database 'weewx.sdb'
Oct 19 20:25:25 borg weewx[22147]: manager: Added record 2017-10-19 20:25:00 CDT (1508462700) to daily summary in 'weewx.sdb'
Oct 19 20:30:47 borg weewx[22147]: manager: Added record 2017-10-19 20:30:00 CDT (1508463000) to database 'weewx.sdb'
Oct 19 20:30:47 borg weewx[22147]: manager: Added record 2017-10-19 20:30:00 CDT (1508463000) to daily summary in 'weewx.sdb'
Oct 19 20:35:36 borg weewx[22147]: manager: Added record 2017-10-19 20:35:00 CDT (1508463300) to database 'weewx.sdb'
Oct 19 20:35:36 borg weewx[22147]: manager: Added record 2017-10-19 20:35:00 CDT (1508463300) to daily summary in 'weewx.sdb'
Oct 19 20:41:02 borg weewx[22147]: manager: Added record 2017-10-19 20:40:00 CDT (1508463600) to database 'weewx.sdb'
Oct 19 20:41:02 borg weewx[22147]: manager: Added record 2017-10-19 20:40:00 CDT (1508463600) to daily summary in 'weewx.sdb'
Oct 19 20:45:14 borg weewx[22147]: manager: Added record 2017-10-19 20:45:00 CDT (1508463900) to database 'weewx.sdb'
Oct 19 20:45:14 borg weewx[22147]: manager: Added record 2017-10-19 20:45:00 CDT (1508463900) to daily summary in 'weewx.sdb'
Oct 19 20:50:57 borg weewx[22147]: manager: Added record 2017-10-19 20:50:00 CDT (1508464200) to database 'weewx.sdb'
Oct 19 20:50:57 borg weewx[22147]: manager: Added record 2017-10-19 20:50:00 CDT (1508464200) to daily summary in 'weewx.sdb'
Oct 19 20:55:25 borg weewx[22147]: manager: Added record 2017-10-19 20:55:00 CDT (1508464500) to database 'weewx.sdb'
Oct 19 20:55:25 borg weewx[22147]: manager: Added record 2017-10-19 20:55:00 CDT (1508464500) to daily summary in 'weewx.sdb'
Oct 19 21:01:03 borg weewx[22147]: manager: Added record 2017-10-19 21:00:00 CDT (1508464800) to database 'weewx.sdb'
Oct 19 21:01:03 borg weewx[22147]: manager: Added record 2017-10-19 21:00:00 CDT (1508464800) to daily summary in 'weewx.sdb'
Oct 19 21:05:30 borg weewx[22147]: manager: Added record 2017-10-19 21:05:00 CDT (1508465100) to database 'weewx.sdb'
Oct 19 21:05:30 borg weewx[22147]: manager: Added record 2017-10-19 21:05:00 CDT (1508465100) to daily summary in 'weewx.sdb'
Oct 19 21:10:30 borg weewx[22147]: manager: Added record 2017-10-19 21:10:00 CDT (1508465400) to database 'weewx.sdb'
Oct 19 21:10:30 borg weewx[22147]: manager: Added record 2017-10-19 21:10:00 CDT (1508465400) to daily summary in 'weewx.sdb'
Oct 19 21:15:28 borg weewx[22147]: manager: Added record 2017-10-19 21:15:00 CDT (1508465700) to database 'weewx.sdb'
Oct 19 21:15:28 borg weewx[22147]: manager: Added record 2017-10-19 21:15:00 CDT (1508465700) to daily summary in 'weewx.sdb'
Oct 19 21:20:39 borg weewx[22147]: manager: Added record 2017-10-19 21:20:00 CDT (1508466000) to database 'weewx.sdb'
Oct 19 21:20:39 borg weewx[22147]: manager: Added record 2017-10-19 21:20:00 CDT (1508466000) to daily summary in 'weewx.sdb'
Oct 19 21:26:16 borg weewx[22147]: manager: Added record 2017-10-19 21:25:00 CDT (1508466300) to database 'weewx.sdb'
Oct 19 21:26:16 borg weewx[22147]: manager: Added record 2017-10-19 21:25:00 CDT (1508466300) to daily summary in 'weewx.sdb'
Oct 19 21:30:27 borg weewx[22147]: manager: Added record 2017-10-19 21:30:00 CDT (1508466600) to database 'weewx.sdb'
Oct 19 21:30:27 borg weewx[22147]: manager: Added record 2017-10-19 21:30:00 CDT (1508466600) to daily summary in 'weewx.sdb'
Oct 19 21:35:59 borg weewx[22147]: manager: Added record 2017-10-19 21:35:00 CDT (1508466900) to database 'weewx.sdb'
Oct 19 21:35:59 borg weewx[22147]: manager: Added record 2017-10-19 21:35:00 CDT (1508466900) to daily summary in 'weewx.sdb'
Oct 19 21:40:27 borg weewx[22147]: manager: Added record 2017-10-19 21:40:00 CDT (1508467200) to database 'weewx.sdb'
Oct 19 21:40:27 borg weewx[22147]: manager: Added record 2017-10-19 21:40:00 CDT (1508467200) to daily summary in 'weewx.sdb'
Oct 19 21:45:20 borg weewx[22147]: manager: Added record 2017-10-19 21:45:00 CDT (1508467500) to database 'weewx.sdb'
Oct 19 21:45:20 borg weewx[22147]: manager: Added record 2017-10-19 21:45:00 CDT (1508467500) to daily summary in 'weewx.sdb'
Oct 19 21:50:24 borg weewx[22147]: manager: Added record 2017-10-19 21:50:00 CDT (1508467800) to database 'weewx.sdb'
Oct 19 21:50:24 borg weewx[22147]: manager: Added record 2017-10-19 21:50:00 CDT (1508467800) to daily summary in 'weewx.sdb'
Oct 19 21:55:44 borg weewx[22147]: manager: Added record 2017-10-19 21:55:00 CDT (1508468100) to database 'weewx.sdb'
Oct 19 21:55:44 borg weewx[22147]: manager: Added record 2017-10-19 21:55:00 CDT (1508468100) to daily summary in 'weewx.sdb'
Oct 19 22:00:14 borg weewx[22147]: manager: Added record 2017-10-19 22:00:00 CDT (1508468400) to database 'weewx.sdb'
Oct 19 22:00:14 borg weewx[22147]: manager: Added record 2017-10-19 22:00:00 CDT (1508468400) to daily summary in 'weewx.sdb'
Oct 19 22:02:02 borg weewx[22147]: observerip: direct retrieval failed attempt 1 of 5: timed out
Oct 19 22:05:25 borg weewx[22147]: manager: Added record 2017-10-19 22:05:00 CDT (1508468700) to database 'weewx.sdb'
Oct 19 22:05:25 borg weewx[22147]: manager: Added record 2017-10-19 22:05:00 CDT (1508468700) to daily summary in 'weewx.sdb'
borg.lerctr.org /home/ler $
the weewx is public at:
http://home.lerctr.org:8888/~ler/weewx/
Larry Rosenman
Round Rock, TX USA
http://sienawx.com
junkycosmos
28 degrees outside just became 82
In other words it is happening again right now
Are you using latest Meteobridge version? 3.5?
