bad UV readings
aeng2
bad UV readings
Post by aeng2 »
I have sometimes bad uv readings (7 minutes no readings). How is that possible?
I use a Meteobridge Pro and Davis VP2+
aeng2
Re: bad UV readings
Post by aeng2 »
solar sensor same problem
aeng2
Re: bad UV readings
Post by aeng2 »
problem solved. Change te position from the meteobridge Pro (better reception).
