Cannot connect to VP2 datalogger
Clément
Post by Clément »
It seems that the Meteobridge has some difficulties to connect to my VP2 datalogger...
Here is the log:
wnetd (30.11.2017 21:23:28): process started.
system (30.11.2017 21:23:28): start of logging process initiated.
logger (30.11.2017 21:23:28): no historical data loaded.
logger (30.11.2017 21:23:28): data logger (version 5.0w, build 11648) started.
logger (30.11.2017 21:23:29): connect station 0 (Vantage via USB serial).
logger (30.11.2017 21:23:29): wakeup sent.
logger (30.11.2017 21:23:29): internal logger activated.
logger (30.11.2017 21:23:29): syncing.
logger (30.11.2017 21:23:32): waiting for sensors (wind0, rain0, th0, thb0) to provide data.
logger (30.11.2017 21:23:32): services paused.
logger (30.11.2017 21:23:39): gettime request sent.
logger (30.11.2017 21:23:59): message above repeats 2 times.
logger (30.11.2017 21:24:09): disconnect station 0 (Vantage): timeout
logger (30.11.2017 21:24:39): connect station 0 (Vantage via USB serial).
logger (30.11.2017 21:24:39): wakeup sent.
logger (30.11.2017 21:24:39): internal logger activated.
logger (30.11.2017 21:24:39): syncing.
logger (30.11.2017 21:24:49): gettime request sent.
logger (30.11.2017 21:25:09): message above repeats 2 times.
logger (30.11.2017 21:25:19): disconnect station 0 (Vantage): timeout
logger (30.11.2017 21:25:29): give up waiting for sensors after 120 secs.
logger (30.11.2017 21:25:29): services activated.
logger (30.11.2017 21:25:49): connect station 0 (Vantage via USB serial).
logger (30.11.2017 21:25:49): wakeup sent.
logger (30.11.2017 21:25:49): internal logger activated.
logger (30.11.2017 21:25:49): syncing.
logger (30.11.2017 21:25:59): gettime request sent.
logger (30.11.2017 21:26:19): message above repeats 2 times.
logger (30.11.2017 21:26:29): disconnect station 0 (Vantage): timeout
logger (30.11.2017 21:26:59): connect station 0 (Vantage via USB serial).
logger (30.11.2017 21:26:59): wakeup sent.
logger (30.11.2017 21:26:59): internal logger activated.
logger (30.11.2017 21:26:59): syncing.
logger (30.11.2017 21:27:09): gettime request sent.
logger (30.11.2017 21:27:29): message above repeats 2 times.
logger (30.11.2017 21:27:39): disconnect station 0 (Vantage): timeout
logger (30.11.2017 21:28:09): connect station 0 (Vantage via USB serial).
logger (30.11.2017 21:28:09): wakeup sent.
logger (30.11.2017 21:28:09): internal logger activated.
logger (30.11.2017 21:28:09): syncing.
logger (30.11.2017 21:28:19): gettime request sent.
logger (30.11.2017 21:28:39): message above repeats 2 times.
logger (30.11.2017 21:28:49): disconnect station 0 (Vantage): timeout
logger (30.11.2017 21:28:51): usb port reset.
logger (30.11.2017 21:29:19): connect station 0 (Vantage via USB serial).
logger (30.11.2017 21:29:19): wakeup sent.
logger (30.11.2017 21:29:19): internal logger activated.
logger (30.11.2017 21:29:19): syncing.
logger (30.11.2017 21:29:29): gettime request sent.
logger (30.11.2017 21:29:49): message above repeats 2 times.
logger (30.11.2017 21:29:59): disconnect station 0 (Vantage): timeout
logger (30.11.2017 21:30:01): usb port reset.
logger (30.11.2017 21:30:29): connect station 0 (Vantage via USB serial).
logger (30.11.2017 21:30:29): wakeup sent.
logger (30.11.2017 21:30:29): internal logger activated.
logger (30.11.2017 21:30:29): syncing.
logger (30.11.2017 21:30:39): gettime request sent.
logger (30.11.2017 21:30:59): message above repeats 2 times.
logger (30.11.2017 21:31:09): disconnect station 0 (Vantage): timeout
logger (30.11.2017 21:31:11): usb port reset.
logger (30.11.2017 21:31:39): connect station 0 (Vantage via USB serial).
logger (30.11.2017 21:31:39): wakeup sent.
logger (30.11.2017 21:31:39): internal logger activated.
logger (30.11.2017 21:31:39): syncing.
logger (30.11.2017 21:31:49): gettime request sent.
logger (30.11.2017 21:32:09): message above repeats 2 times.
logger (30.11.2017 21:32:19): disconnect station 0 (Vantage): timeout
logger (30.11.2017 21:32:21): usb port reset.
logger (30.11.2017 21:32:49): connect station 0 (Vantage via USB serial).
logger (30.11.2017 21:32:49): wakeup sent.
logger (30.11.2017 21:32:49): internal logger activated.
logger (30.11.2017 21:32:49): syncing.
logger (30.11.2017 21:32:59): gettime request sent.
logger (30.11.2017 21:33:19): message above repeats 2 times.
logger (30.11.2017 21:33:29): disconnect station 0 (Vantage): timeout
logger (30.11.2017 21:33:31): usb port reset.
MB running on MR3020, V3.4, Firmware 1.5.
Any ideas?
Thanks...
Colin
Re: Cannot connect to VP2 datalogger
Post by Colin »
For what it is worth and because of lack of response from other members I will put my views forward.
I had a very similar problems with my VP2 and Meteobridge not talking to each other. Went on for ages on an intermittent basis.
The fault was less frequent when I used a USB hub between the 2.
Admin logged onto my system and changed a setting on the weather network page. He set the retries to 'no retries' and the fault has disappeared.
Been good for months now.
Not saying that is the answer to your problem, just saying it is what fixed mine.
Hope it helps....
Clément
Post by Clément »
Hello Colin,
Thank you for your answer.
Unfortunately, so far, your workaround has not fixed anything.
Regards.
Your Vantage does not report any data over USB.
1) Make sure you have a USB 2.0 hub inbetween, this is mandatory.
2) Other reason might be that Console's USB port has hung up when inserting the USB logger into a powered-on Console:
Please remove USB connection, Power and batteries from the console, then put all in again.
3) Please also check that logger is still tightly fitting in the console, it might have swapped out.
Clément
Post by Clément »
Thanks for the reply.
1) Yes.
2 and 3) I'll try it again...
Clément
Post by Clément »
Thas has been fixed by connecting the station to a computer and downloading data from datalogger into WeatherLink.
