Meteohub Update 2.8b (experimental)
What's hot...
DEUTSCH:
Änderungen gegenüber V2.8a:
* Demozeitraum wurde bis zum 30.11. verlängert.
* Die Clone-Funktion wurde reaktiviert. Einfach im laufenden Betrieb den neuen USB-Stiuck anstelle der Wetterstation einstecken und "Clone" drücken.
* Behebt einen Fehler beim Betrieb der WH-1080, durch den leich gealterte Messdaten der WH-1080 ausgewertet wurden, anstelle der ganz aktuellen Daten.
* Neue Dashboard-Version 1.6 bricht bei einem XML-Ladefehler nicht mehr ab, sondern versucht es erneut.
ENGLISH:
Changes since V2.8a:
* Demo period has been extended until 30.11.2008.
* Clone function has been updated. Simply plug-off the weather station and insert the new USB stick instead (during ongoing operation of Meteohub) and press "clone".
* Fixes a bug in WH-1080 mode that caused data from the past being used by Meteohub instead of brand new data.
* New dashboard version 1.6 does not abort on XML load error, but tries again.
urosh
Re:Meteohub Update 2.8b (experimental)
Post by urosh »
Hello.
I have noticed, that last couple of days the annual rain is not shown anymore...
http://vreme.jausovec.com
Do you have any info why is that?
Regards, Uros
Chill
Post by Chill »
Hi there,
I have no problem under 2.8b.
You can see it at the very bottom of my page
http://www.telefonica.net/web2/vilacardona
I'm using WD Evaluation Version.
Regards,
Chill
urosh
Post by urosh »
Hello.
Now it's there again... Last couple of days it were not...
So let's say it is solved.
Cheers!
2.8b should behave ok again. I had a not so smart change in 2.8a, that caused bad computation of daily/monthly values. All this just affected time-compacted data, so a recompute with 2.8b should fix all this.
skyewright
Post by skyewright »
admin wrote:2.8b should behave ok again. I had a not so smart change in 2.8a, that caused bad computation of daily/monthly values. All this just affected time-compacted data, so a recompute with 2.8b should fix all this.
2.8b seems to have fixed the problem I was seeing with "day1" values resetting at 23:00 local time (22:00 UTC). Presumably the same problem?
skyewright
skyewright wrote:2.8b seems to have fixed the problem I was seeing with "day1" values resetting at 23:00 local time (22:00 UTC).
But it seems that 2.8b introduced a different one - "Temp 7" has disappeared from the WSWIN export... :(
skyewright
skyewright wrote:But it seems that 2.8b introduced a different one - "Temp 7" has disappeared from the WSWIN export... :(
Solved by 2.8c.
Thank you.
