Weather Cam Image Handling ...
jeffd2651
Post by jeffd2651 »
Greetings,
As a total noobie to Meteobridge which I only discovered a couple of days ago, I'm particularly interested in the 'Weather Cam Image Handling' capability.
I've looked on the forum and the wiki but there doesn't appear to be too much in the way of documentation.
Does this feature support RTSP input streams with a suitable output that can be embedded into html pages ??
If it does, then I'll continue to get up to speed with this and give the whole concept a try out with my weather station.
Thanks again in advance
Re: Weather Cam Image Handling ...
It just supports static images, which the Meteobridge grabs as a JPEG from the cam and then uploads for image processing to the Meteobridge server. It is not realtime, can be done fastest any 5 or 10 minutes, when I remember correctly.
jeffd2651
Post by jeffd2651 »
