UV Index not being passed to WeatherCloud **solved**
NEW2ARK
Post by NEW2ARK »
Hi New2Ark,
Thank you for using Weathercloud.
It seems that the Meteobridge software is not sending us the UV radiation data.
Re: UV Index not being passed to WeatherCloud
It is doing, according to their 0.6 API as parameter "&uvi=xxx", where xxx is UV index in 1/10.
SkidMark
Post by SkidMark »
I looked at my Weathercloud page and it looks like mine is working.
https://app.weathercloud.net/d0785887028#evolution
Do you feed your data anywhere else and does it show?
Mark
NEW2ARK
Post by NEW2ARK »
UVI is fine on Weather Underground...
i just got this from WeatherCloud:
Hi Joe,
Thank you for the information.
The UV index must be sent multiplied by 10. For instance, 5.7 must be sent as uvi=57. Otherwise, it will be filtered by our API.
Slash format:
http://api.weathercloud.net/v01/set/wid ... 105/uvi/57...
& format:
http://api.weathercloud.net/v01/set?wid ... 105&uvi=57...
Regards,
The Weathercloud team
UVI is reported factored by 10 and without decimals, so this should go fine.
As is is working for Mark and my tests also show it working, I have no idea why it is not for you.
NEW2ARK
Post by NEW2ARK »
I am using an AW 1401-IP weather station...i have setup a new device on WC and UVI is still not being reported but is appearing on WU and AWN
NEW2ARK
Post by NEW2ARK »
I am no longer using WeatherCloud....i decided to bring up a Home Weather Station website instead...
https://pwsincabotar.000webhostapp.com/ ... heme=color
