WSWINExport - Temp 7 gone!
skyewright
Post by skyewright »
Somewhat belatedly I've just noticed that "Export of Weather Data in WSWIN Format" page has lost its "Temp 7" - which I was using!
The "Temp 7" & "Temp 8" fields seems to have been replaced by "Wind Chill" and "UV via Temp", then the "Temps" re-continue with "Temp 9", so presumably this happened when "Wind Chill" export was added?
How can I get my WSWIN "Temp 7" back?
skyewright
Re:WSWIN Export - Temp 7 gone!
Checking back, "Temp 7" dropped to 0 C in WSWIN at 14:00 on Friday 3rd October - which is just when I installed v2.8b and did a recompute (When I do a recompute I always turn off WSWIN 'on-going' export to reduce the system load, then restart it afterwards)
I didn't notice this earlier because "Temp 7" is a soil sensor, so I don't check it very often at this time of year. It is plotted on my main WSWIN graph, but as a dashed line in a deliberately unobtrusive colour - and at 0 C that line happens to have been 'behind' the wind plot for most of the weekend anyway...
