Flash MR3020 V3 problems.
gw3atz
Post by gw3atz »
Hi.........After deciding to move away from an rpi for my wx stn, I purchased a MR3020 V3. Following the setup page for meteobridge, I installed virtual box, downloaded bin file and the server image. Virtual box runs ok and will run a different system to program radios. The server image imported ok but when it starts problems occur. I sorted the acceleration issue ( I think !) going into bios etc.. All I get in the terminal window is black to start with, then the oracle full screen logo, then just a flashing cursor on a blank screen. Could latest W10 updates be a problem.?
Done all of the above on two AMD desktop PC's, and a Intel laptop. Same result........And of course no flashing takes place. Any thoughts most welcome. I also built a linux pc from spare parts I have. That was just too much hassle to sort out. I use linux a little bit, but can't get to grips with tftp on it. So would like to sort the windows Pc's out if possible.
Geoff
gw3atz@gw3atz.co.uk
