FTP to two(2) webservers?
pelle61
Post by pelle61 »
Hi there! Is it possible in ANY way to upload the small txt files to two different web servers? I´m with Meteohub ver.5.0 x.
(Or is it possible to write a PHP script with a timer that copies them with an time interval? Just now I copy the files when loading the start page, but I would like to di it automatically :D )
Any help is appreciated!
d_l
Re: FTP to two(2) webservers?
Post by d_l »
You probably won't like this suggestion, but you could probably do it with two Meteohub servers. I'm guessing that you are computing different values and inserting them into the two txt files. If you used two servers, the second would link to the first to obtain its raw weather data.
I have to do something similar because I have two weather stations so weather data is up loaded to two different sub-files on one web server. AFAIK it takes two Meteohub servers to do this. As a bonus, the calculations for various graphs can be spread across my Meteohub servers reducing the computation load on each.
