Different figures Indoor Temp Live data sheet. **solved**
robert66
Post by robert66 »
I started today to setup Meteobridge pro. I am using the Davis Vantage, Vue. When I look at the Live data sheet, and I check the figure of Indoor Temp then it has the figure of 43,4 Celsius. I thought this was the temperature in my room, where I am using the Davis Vantage. But on the Davis Vantage the figure is 28 Celsius. I don't understand this difference, or it are two different measurements . The Meteobridge PRO is receiving the data of the Davis Vantage, I gueess, so why this different figures (43 against 28 degrees Celsius).
Re: Different figures Indoor Temp Live data sheet
Firstly, how is the MBPro connecting to the Vantage Vue? Would appear to be via RF, correct?
If so then this would fit your situation and the temp difference as there is no connection between the MBPro (Internal temp) and the Vue console (Internal/indoor temp) as the MBPro being in such a small box is affected by the enclosure temp as there is no temp sensor (as such) external to the MBPro enclosure.
robert66
Post by robert66 »
It's connected to RF, indeed. So as I understand it right, the indoor temp and humidity figures are figures measurements connected to the Meteobridge and not to the Davis Vue Console? And the figures the Davis Vue Console regarding the internal temp/humidity I can't see in the Meteobridge Software?
Correct, there is no connection (as such) between the MB and Vue console
robert66
Post by robert66 »
Ok, clear:-) Thanks ! Using weatherlink software also, with all the figures of the Vantage, so no problem.
