after loading fw 3.7 released August 25, 2018 does not load camera ftp **solved**
- jmontamat
I use a local foscam
External Picture URL: 192.168.1.55:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2
correctly generates aircam.jpg but does not load ftp.
in fw 3.6 works well.
I guess the problem is in:
adds support for HTTPS URLs for grabbing web cam pictures.
Platform: TL-MR3020 (plus USB hub)
RAM: 29364 kB total, 3312 kB free (88% used)
SW Version: Meteobridge 3.7 (Aug 26 2018, build 12309), FW 1.4
Josep.
Josep.
- Sin título.png (17.78 KiB) Viewed 8545 times
Re: after loading fw 3.7 released August 25, 2018 does not load camera ftp
Same problem it broke in that release!
Does not upload to wunderground either!
Version 3.7
released August 27, 2018
fixes a freshly introduced bug that prevents web cam pictures to be uploaded to the Meteobridge server.
I have Meteobridge 3.7 (Aug 26 2018, build 819), FW 1.1 tried to reboot with update on reboot set and still says Aug 26 build 819.
Same. Multiple reboots and I am still getting.
Platform: TL-WR902AC (no USB hub)
RAM: 60056 kB total, 21352 kB free (64% used)
SW Version: Meteobridge 3.7 (Aug 26 2018, build 819), FW 1.1
Uptime: 4 hours, 23 minutes Buffer: 2 items (0%)
Not updating to Aug 27 2018 version.
Cam uploads/updates still failing.
Andy
Andy
fixed with todays release.
- jmontamat
Re: after loading fw 3.7 released August 25, 2018 does not load camera ftp **solved**
Is this the latest version? I do not load another ... it does not work.
Platform:TL-MR3020 (plus USB hub)RAM:29364 kB total, 3372 kB free (88% used)SW Version:Meteobridge 3.7 (Aug 26 2018, build 12313), FW 1.4Uptime:0 hours, 5 minutes Buffer: 0 items (0%)
nope, it is from August 27. I deployed it again, just to make sure the upload went fine.
- jmontamat
Yes now !!!
TL-MR3020 (plus USB hub)RAM:29364 kB total, 2424 kB free (91% used)SW Version:Meteobridge 3.7 (Aug 27 2018, build 12317), FW 1.4Uptime:0 hours, 4 minutes Buffer: 0 items (0%)
Work fine tnx.
Work fine tnx.
Confirmed update took place and web camera image upload to wunderground working again!
Still not working as of 6:09am 8/28/2018. Had to go back to 3.6 on the TL-AC920
Do I need to change my http:// to https:// as I am reading this correctly?
Here is what my camera URL setting looks like:
http://Your IP Address:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=Your UserID&pwd=Your Password
When it is automatically rerouted by your cam to a HTTPS URL then you need to use the final HTTPS address to avoid a hidden protocol change which makes Meteobridge to decide falsely if the non-ssl or ssl-enabled wget should be used for data transfer form the cam.Andyk1 wrote: Tue Aug 28, 2018 1:12 pm Do I need to change my http:// to https:// as I am reading this correctly?
just did a test with latest runlevel.
Did a reboot.
Login meteobridge via webinterface.
Meteobridge Weather Cam option was again selected on "none"
And no upload of a weathercam image.
Have to enable it again.
After enable the image is uploaded every minute to my local ftp server.
Still a big, I'm afraid.
Somehow the selection to enable upload in the Weather Station tab is not proper saved in the config file of meteobridge, I assume.
See also my message :
viewtopic.php?f=61&t=12633#p25867
regards, Peter
Did a reboot.
regards, Peter
