Erron on Rain rate **SOLVED**
Casappa
Post by Casappa »
Hallo' all,
due to maintenance in the rain collector, now I've recorded a new monthly and yearly higth rain rate value of 1350 mm/hr.
Is there a way to edit a file to delete this value?
Thank You.
Alberto.
sevenless
Re:Erron on Rain rate
Post by sevenless »
I haven't done this myself so I can't be absolutely certain, but you should be able to manually delete the incorrect entries by going to the "Inspect Data" page on the web interface, select the start of the timeframe where the problem occurred (times are recorded as UTC, regardless of your own time zone), and then select the rain0 sensor on the filter setting.
Once you identify the incorrect entries, type their timestamp into the "from" box at the bottom and press Delete to remove them.
After you have deleted all of the incorrect entries (and there are probably many of them because rain rate decays slowly), then go to the Maintenance page and Recompute your aggregated data.
bolzano
Post by bolzano »
In web interface you can edit/delete bad entries in Inspect data menu.
