Failed to connect to MYSQL database: Can't connect to MySQL server on 'IP' (146) **solved**
rmccullough
Post by rmccullough »
I followed these directions to get the database and table configured. Which seems to have gone fine.
But when I enter the details in my Meteobridge I get the error in the attached screenshot. The details I entered are correct. I can log in to phpMyAdmin with the same credentials and view the table just fine.
2018-10-25 19_37_32-Meteobridge.png (45.49 KiB) Viewed 2131 times
bardek
Re: Failed to connect to MYSQL database: Can't connect to MySQL server on 'IP' (146)
Post by bardek »
Your database should permit remote insert for the user first and propably myslq server remote access should be enabled too.
rmccullough
bardek wrote: Fri Oct 26, 2018 10:57 pm Your database should permit remote insert for the user first and propably myslq server remote access should be enabled too.
I figured that If I could login to the phpMyAdmin interface remotely I was good to go. Had no idea that I had to allow remote access to the database itself. Working perfect now.
