SOLVED - Was USB Issue - Help! Can't find Meteohub -no IP...
I'm using V2.8 and all of a sudden I can no longer get to my Meteohub and it stopped sending data. All the lights are green and I have rebooted several times.... It's connecting, green light, to my router, but not showing an ip address anywhere. I had it set to a fixed IP and using IPScan - it not longer shows up.... It's powering up - but like it doesn't exist... Any ideas - I can't access it in any way.....any ideas on how to get to it - I can't even browse to it... Ughhhh!
Gregg
Gregg
Re:Help! Can't find Meteohub -no IP...
Just in case...
have you tried to connect through 192.168.1.77 which is default IP ? (you need to do it from a PC which also has an IP in the rang 192.168.1.xx)
If it works, the you can change IP again from Settings
HTH,
Chill
HTH,
Chill
It looks like it is definitely at http://192.168.1.77 - but I still can't get to it... It shows something at that address in IPScan and I can ping that address - but can't pull it up in explorer... My guess it has something to do with accessing it through my linksys router... No luck yet getting to it to change the ip....
I have a NSLU2 with similar problem.
I can see with an IPSCAN. I can access via SSH, but I don't know how to change IP.
I was told it means meteohub is not running in this NSLU2, although I installed it previously. I can see it but who gives access through windows is meteohub software, and it's not working (properly).
So I don't think it is your Linksys...
Chill,
Chill,
How do you access it through SSH - do you get the normal screens....because you can assign a IP from the maint tab......
One other thing - when I debug through IE - it says that the IP address is not configured for Http access..... Hmmmmm
Re:Help! Can't find Meteohub -no IP... DEAD!
Well - I've try just about everything and I am completely dead in the water... It has stopped working and I can no longer access my Meteohub... It's not uploading anymore and my site is dead! Very dissapointed in this thing as it just stopped working with no luck.... At least it has a 3 year warranty through Ambient here in the states...
Gregg
Gregg
when it does not make the IP signaling after boot, but gives three beeps, shortly one after another differently in volume and pitch, then NSLU2 was not able to boot USB stick, but remains in firmware mode.
You can connect on the unit with ssh in firmware mode, but not via http.
Try logging in on port 22 via SSH. When logged in say "dmesg", which should give you some logs during boot. I guess your USB stick has read/write faults. If so, you can see it in dmesg output.
Okay - that explains a few things! Thanks.
I'm not quite sure how to log in via SSH....do I need a separate program? or is it https://192.168.1.77/ which didn't work either...
Is there a way to recover the stick or repair it? or do I have to start from scratch... It was a 4gb kingston....a fairly reliable brand....
I now have a SSH login program puTTY and I'm able to get half way there but can't seem to get by the password.... it won't accept admin, pass, root... any ideas.. Thanks
The ssh login/password on all Meteohub systems is root/meteohub (all lower case.)
If that fails then you've got a more serious problem on your hands and there's likely an issue with the NSLU2 itself.
In my case, I have no troubles at all if I use my regular USB (working properly). But if I MAKE A NEW USB STICK Image, then I get three beeps and I can't reach it (unless I use SSH login).admin wrote:when it does not make the IP signaling after boot, but gives three beeps, shortly one after another differently in volume and pitch, then NSLU2 was not able to boot USB stick, but remains in firmware mode.
So point is, is the new USB Image working fine, or it is my USB which is not working? I GUESS IS MY USB sttick, so today I'll buy a new one ... and I'll try again...
Chill
I'm going to makea new usb stick today and see what happens.. I got in via SSH but that is new to me and can't seem to do much from there... I do get the following which looks to me to be a bad stick... Too bad I can't save my historical data though...
<7>usb-storage: device found at 3
<7>usb-storage: waiting for device to settle before scanning
<6>usb 2-1: new full speed USB device using ohci_hcd and address 2
<6>usb 2-1: configuration #1 chosen from 1 choice
<5>scsi 0:0:0:0: Direct-Access Kingston DataTraveler 2.0 1.00 PQ: 0 ANSI: 2
<5>SCSI device sda: 7856128 512-byte hdwr sectors (4022 MB)
<5>sda: Write Protect is off
<7>sda: Mode Sense: 23 00 00 00
<3>sda: assuming drive cache: write through
<6> sda: sda1 sda2 sda3
<5>sd 0:0:0:0: Attached scsi removable disk sda
<7>usb-storage: device scan complete
<2>EXT3-fs error (device sda1): ext3_check_descriptors: Block bitmap for group 0 not in group (block 335806464)!
<3>EXT3-fs: group descriptors corrupted!
<6>IXP4XX Q Manager 0.2.1 initialized.
<6>ixp4xx_mac driver 0.3.1: eth0 on NPE-B with PHY[1] initialized
<6>kjournald starting. Commit interval 5 seconds
<4>EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
<6>EXT3 FS on sda3, internal journal
<6>EXT3-fs: recovery complete.
<6>EXT3-fs: mounted filesystem with ordered data mode.
<6>Adding 130688k swap on /dev/sda2. Priority:-1 extents:1 across:130688k
<6>eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
first partition (sda1) does not mount, therefore boot of usb sticks fails. however third partition (sda3) that holds your data looks ok.
I would recommend to set up a new stick and then to copy partition 3 from the old one to the new one. By that you do not loose your data. Do you have a spare USB stick (formatted in FAT/FAT32) where to copy the data onto?
If so, steps are.
1) boot nslu2 with original stick inserted.
2) login via ssh
3) put temp usb stick into the other usb slot of NSLU2, give linux commands as follows:
4) mkdir -p /mnt
5) mkdir -p /mnt2
6) mount /dev/sda3 /mnt
7) mount /dev/sdb1 /mnt2 (if that fails use /dev/sdb)
8) cp -r /mnt/* /mnt2/
9) umount /mnt /mnt2
10) unplug temp usb stick and save data to your PC.
If so, steps are.
2) login via ssh
4) mkdir -p /mnt
5) mkdir -p /mnt2
Well - I created a new USB stick using DiskImage and used the 4 gb version with a new SanDisk USB Stick... I still can't get to it...same as chill - could there be something wrong in the image as I three beeps - two the same and one different tone...
My computer is at 192.168.101 and I have also tried it at 192.168.1.73 and still can't get to it. I can get to it via SSH with the new stick - but still can't via Explorer.. There must be something deeper that is wrong... Here is my latest... Look at the very end - problem with FAT???
I originally reformated the new stick with FAT32 then ran DiskImage to mount the dd file. I'll try reformating again but do it through the NSLU2 instead of Disk Image to see if that changes anything...
login as: root
root@192.168.1.77's password:
root@LKG288307:~$ dmesg
<5>Linux version 2.6.21.7 (slug@otto) (gcc version 4.1.2) #1 PREEMPT Mon Dec 24 23:12:24 UTC 2007
<4>CPU: XScale-IXP42x Family [690541f1] revision 1 (ARMv5TE), cr=000039ff
<4>Machine: Linksys NSLU2
<4>Memory policy: ECC disabled, Data cache writeback
<7>On node 0 totalpages: 8192
<7> DMA zone: 64 pages used for memmap
<7> DMA zone: 0 pages reserved
<7> DMA zone: 8128 pages, LIFO batch:0
<7> Normal zone: 0 pages used for memmap
<4>CPU0: D VIVT undefined 5 cache
<4>CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
<4>CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
<4>Built 1 zonelists. Total pages: 8128
<5>Kernel command line: rtc-x1205.probe=0,0x6f console=ttyS0,115200n8 root=/dev/mtdblock4 rootfstype=jffs2 rw init=/linuxrc noirqdebug
<6>IRQ lockup detection disabled
<4>PID hash table entries: 128 (order: 7, 512 bytes)
<4>Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
<4>Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
<6>Memory: 32MB = 32MB total
<5>Memory: 30292KB available (1912K code, 153K data, 84K init)
<7>Calibrating delay loop... 132.71 BogoMIPS (lpj=663552)
<4>Mount-cache hash table entries: 512
<6>CPU: Testing write buffer coherency: ok
<6>NET: Registered protocol family 16
<4>IXP4xx: Using 16MiB expansion bus window size
<4>PCI: IXP4xx is host
<4>PCI: IXP4xx Using direct access for memory space
<6>PCI: bus0: Fast back to back transfers disabled
<6>dmabounce: registered device 0000:00:01.0 on pci bus
<6>dmabounce: registered device 0000:00:01.1 on pci bus
<6>dmabounce: registered device 0000:00:01.2 on pci bus
<5>SCSI subsystem initialized
<6>usbcore: registered new interface driver usbfs
<6>usbcore: registered new interface driver hub
<6>usbcore: registered new device driver usb
<6>Time: OSTS clocksource has been installed.
<6>NET: Registered protocol family 2
<4>IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
<4>TCP established hash table entries: 1024 (order: 1, 8192 bytes)
<4>TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
<6>TCP: Hash tables configured (established 1024 bind 1024)
<6>TCP reno registered
<4>NetWinder Floating Point Emulator V0.97 (double precision)
<6>JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
<6>io scheduler noop registered
<6>io scheduler deadline registered (default)
<6>Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
<6>serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
<6>serial8250.0: ttyS1 at MMIO 0xc8001000 (irq = 13) is a XScale
<4>RAMDISK driver initialized: 4 RAM disks of 10240K size 1024 blocksize
<6>IXP4XX NPE driver Version 0.3.0 initialized
<6>NFTL driver: nftlcore.c $Revision: 1.98 $, nftlmount.c $Revision: 1.41 $
<6>IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
<7>IXP4XX-Flash.0: Found an alias at 0x800000 for the chip at 0x0
<4> Intel/Sharp Extended Query Table at 0x0031
<6>Using buffer write method
<5>cfi_cmdset_0001: Erase suspend on write enabled
<7>erase region 0: offset=0x0,size=0x20000,blocks=64
<5>Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x7e0000
<5>6 RedBoot partitions found on MTD device IXP4XX-Flash.0
<5>Creating 6 MTD partitions on "IXP4XX-Flash.0":
<5>0x00000000-0x00040000 : "RedBoot"
<6>nslu2 mac: 00:14:bf:66:43:e5
<5>0x00040000-0x00060000 : "SysConf"
<5>0x00060000-0x00080000 : "Loader"
<5>0x00080000-0x00180000 : "Kernel"
<5>0x00180000-0x007e0000 : "Flashdisk"
<5>0x007e0000-0x00800000 : "FIS directory"
<4>npe: searching for firmware...
<6>npe: found at 0x1c010, IXP425/NPE-B func: 00, rev: 2.1, size: 11964, id: 01000201
<6>Image loaded to NPE-B Func:0, Rel: 2:1, Status: 82c00000
<6>Initializing USB Mass Storage driver...
<6>usbcore: registered new interface driver usb-storage
<6>USB Mass Storage support registered.
<6>input: ixp4xx beeper as /class/input/input0
<6>i2c /dev entries driver
<6>x1205 0-006f: chip found, driver version 1.0.7
<6>x1205 0-006f: rtc core: registered x1205 as rtc0
<6>Registered led device: ready
<6>Registered led device: status
<6>Registered led device: disk-1
<6>Registered led device: disk-2
<6>TCP cubic registered
<6>NET: Registered protocol family 17
<6>XScale DSP coprocessor detected.
<6>x1205 0-006f: setting the system clock to 2008-11-11 10:36:00 (1226399760)
<4>VFS: Mounted root (jffs2 filesystem).
<6>Freeing init memory: 84K
<4>PCI: enabling device 0000:00:01.2 (0140 -> 0142)
<6>ehci_hcd 0000:00:01.2: EHCI Host Controller
<6>ehci_hcd 0000:00:01.2: new USB bus registered, assigned bus number 1
<6>ehci_hcd 0000:00:01.2: irq 26, io mem 0x48002000
<6>ehci_hcd 0000:00:01.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
<6>usb usb1: configuration #1 chosen from 1 choice
<6>hub 1-0:1.0: USB hub found
<6>hub 1-0:1.0: 5 ports detected
<7>ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
<4>PCI: enabling device 0000:00:01.0 (0140 -> 0142)
<6>ohci_hcd 0000:00:01.0: OHCI Host Controller
<6>ohci_hcd 0000:00:01.0: new USB bus registered, assigned bus number 2
<6>ohci_hcd 0000:00:01.0: irq 28, io mem 0x48000000
<6>usb usb2: configuration #1 chosen from 1 choice
<6>hub 2-0:1.0: USB hub found
<6>hub 2-0:1.0: 3 ports detected
<4>PCI: enabling device 0000:00:01.1 (0140 -> 0142)
<6>ohci_hcd 0000:00:01.1: OHCI Host Controller
<6>ohci_hcd 0000:00:01.1: new USB bus registered, assigned bus number 3
<6>ohci_hcd 0000:00:01.1: irq 27, io mem 0x48001000
<6>usb usb3: configuration #1 chosen from 1 choice
<6>hub 3-0:1.0: USB hub found
<6>hub 3-0:1.0: 2 ports detected
<6>usb 1-2: new high speed USB device using ehci_hcd and address 3
<6>usb 1-2: configuration #1 chosen from 1 choice
<6>scsi0 : SCSI emulation for USB Mass Storage devices
<5>scsi 0:0:0:0: Direct-Access SanDisk Cruzer 7.01 PQ: 0 ANSI: 0 CCS
<5>SCSI device sda: 7905279 512-byte hdwr sectors (4048 MB)
<7>sda: Mode Sense: 45 00 00 08
<6> sda: sda1
<3>VFS: Can't find ext3 filesystem on dev sda1.
<3>FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
<3>FAT: invalid media value (0x00)
<6>VFS: Can't find a valid FAT filesystem on dev sda1.
<7>Link of eth0 is full-duplex
login as: root
<6> sda: sda1
