Data Import function for MB PRO and NANO SD
Re: Data Import function for MB PRO and NANO SD
Thanks, the files differ from what I have had before that they are with ascending time stamps. Just released update now supports both types (CSV and SQL) and both time stamp directions (ascending or descending).
I will now primarily take care of my family... Have a nice Christmas!
ConligWX
Post by ConligWX »
Thanks for the help Boris, Merry Christmas and a Happy New Year!
I received two completely different looking data sets for Meteotemplate and I wonder if one might not even be a Meteotemplate export.
Example 1 starting with "wind average, wind gust, wind direction, ... :
01-01-2018,00:00,0.00,3.20,84,0.00,22.20,51.00,1002.20,11.50,0.00
01-01-2018,00:05,0.60,1.40,99,0.00,22.10,52.00,1002.20,11.70,0.00
01-01-2018,00:10,0.50,1.40,100,0.00,22.00,52.80,1002.10,11.90,0.00
01-01-2018,00:15,0.00,1.40,83,0.00,21.90,53.80,1002.00,12.10,0.00
01-01-2018,00:20,0.00,3.20,89,0.00,21.80,54.40,1001.80,12.10,0.00
01-01-2018,00:25,0.00,1.40,106,0.00,21.60,55.00,1001.70,12.10,0.00
Example 2 starting with "T", "Tmax", "Tmin", ...:
"2010-01-01 00:04:00","-0.4","-0.4","-0.4","81.0","-3.3","9.7","9.7","269.0","0.000","0.000","1005.600","0.0","-4.7"
"2010-01-01 00:09:00","-0.6","-0.6","-0.6","81.0","-3.5","16.7","16.7","265.0","0.000","0.000","1006.000","0.0","-6.3"
"2010-01-01 00:14:00","-0.6","-0.6","-0.6","82.0","-3.3","16.7","16.7","262.0","0.000","0.000","1006.000","0.0","-6.3"
"2010-01-01 00:19:00","-0.7","-0.7","-0.7","82.0","-3.4","13.0","13.0","262.0","0.000","0.000","1006.000","0.0","-5.7"
"2010-01-01 00:24:00","-0.7","-0.7","-0.7","83.0","-3.3","14.8","14.8","262.0","0.000","0.000","1006.000","0.0","-6.0"
"2010-01-01 00:29:00","-0.7","-0.7","-0.7","83.0","-3.3","16.7","16.7","261.0","0.000","0.000","1006.000","0.0","-6.4"
"2010-01-01 00:34:00","-0.7","-0.7","-0.7","83.0","-3.3","11.1","11.1","261.0","0.000","0.000","1005.600","0.0","-5.3"
As I am not running a Meteotemplate instance myself I am a bit lost, which one is right. Any expert advice out there?
stewart45
Post by stewart45 »
This is an extract from my meteotemplate database similar to your example 2
"2018-01-01 00:04:00","4.2","4.2","4.2","86.0","2.0","19.5","27.4","311.0","0.000","0.000","986.300","0.0","-1.3"
"2018-01-01 00:09:00","4.2","4.2","4.2","86.0","2.0","22.7","33.8","276.0","0.000","0.000","986.300","0.0","-1.9"
"2018-01-01 00:14:00","4.1","4.1","4.1","85.0","1.8","16.3","24.1","265.0","0.000","0.000","986.300","0.0","-0.8"
"2018-01-01 00:18:00","3.9","3.9","3.9","86.0","1.7","20.9","25.7","319.0","0.000","0.000","986.700","0.0","-1.9"
"2018-01-01 00:23:00","4.1","4.1","4.1","85.0","1.8","19.5","30.6","293.0","0.000","0.000","986.700","0.0","-1.4"
"2018-01-01 00:28:00","4.1","4.1","4.1","85.0","1.8","19.5","24.1","257.0","0.000","0.000","986.700","0.0","-1.4"
"2018-01-01 00:30:00","4.0","4.0","4.0","85.0","1.7","11.1","25.7","296.0","0.000","0.000","986.700","0.0","0.1"
"2018-01-01 00:35:00","4.0","4.0","4.0","85.0","1.7","13.0","17.7","300.0","0.000","0.000","987.000","0.0","-0.2"
ConligWX
Post by ConligWX »
just for info.
I too ran into some issues with CumulusMX exported csv where each test delimiter was set to " "
I found some erroneous data which was fixed in excel, but the Excel removes the delimiter quotes and then Meteobridge refuses to import the data without them.
I had to then use OpenOffice Calc to put the quotes back in the file since Excel just doesn't work the way you want it too like that.
Perhaps imports of data should accept either Quotes and non Quoted text delimited data as the data after all it is separated by a comma.
ConligWX
Post by ConligWX »
ok I tried to import a cumulusMX csv for 1 whole year. I noticed in the historic data the ALL indoor temp Max was 734c and climbing. the date listed and that value is the overall Raincounter value.
this is obviously a bug and the indoor temp for "All max " is somehow linked /mixed up to the raincounter value.
when importing the values are:
"LogDateTime","Temp","Humidity","Dewpoint","Windspeed","Windgust","Windbearing","RainRate","TodayRainSoFar","Pressure","Raincounter","InsideTemp","InsideHumidity","LatestWindGust","WindChill","HeatIndex","UVindex","SolarRad","Evapotrans","AnnualEvapTran","ApparentTemp","MaxSolarRad","HrsSunShine","CurrWindBearing","RG11rain","RainSinceMidnight","WindbearingSym","CurrWindBearingSym"
"2016-09-11 00:00:00","11.2","81","8.0","3.0","8.0","199","0.0","0.0","1010.13","734.2","24.7","48","3.0","11.2","11.2","0.0","0.0","0.0","7.8","9.8","0.0","0.0","183","0.0","0.0","SSW","S"
in its current state the CumulusMX import values do not copy over to the correct values in Meteobridge.
Thanks for spotting these errors. I changed the code accordingly. Now lines starting directly with a digit or with " or with (" are recognized as data records. Delimiters can be anything. Decimals need to be separated by "." (German "," notation for decimals is currently not supported).
An Update covering that is just released.
Does anybody have a WU export file? I would like to include this as well as some users might have used WU as their archive.
ConligWX
Post by ConligWX »
Boris, just out of curiousity. I noticed my buffers were getting quite high (85% full) before import finished. What happens when it reaches 100%?
Is new data from console just ignored?
rjuricic
Post by rjuricic »
Hi, thanks for implementing import functionality to Nano SD module. I have 10 years of data in Meteotemplate format which i extracted to csv and sql format, and trying to import into Nano SD. So far i have noticed one error regarding parsing data when import is initated: if there is some field which does not contain any value (export in csv format) or has NULL (export in sql format), MB system tab will display error about invalid parameter sequence as shown on image below:
Workaround for me was to manually input value (i.e. 0.0) in those fields. Import was successfull but i dont think that all data are correctly imported. I have cross-comapred original data in sql db and result of import to Nano SD and found that rain amount is not correctly imported, all rain values are lower than actual ones in original DB. Other sensor data seems correctly imported. (I have compared monthly sums,avg,min/max data via History tab on MB Nano)
Is there any possibility to interactively check data in MB database? I wanted to do checks via Graphs tab also, but time period allows me to select as far as 2 years only. I would like to be able to graph all 10 years.
Any advice on this will be helpful. Upload of 10 years db took me around 8hours, and before i try this again, i want to make sure that data will be uploaded correctly. Is there any documentation regarding import functionality which may explain described behaviour?
ConligWX
Post by ConligWX »
Just imported 2.5 years of cumulusmx data. it looks ok now, though I did have to fix some erroneous data.
I broke each year years down into 4 month periods of data which seem to be ok. any bigger and buffers were likely to be near full or at 100% services restarted after buffers were cleared of queues.
Lets hope WeeWX sqlite db can be supported too :)
rjuricic wrote: Wed Dec 26, 2018 9:05 pm Is there any possibility to interactively check data in MB database? I wanted to do checks via Graphs tab also, but time period allows me to select as far as 2 years only. I would like to be able to graph all 10 years.
When you look at the URL that generates the charts, you can easily see how it works.
Example: "chart.cgi?chart=hws-temphum-iso.chart&res=min&lang=en&start=D2&stop=D0"
[*] chart=hws-temphum-iso.chart, this specifies which of the chart definitions to use
[*] res=min, this specifies which time resolution to take. "min" is only available for the last 2-3 days. alternatives are "hour", "day", "month"
[*] start=D2, this tells chart should start at the beginning of the day before today.
[*] stop=D0, this tells chart should end at the beginning of tomorrow (equals to end of today).
start/stop parameters can be relative like "Yn" (n years before current year), "Mn" (n months before current month) or Dn (n days before today). But you can also specify the date to start/stop.
Examples:
[*] "chart.cgi?chart=hws-temphum-iso.chart&res=month&lang=en&start=2016&stop=2017" will show 2016 in monthly resolution.
[*] "chart.cgi?chart=hws-temphum-iso.chart&res=day&lang=en&start=201501&stop=201504" will show first quarter of 2015 in daily resolution.
[*] "chart.cgi?chart=hws-temphum-iso.chart&res=hour&lang=en&start=2015011120&stop=2015011223" will show hourly data from Jan 11, 2015 8PM until Jan 12, 2015 11PM.
Remark: As stop date/time is exclusive, the stop date itself will not be part of the chart. End is always one time bucket before the stop date/time. Just in case you are missing the very last time bucket (most users will not even notice).
I hope this helps to fully understand the power of the Meteobridge graphing engine and how I engineered it for flexibility.
Just released update also supports import from weewx exports (in CSV notation). As with the other import functions, this is still regarded beta.
Now also WSWIN files can be imported. I think we slowly reach the end of the most requested formats.
mthiessen
Post by mthiessen »
I would like to suggest Weather Underground data. I have 4 years of data posted there every 5 minutes using Meteobridge (TP-Link). Here is a tool here that allows you to get a CSV file from WU for a date range or a single day.
http://www.meteor.iastate.edu/~slincoln/stationdata/
The date range data is one line of data per day so it's not every 5 minutes (it doesn't seem to be working at all now). The single day data is every 5 minutes but you can't get a range of data.
I'm working on an AppleScript that will send requests for each day and add the results to a text file. I'm not sure how different WU data is from the other data sets you have created filters for. I've attached 1 days worth of WU data (every 5 minutes).
I will be purchasing a Nano SD in a few months when I visit my out-of-town PWS. I would love to be able to upload this 4 years worth of data to the SD for charting.
Keep up the good work. I love the work you are doing.
Weather Underground export data.txt.zip
(4.76 KiB) Downloaded 266 times
Thanks! The WU file you attached is easy to parse, that will be snap to include to Meteobridge data import features. Is that a file that WU does directly offer for download or did you post-process it somehow?
