SOLVED - Supported characters
argonaut71
- Junior Boarder
What characters sets Meteohub support. Is it UTF-8 compatible or something else. This came to my mind because I was trying to set Station Name to Ristinarkku - Messukylä and last character is displayed in the screen with alias ä
Re:Supported characters
It's UTF 8
Cheers!
Cheers!
argonaut71
- Junior Boarder
I have problems with umlaut characters when using WD Live: http://www.paavolat.fi/wdl/fi
EDIT: Mistake in the link. Is working now!
Hello.
The link does not open...
I use on the box WD live - look: http://vreme.jausovec.com
Regards, Uros
Regards, Uros
web interface is iso-8859-1, but can be changed to UTF-8 when a language file specifies this.
Strings to WD-Live are urlized based on the choosen character set.
I did not test with special characters. Does non of the variants work?
1) just type in the character (ä)
2) use html code (ä )
3) unicode number (ä)
argonaut71
- Junior Boarder
1) nope
2) nope
3) nope
Web interface translates variant 2 and 3 on the screen to ä (so after the save code is not show on the screen). In the web page ä is show as a box, variant 2 as code and number.
2) nope
3) nope
argonaut71
- Junior Boarder
Even with this new version I have same problem.
Next update will shift completely to UTF-8. Then there will be no more problems giving special characters to WD-Live.
argonaut71
- Junior Boarder
Yes indeed! New 3.1a version solved this problem. Thank you very much.
