Meteobridge NANO SD - a NANO with local storage
leliep
Re: Meteobridge NANO SD - a NANO with local storage
Post by leliep »
Something for the wishlist:
I would like to be able to insert an optional "reload" function into the generated .html weather graphics code. This would allow me to automatically update a displayed weather graphics without of any further ado.
Thanks for listening, -pl ;-)
BTW: thanks for doing a great job, the "SD" extension of the NANO was a nice surprise!
sv2bzq
Post by sv2bzq »
Hi.
I wanted to ask if Meteobridge NANO SD can work on in the Vandage Pro2 console old type (before 2012) .
Thanks ...
George .
Define what you mean by "old type"? If it's a VP2 shouldn't be a problem, I have it running on pre 2012 VP2 Envoy's, same thing.
To my knowledge any PRO2 will do, but I don't have old versions here to test with.
sv2bzq
Post by sv2bzq »
Τhank you for the answers.
The Vandage PRO2 i have the 3.15 firmware .
Tomorrow is received the Nano SD and and I will try it and I will let you know .
Also ask the Nano SD creates the file clientraw.txt I did not find this information anywhere .
George .
3.15 Firmware won't be a problem, released April 2014, I have a nanoSD running with 1.90 Firmware which well and truly predates 3.15
sv2bzq
Post by sv2bzq »
Hi.
Today receive the Meteobridge NANO SD all ok untill now with Vantage PRO2 (firmware 3.80 now) .
How do I transfer the history data from meteohub??
George.
ConligWX
Post by ConligWX »
sv2bzq wrote: Mon Jan 14, 2019 10:35 pm Hi.
George.
https://www.meteobridge.com/wiki/index.php/PRO_History
Import Data
sv2bzq
Post by sv2bzq »
ConligWX wrote: Mon Jan 14, 2019 10:51 pm
George.
Import Data
Hi .
I still could not upload the historical data from Meteohub .
Please tell me what files and what is the process to Meteohub ???
I made a Backup export from Meteohub but in Meteobridge Nano SD write "error in Line 1" and does not progress .
I put one by one raw files from folder WEATHER of Meteohub but most data passed "0.0" .
Please any help .
Any news to pass the History data from Wunderground to Nano SD ???
George .
ConligWX
Post by ConligWX »
I have never used meteohub so I cannot answer your question. Perhaps @admin can help. do you have erroneous data on line 1? you might need to email the data to info(at)smartbedded.com and see if Boris can help
sv2bzq
Post by sv2bzq »
ConligWX wrote: Thu Jan 17, 2019 6:25 pm I have never used meteohub so I cannot answer your question. Perhaps @admin can help. do you have erroneous data on line 1? you might need to email the data to info(at)smartbedded.com and see if Boris can help
Ok thanks for the answered....
George.
sv2bzq
Post by sv2bzq »
Hi .
My Nano SD write one error in a Services menu .....
Error: Cannot add more events, maximum reached (20)
they can increase these command because I need more commands ????
George.
ConligWX
Post by ConligWX »
sv2bzq wrote: Fri Jan 18, 2019 4:20 pm Hi .
George.
20 is the max. thats why you get the error. unless Boris can add more, there is not much you can do.
what are you running you would need to list them to see if we could help in someway to lesson the amount of services you are running. I am on 15 at present.
There is possibly an operational and storage limit imposed by a max number of services. There has to be a practical max limit at which point one starts to degrade the system?
sv2bzq
Post by sv2bzq »
ConligWX wrote: Fri Jan 18, 2019 7:45 pm
George.
Mattk wrote: Fri Jan 18, 2019 10:11 pm There is possibly an operational and storage limit imposed by a max number of services. There has to be a practical max limit at which point one starts to degrade the system?
Ok thanks for the answering .
Now and I have limited them to 16 but it needs for production and other Chart and Data Export .
George.
