Hi all,
I am really happy with the functionality of the Meteobridge pro!
Data collection is through RF (MBpro red) and there is one thing i am missing.
I'd like to be able to correct the temp reading from station #2, wich is an extra temp/hum station. This would allow me to calibrate the ground temperature (@10cm) to a calibrated temp sensor, or to calibrate it to the (calibrated) main temp sensor.
I hope this is possible to implement!
Thanks!
Gerhard
www.weeropdeveluwe.nl
Feature request: Extra temp correction **solved**
fotogw
- Senior Boarder
fotogw
- Senior Boarder
Re: Feature request: Extra temp correction
I'm curious if this is something that could be implemented. I'd like to calibrate my extra temperature station! Anyone willing and able to answer?
Thx!
Gerhard
Thx!
Gerhard
Looking at https://www.meteobridge.com/wiki/index.php/Templates you can add a 'calibration' to any template you use to read the second temp data by adding a Numerical Expressions.
For example the template: Outdoor temperature is {* [th0temp-act=F.1] + 2 *0}°F
If the outdoor temp is 50.3°F will return
Outdoor temperature is 52°F
Lou
fotogw
- Senior Boarder
Thanks for the hint. But I think this can not be implemented in export-files like Clientraw.txt or Realtime.txt. That is why I hope a calibration-setting would be added to the "Station" settings in Meteobridge, just like the regular calibrations for main temp, rain, wind etc.Ag2000CO wrote: Sun Mar 17, 2019 9:48 pm Looking at https://www.meteobridge.com/wiki/index.php/Templates you can add a 'calibration' to any template you use to read the second temp data by adding a Numerical Expressions.
Gerhard
fotogw
- Senior Boarder
Solved in v4!
This issue is solved in version 4
