[wind0dir-act]
ConligWX
[wind0dir-act]
Post by ConligWX »
Boris
Why does Template [wind0dir-act] add a decimal place? Degrees in Wind are measured in whole numbers, "integers" and should not have a .0 after them.
I've tested this on a Twitter post and a text template, both added .0 after the value.
Can this be fixed at source?
Ag2000CO
Re: [wind0dir-act]
Post by Ag2000CO »
Looking at https://www.meteobridge.com/wiki/index.php/Templates
I see
Decimals
Unless otherwise defined numbers are reported with one decimal.
Doing a search of that page I did not see any where that wind0dir-act format was redefined.
Why not change the request to [wind0dir-act.0] That will report a whole number.
Lou
ConligWX
Re: [wind0dir-act]
Post by ConligWX »
Yes I should be able to, but I am asking why is it not a integer already.
Ag2000CO
Re: [wind0dir-act]
Post by Ag2000CO »
From a "programmer's" point of view I think it is much better if all the numbers are available/presented in the same format. That way you (the user) do not have to remember which are real, which are integer, which are text strings or binary. JMHO
To change the format now would/could have unforeseen consequences for an unknown number of user applications.
As for why wind0dir was set up as a real number in the beginning(?) Just guessing but it would make sense to use a single common subroutine to convert an analog sensor signal to a real number in stead of having two procedures or an added step to round to an integer. This is especially true when the user interface already has the capability to format the requested data. When building an embedded system like MB, every byte of space is important; an extra step here, a byte there can add up to it does not fit or it runs to slow...
Lou
ConligWX
Re: [wind0dir-act]
Post by ConligWX »
To change the format would be the correct thing to do so that Meteobridge reports the same as the rest of the world.
No weather report shows 0.0-360.0 degrees in wind direction.
It's just typically wrong show this value when reporting weather values.
Re: [wind0dir-act]
Starting to really split hairs here, appears to be concern over something that is not a real issue with a mechanism to give the user the output they require. Time to move on to something that is really important and may require fixing.
Re: [wind0dir-act]
[wind0dir-act.0] will show what you are looking for.
