Weather Underground Rapid Fire ** solved **
ab4bama
Post by ab4bama »
I have entered the WS ID and password for weather undergrouond. I ck'd the rapid fire box and set the update for 30 secs. The website is still only updating every 5 to 6 mins. Am i doing something wrong or is this a bug?
I have a TE923W and slug runing v1.8
Re:Weather Underground Rapid Fire
Meteohub does the regular update (every 5 min for example) and the rapid fire (when selected). Both are working in parallel.
You can see rapid fire working when looking at the live-data info at to upper right in wu. There it says when data has been received.
I am not sure, if 1.8 handles all this correctly. 1.9b should do.
Regards,
Boris
ab4bama
Post by ab4bama »
That's where I am looking WU current conditions. It is updating every 5 to 6 mins and says it is via normal update. When I was using the WD program it said rapid fire. I will upgrade to the 1.9b and see if it makes a difference.
THANKS
ab4bama
Post by ab4bama »
THANKS BORIS!!!
The upgrade to 1.9b did the trick. Rapid fire is updating correctly now.
