DEUTSCH:
Update V3.1b (NSLU2 und x86) enthält die folgenden Änderungen:
* Behebt einen "buffer overflow" Fehler bei der Erstellung der "clientraw.txt".
* Behebt einen Fehler, der zur Reduzierung der Werte in den Solarstrahlungsgrafiken in WD-Live um den Faktor 10 führt.
* Behebt einen Fehler, der bei der Berechnung der Regenraten für die Wetterstation WH-1080 auftreten kann.
* Erlaubt die Übergabe des höhenkorrigierten relativen Luftdrucks an WSWIN.
ENGLISH:
Update to Meteohub V3.1b (NSLU2 and x86):
* Fixes a buffer overflow bug that might occur when building a "clientraw.txt" file.
* Fixes a bug that reduces values for solar radiation graphs in WD-Live by factor 10.
* Fixes a bug that could cause wrong rain rates for station WH-1080.
* Supports export of sealevel pressure to WSWIN.
Meteohub Update 3.1b (experimental)
Re:Meteohub Update 3.1b (experimental)
had running 3.1a, but
since applying 3.1b today I see two glitches with the UV and wind direction variables
see screenshot
see screenshot
I guess recomputation has not finished yet, so min/max values are not there for sure.
if you use variable notation [day1_uv0_indexmax:--] it will return "--" when variable is not avail.
Please check again with recomputation finished.
I don´t think it is recomputation, because it finished with recomputation.
If you check my sensors from there, you´ll see that the two values for UV and wind main direction are there
http://adr.homedns.org/meteograph.cgi?text=all
Also I did not change something with the code since yesterday.
It must have something to do with 3.1b, because 3.1a worked fine.
<font color="yellow">UV-Index: [day1_uv0_indexmax] (<script type="text/javascript">var str="[day1_uv0_indexmax_time]";document.write( str.substring(8,10),":",str.substring(10,12));</script> Uhr)</font><br> <br>
<u>Wind:</u> [day1_wind0_speedmax_kmh] km/h | [day1_wind0_speedmax_mph] mph <br>
[day1_wind0_speedmax_kn] kn | [day1_wind0_speedmax_bft] bft
(<script type="text/javascript">var str="[day1_wind0_speedmax_time]";document.write( str.substring(8,10),":",str.substring(10,12));</script> Uhr)<br>
<u>Böen:</u> [day1_wind0_gustspeedmax_kmh] km/h | [day1_wind0_gustspeedmax_mph] mph <br>
[day1_wind0_gustspeedmax_kn] kn | [day1_wind0_gustspeedmax_bft] bft
(<script type="text/javascript">var str="[day1_wind0_gustspeedmax_time]";document.write( str.substring(8,10),":",str.substring(10,12));</script> Uhr)<br>
<u>Hauptrichtung:</u> [day1_wind0_maindir_de] | [day1_wind0_maindir_deg]° <br><br>
<font color="orange">Sonne: <sup>[actual_sunrise_standard_local]</sup> | <sub>[actual_sunset_standard_local]</sub> Uhr<br>
Tageslänge: [actual_daylength_standard_hhmm] h</font><br>
[actual_lunar_phase_de]<br>Sichtbarkeit: [actual_lunar_phase_percentage]% <img src="http://www.myway.de/honsolgen/moon.png" width="17" height="17"><hr style="WIDTH: 150px; HEIGHT: 1px" size="1"></font>
Ja, Du hast recht. Bitte probier mal das Update, das ich Dir grad per email gesendet habe.
