charts endless loop on DST time change **fixed**
after DST time change, charts template enters endless loop on changed hour. Generating charts to drive take entire drive space, calling charts http never ends.
its same on data export
Re: charts endless loop on DST time change
I think that is the same issue that I have......kicked in at 23:59 for me. I have turned all my charts and exports off for the moment.
Paul
Paul
- ConligWX
what country are you both in? It doesn't seem to have effected my charts as yet.
I have one create a chart every hour for last month and one end of month for a yearly chart. both work fine is I manually "test" them.
our time change was 01:00 (GMT) to 02:00 (BST)
Regards Simon
https://www.conligwx.org/pws
Poland had time change tonight
I am in the UK. I know one other UK Nano user who is also showing site offline at 23:59. Suspect thats the same issue
UK did change time this morning.
My charts haven't updated since midnight. They don't upload if you click on test.
Paul
Paul
I think the issue is only on minute resolution.ConligWX wrote: Sun Mar 31, 2019 10:22 am ...
thunderstorm
- Senior Boarder
I've a similar problem when exporting data. Basically the export is filling up my SD card (which resulted into a dataloss since 2:00)
The export runs every hour (before each current hour) on the current hour and exports values per minute
- ConligWX
I suggest you all contact Boris. this is obviously a bug that is bespoke to you settings.
Regards Simon
Same problem for me, it started after 2019-03-31 01:55. We (Germany) had the change to CEST at 2019-03-31 02:00.
Symptoms : Unlimited growing chart html file, no more uploads of any kind.
I was doing charts every 5 minutes and two different templates every 2 minutes.
After disabling the chart generation and deleting the accumulated files at least the template stuff is now working again.
hello,
Just tried with 10 minute resolution and same result. File size just increases on the SD and no upload of any files. You then have to turn off the upload of the chart file and reboot to get the template uploading again.
Paul
Paul
I have just tried my charts and data export generation and it seems to be working again. This is the first time that I have tried the chart/export nano SD function since the day that the clocks changed in the UK (31st March 2019). Whilst the bug was repeatedly occuring on the day that the clocks changed, it appears that it is OK on other days.
I have sent Boris a PM, but not heard anything from him yet. Hopefully he will find a fix, but in the mean time my chart/data export uploads seems to be working again.
Good to hear if others with the same problem can now upload?
Paul
Paul
Yes, I can confirm this. I re-activated the chart generation after more than 24 hours past the DST change and it is working again.
It would be nice if this problem could be corrected, because it will hit us again at the next time change.
Cheers, -pl
Cheers, -pl
Bug is fixed... as we will see next year, hopefully
Glad to see this - Thanks! -pl
