Latest Version Update Problem **solved**
Ed_Heaton
Post by Ed_Heaton »
For some reason my meteobridge will not go to the latest version. I've rebooted several times without any success.
Platform: TL-MR3020 (plus USB hub)
RAM: 29364 kB total, 4092 kB free (86% used)
SW Version: Meteobridge 3.8 (Jan 2 2019, build 12626), FW 1.4
Uptime: 0 hours, 7 minutes Buffer: 2 items (0%)
Includes access to new releases until: 2019-05-13
Re: Latest Version Update Problem
That's a bit odd as the last 3.8 version is Jan 1, 2019.
I assume you have the version control set to "newest" and not "stick to version 3.8"? Have you tried re-powering as opposed to Reboot?
Ed_Heaton
Post by Ed_Heaton »
I do have it set to latest version... I will try a power off in lieu of a reboot...
Ed_Heaton
Post by Ed_Heaton »
Nope didn't seem to help unplugging it... Thoughts?????
Ed_Heaton
Post by Ed_Heaton »
Boris... Thoughts?
Can you please email me a reomte login link or your MAC to check if you are still within the 2 years of free updates: info(at)meteobridge.com
Ed_Heaton
Post by Ed_Heaton »
Sorry for the delay Boris I was out of town for 7 days... I sent you an email last night! Thanks
This seems to be an issue with the 3.8 version. Once you have selected this and loaded the 3.8 version it will ignore going to "newest" again. Work around is to go the version "3.6" first and having that to select "newest" again. This time most recent version will load.
Ed_Heaton
Re: Latest Version Update Problem **solved**
Post by Ed_Heaton »
Thanks Boris!!!
Yes you can use next version, Yes you can stick with old one, really all depends what any big fixes mean to you? Unless the new version has critical updates relative and meaningful to you what you require then maybe not much point updating.
So what is your "old one"?
