Errors Live Data Tab **solved**
amateurextra
Post by amateurextra »
OS Windows 10, Meteobridge 4.0 (May 26 2019, build 12972), FW 1.4, platform TL-MR3020 plus USB Hub, Davis Vantage Pro2 Plus USB.
Weatherflow: No weather network traffic - upload scheduled every 5 minutes
Weather Underground: 2019-05-31 03:51:45 Success: 2019-05-31 03:51:45
Meteotemplate: 2019-05-31 03:51:47 Success: 2019-05-31 03:51:45
Weather Cloud: 2019-05-31 03:51:48 Error: 2019-05-31 03:51:45 500 (no more tries) - upload scheduled every hour
AWEKAS: 2019-05-31 03:51:49 Error: 2019-05-31 03:51:45 too many requests - try again later (no more tries) - upload scheduled every hour
Ambient Weather Network: No weather network traffic - upload scheduled every minute
PWS Weather: 2019-05-31 03:51:50 Success: 2019-05-31 03:51:45
CWOP: 2019-05-31 03:51:03 Success: 2019-05-31 03:50:53
AnythingWeather: 2019-05-31 03:51:04 Sent: 2019-05-31 03:50:53 SUCCESS
Twitter Upload: 2019-05-31 03:24:28 Success: 2019-05-31 03:24:25- manual feed only, automated feed inoperative - upload scheduled every 30 minutes
HTTP Upload: 2019-05-31 03:51:35 Success: 2019-05-31 03:51:26
Sent E-Mail: No email traffic
Triggered Alarms: ? No alarm
FTP Upload: 2019-05-31 03:51:33 Success: 2019-05-31 03:51:26
Solutions?
Christopher Doherty, N3UVR
CoCoRaHS PA-LC-24
CWOP EW5712
Davis Vantage Pro2 Plus via MB 4.4
Re: Errors Live Data Tab
Do you think you may be trying to push a little too much from something like a MR3020?
amateurextra
Mattk wrote: Fri May 31, 2019 1:22 pm Do you think you may be trying to push a little too much from something like a MR3020?
Twitter stopped working on 14 May. Prior to that date, all uploads worked without issue. I added Meteotemplate on 26 May. I will, as an experiment, end some uploads and see what transpires. As far as "pushing a little too much", I do not know about that.
CoCoRaHS PA-LC-24
CWOP EW5712
Sorry, I cannot work with this unsorted bunch of partial information. Uploads work fine, when needed data is coming in fine from the weather station. You can inspect per service when it has been triggered. Please start from there to spot your failure.
amateurextra
admin wrote: Sat Jun 01, 2019 1:35 pm Sorry, I cannot work with this unsorted bunch of partial information. Uploads work fine, when needed data is coming in fine from the weather station. You can inspect per service when it has been triggered. Please start from there to spot your failure.
If Twitter would trigger I suppose I could inspect, that begs the question, inspect where? Moreover, what additional information do you need? This is the information copied from the Meteobridge Live Data tab.
CoCoRaHS PA-LC-24
CWOP EW5712
SANdood
Post by SANdood »
FWIW, I have to MR3020v3s, each running more than 23 different weather services, HTTP/FTP uploads and several HTTP GETs.
Weather Network Status
	Meteoplug Cloud:		2019-06-02 08:25:00 Success: 2019-06-02 08:24:44
	Meteoplug Cloud (Live):		2019-06-02 08:28:47 Success: 2019-06-02 08:28:47
	Weather Underground:		2019-06-02 08:29:04 Success: 2019-06-02 08:28:56
	Meteotemplate:			2019-06-02 08:28:43 Success: 2019-06-02 08:28:41
	Home Weather Station:		2019-06-02 08:28:53 Success: 2019-06-02 08:28:53
	Weather Cloud:			2019-06-02 08:23:43 Success: 2019-06-02 08:23:38
	AWEKAS:				2019-06-02 08:28:54 Success: 2019-06-02 08:28:53
	Ambient Weather Network:	2019-06-02 08:28:55 Success: 2019-06-02 08:28:53
	Open Weather Map:		2019-06-02 08:28:57 Success: 2019-06-02 08:28:53
	PWS Weather:			2019-06-02 08:28:58 Success: 2019-06-02 08:28:53
	UK Met Office WOW / WOW-NL:	2019-06-02 08:24:52 Success: 2019-06-02 08:24:38
	CWOP:				2019-06-02 08:24:56 Success: 2019-06-02 08:24:38
	Windfinder:			2019-06-02 08:29:00 Success: 2019-06-02 08:28:53
	Windguru:			2019-06-02 08:29:01 Success: 2019-06-02 08:28:53
	wetter.com:			2019-06-02 08:29:03 Success: 2019-06-02 08:28:53
	AnythingWeather:		2019-06-02 08:24:58 Sent: 2019-06-02 08:24:38 SUCCESS
	HTTP Upload:			2019-06-02 08:28:51 Success: 2019-06-02 08:28:49
	FTP Upload:			2019-06-02 08:24:22 Success: 2019-06-02 08:24:21
	Meteobridge Weather Cam:	2019-06-02 08:28:11 Success: 2019-06-02 08:28:00
As MB is only a single threaded device then it's not the number (as such) of services etc that could be an issue but the config and execution of those services as a time line. Pushing 23 services one at a time is just a single service 23 times, pushing multiple services at the same time is when there could be conflicts and dropouts?
amateurextra
Mattk wrote: Sun Jun 02, 2019 11:19 pm As MB is only a single threaded device then it's not the number (as such) of services etc that could be an issue but the config and execution of those services as a time line. Pushing 23 services one at a time is just a single service 23 times, pushing multiple services at the same time is when there could be conflicts and dropouts?
Weather Underground: 2019-06-03 14:06:29 Success: 2019-06-03 14:06:28
Meteotemplate: 2019-06-03 14:06:31 Success: 2019-06-03 14:06:28
Weather Cloud: 2019-06-03 14:06:32 Error: 2019-06-03 14:06:28 500 (no more tries)
AWEKAS: 2019-06-03 14:06:33 Error: 2019-06-03 14:06:28 too many requests - try again later (no more tries)
Open Weather Map: 2019-06-03 14:05:51 Success: 2019-06-03 14:05:31
PWS Weather: 2019-06-03 14:05:52 Success: 2019-06-03 14:05:31
CWOP: 2019-06-03 14:05:56 Success: 2019-06-03 14:05:31
Twitter Upload: 2019-06-03 13:52:12 Success: 2019-06-03 13:51:58
HTTP Upload: 2019-06-03 14:06:15 Success: 2019-06-03 14:06:07
FTP Upload: 2019-06-03 14:06:13 Success: 2019-06-03 14:06:07
@ Mattk - Weatherflow and Ambient Weather show no weather traffic after 2 days so I terminated the processes. (I do not care if those work or not, but I noticed a fix "released March 26, 2019 fixes a newly introduced bug that inhibits uploading to ambient weather network" and that makes me wonder if this bug still exists.) Weathercloud and Awekas throw errors (as you see above) but the data is sent and is current. I do not know why, maybe a software glitch, hardware glitch or something on their end. I added "Open Weather Map" and the services I want, PWS and CWOP, are working fine. Twitter is now working. I tried various upload schedules and finally tried "after every full hour" and now Twitter is being sent.
CoCoRaHS PA-LC-24
CWOP EW5712
When you give me a remote login, I will give it a check, when I have some spare time. Please send credentials to "info(at)meteobridge.com". With thousands of users I doubt (and you should too) that you detected anything remarkable, but we ll see ;-)
amateurextra
admin wrote: Tue Jun 04, 2019 10:53 pm When you give me a remote login, I will give it a check, when I have some spare time. Please send credentials to "info(at)meteobridge.com". With thousands of users I doubt (and you should too) that you detected anything remarkable, but we ll see ;-)
Will do, thanks. What I have detected, looking at the logs, is that CWOP is being uploaded approximately in 1 minute 25 second intervals and I have the interval set for 15 minutes. Here is the partial log for CWOP:
2019-06-04 18:17:09 Success: 2019-06-04 18:16:45
2019-06-04 18:15:45 Success: 2019-06-04 18:15:20
2019-06-04 18:14:23 Success: 2019-06-04 18:13:59
2019-06-04 18:12:59 Success: 2019-06-04 18:12:34
2019-06-04 18:11:19 Success: 2019-06-04 18:10:54
2019-06-04 18:09:43 Success: 2019-06-04 18:09:30
2019-06-04 18:08:02 Success: 2019-06-04 18:07:48
2019-06-04 18:06:51 Success: 2019-06-04 18:06:26
2019-06-04 18:05:28 Success: 2019-06-04 18:05:02
2019-06-04 18:04:07 Success: 2019-06-04 18:03:42
PWS is set for a 10 minute interval and it is uploading also in approximately 1 minute 25 second intervals. Here is the partial log:
2019-06-04 18:28:21 Success: 2019-06-04 18:28:07
2019-06-04 18:27:00 Success: 2019-06-04 18:26:40
2019-06-04 18:24:47 Success: 2019-06-04 18:24:27
2019-06-04 18:23:24 Success: 2019-06-04 18:23:05
2019-06-04 18:22:01 Success: 2019-06-04 18:21:41
2019-06-04 18:19:48 Success: 2019-06-04 18:19:29
2019-06-04 18:18:27 Success: 2019-06-04 18:18:07
2019-06-04 18:17:05 Success: 2019-06-04 18:16:45
2019-06-04 18:15:41 Success: 2019-06-04 18:15:20
2019-06-04 18:14:19 Success: 2019-06-04 18:13:58
2019-06-04 18:12:55 Success: 2019-06-04 18:12:34
There are other anomalies. Open Weather Map, set for 30 minutes is uploading at approximately 1 minute 25 second intervals. Ambient Weather is now uploading after days of not uploading, interesting. I will send you the remote login and you can look when you get a chance, thanks.
CoCoRaHS PA-LC-24
CWOP EW5712
Problems have been tracked down to be the consequence of the logging process restarting again and again caused by bug. Bug has been solved with just released update. Please give this a chance.
amateurextra
admin wrote: Sun Jun 09, 2019 4:20 pm Problems have been tracked down to be the consequence of the logging process restarting again and again caused by bug. Bug has been solved with just released update. Please give this a chance.
Thank you for the help. The system is working and data is flowing.
CoCoRaHS PA-LC-24
CWOP EW5712
