Local Dashboard query **solved**
ConligWX
Post by ConligWX »
Ok so I've setup the PWS Local Dashboard.
Can someone confirm the Update Interval is just local to the console or does this also poll Darksky and CheckWX at the same interval period?
I ask as Darksky only has 1000 polls perday on the free plan, and every minute interval would poll 1440 times perday. the slowest setting is "per minute".
BigAlT
Re: Local Dashboard query
Post by BigAlT »
Per Boris’s comments on the latest firmware update for the Nano SD ( July 7 ) which fixed the problem of the dashboard forecast being missing after the June 22 firmware update. He has now set up external api downloads to only take place every 10 minutes. Make sure you update to the July 7 firmware update if you’re using a Nano SD.
ConligWX
Post by ConligWX »
thanks - just updated
