UTC time **solved**
andresegea
- Fresh Boarder
UTC time **solved**
I have meteoclimatic on weather network of meteobridge, it works fine.
It would be possible add a variable to send the time format in UTC?
Thanks in advance.
Andrés Egea
Thanks in advance.
Andrés Egea
Re: UTC time
Yes, for sure, if you tell me how and when the weather network admin tells me that he/she is fine to get this additional parameter. Are you the admin?
andresegea
- Fresh Boarder
Re: UTC time
Sorry, I didn't see the answer.
Yes, I am admin.
It is about 'meteoclimatic' when meteobridge sends data in UPD time and I'd like to choose between UTC or UPD, everything else works fine.
Best Regards,
Andres Egea
Yes, I am admin.
Best Regards,
Andres Egea
Re: UTC time
Please give me the exact syntax how UTC should be transferred.
Then I can add this for the next release.
andresegea
- Fresh Boarder
Re: UTC time
Well I am not sure what do you mean, so I send you a picture
Best regards
Best regards
- UTC.jpg (83 KiB) Viewed 16437 times
Re: UTC time
So you mean it should report UTC instead of local time? So far I understood your request that you would like to have UTC additionally.
andresegea
- Fresh Boarder
Re: UTC time
Thanks a lot and best regards
andresegea
- Fresh Boarder
Re: UTC time
hi,
I have updated meteobridge and I see that It sends the data in two format UPD and UTC. Well, I meant that I would like to send one of the two, or UPD or UTC because meteoclimatic's datasheet only read one.
I apologize by the issue caused
Have a good weekend.
Re: UTC time
Should it just send UTC? I can change on next update.
andresegea
- Fresh Boarder
Re: UTC time
Merci
and thank you for your patience
Re: UTC time
ok, next update will have UTC only (no UPD).
Re: UTC time
I can't achieve to send the data to meteoclimatic using UTC.
Otherwise, the minimum frequency to push the template (every 10 minutes) is quite high. It would be better to elliminate the 1 hour frequency, and set 2 or 5 minutes.
Could it be possible, Boris, to have the meteoclimatic.txt template? That way, we could customize ourselves
Re: UTC time
It is now always sent in local time via UPD. I agreed with meteoclimatic admin to handle it that way.
Please check with Andres Egea if they are fine to receive data more often.
Re: UTC time
Thank you, Boris. I'll contact with Andres, but
¿Why we can't select UTC as local time? As I solution, I can use Atlantic/Reykjavik
Re: UTC time
Is UTC and Local time exactly the same all year round, no DST?
