Auto Backup
bolzano
Re:Auto Backup
Post by bolzano »
admin wrote:you can remove the file/link "/home/meteohub/meteohub". This has been produced by one of the updates by accident.
Sure ?
Files in those directories seems to be up to date...
Re:Auto Backup
"/home/meteohub/meteohub" is a symbolik link to "/home/meteohub". I don't exactly know if deleting that link via Windows, what might happen.
If you want to be sure, login via ssh:
1) login via ssh (putty for example), port 22, user root, password meteohub
2) give command "rm /home/meteohub/meteohub"
bolzano
Re:Auto Backup
Post by bolzano »
Done.
thanks !
AAMFlyer
Re:Auto Backup
Post by AAMFlyer »
For those that may run in Vista - Scheduler has an issue with running batch files - so you have to do the following...
Program Script is: cmd
argument line is: /c backup.bat
start in is your director of the bat file.
Gregg
oliverb
Re:Auto Backup
Post by oliverb »
I am having trouble running backup.bat in Windows 7 scheduler. The file runs fine when run within windows but does not run in scheduler. Can anyone help with my scheduler settings?
Thanks Brett. Image
AAMFlyer
Re:Auto Backup
Post by AAMFlyer »
I just moved over to Win 7 too and don't seem to have any problems....but I will take a look at my settings this weekend when I get a chance.... I know before I moved from vista to Win 7 I exported my Schedule settings then just imported them back into Win 7.....
Gregg
oliverb
Re:Auto Backup
Post by oliverb »
Thanks Gregg.
I have got it working. I presumed wrongly it would work as Vista and require "CMD" in the Program box.
See working Windows 7 settings below. Image
oliverb
Re:Auto Backup
Post by oliverb »
This is the cmd screen during my backup.
Is there anything going wrong here?
End of backup Image
oliverb
Re:Auto Backup
Post by oliverb »
Start of backup. Image
oliverb
Re:Auto Backup
Post by oliverb »
My lost and found folder on Meteohub is empty could that be reason for the error on the top backup screen?
LorieJCall
Re: Auto Backup
Post by LorieJCall »
My apologies for bumping an ancient thread: I'm hoping someone can explain why Plans A and B didn't work, but Plan C did.
I was unable to find cwRsync anywhere in the Downloads section of the MeteoHub wiki. (I looked in all four sections: Documentation, Images, Updates, and Misc, but couldn't find it.) I googled through that part of the website, as well as the forum, and didn't see any updated location information, so I downloaded the SourceForge version at http://sourceforge.net/projects/sereds/ ... ync/4.0.6/.
After installation, I created the config and data folders, as well as a modified backup.bat file. (I omitted the "@echo off" line, and changed "Meteohub" to match my MeteoHub's hostname.):
sevenless wrote:3) Open notepad and insert the following text:
@echo off
rsync.exe -uav rsync://root@
Meteohub/data data
Meteohub/config config
When I ran backup.bat, I got connection timeouts for both command lines. I changed the hostname (which is mixed-case characters with numbers) to all lowercase, then to all uppercase; neither ran successfully. When I replaced the hostname with the static IP address, it appears to have backed-up everything except \\...\\public\\uploads, which is a symlink to /var/run/meteohub/uploads.
My Windows machines are running XP SP3. The MeteoHub is in the same workgroup and on the same subnet as the rest of my LAN; I'm able to access the Samba share from all computers on the LAN. While the MeteoHub's hostname is shown on Windows machines with mixed-case characters, I can't ping it that way, but again, I can ping the static IP address.
Can someone explain what I'm overlooking or doing wrong? Should I rename my MeteoHub's hostname to all lowercase? Do I need to be concerned about not including \\...\\public\\uploads? Or should I just take what I've got so far and run? Thanks in advance!
Lorie
d_l
Re: Auto Backup
Post by d_l »
The uploads folder is usually empty except for brief intervals when the Meteohub loads files into it just before making an upload. I think it is more of a scratch pad folder.
You didn't say if you have a hostname for your Meteohub listed with its IP address in your hosts file. That might account for the failure using the hostname, but its IP address works.
LorieJCall
Re: Auto Backup
d_l wrote:The uploads folder is usually empty except for brief intervals when the Meteohub loads files into it just before making an upload. I think it is more of a scratch pad folder.
Thanks for the clarification on \\...\\public\\uploads. And correct, I didn't have the MeteoHub defined in my hosts file, and didn't even think of it, since I could access the Samba share without any issues. Once I added that entry, backup.bat was able to run using the hostname. Thanks for the quick response!
